Re: A new Video Converter beta version (1.0.0.24) is out!
Hello Coral,
I fixed your problem with .mkv file, you need to wait for the next version...
cedric wrote:Hello Coral,
vous êtes magnifique. Google can do miracles with translation :lol:
Thanks for your exelent hard work. If you ever come this way I shall be very happy to buy you a drink.
Hello Cedric,
Will you consider adding a "No subtitles" setting in the coustom profile editor ?
Trezona
Post by Trezona »
Coral wrote:Hello Cedric,
I agree!
Hello Cedric,
The error is still there.
Please also check transparency on edges of buttons.
Re: A new Video Converter beta version (1.0.0.25) is out!
Hello Coral,
I can't reproduce your problem.
Please can you post your custom profile?
Thank you.
Thank you.
This is the coustom profile I'm using. Please use the same mkv clip I have posted to you some time ago
<?xml version="1.0" encoding="Windows-1252" standalone="no"?>
<BlurayConverter_profile>
<VSO_custom_profile>
<Description/>
<DefaultFileExtension>mpg</DefaultFileExtension>
<FileFormat>dvd</FileFormat>
<ContextName>PAL 16:9</ContextName>
<VideoProfile>
<Item0>codec=mpeg2video</Item0>
<Item1>width=720</Item1>
<Item2>height=576</Item2>
<Item3>time_base=1/25</Item3>
<Item4>aspect=(16*576)/(9*720)</Item4>
<Count>5</Count>
</VideoProfile>
<AudioProfile>
<Item0>codec=ac3</Item0>
<Item1>ac=2</Item1>
<Item2>ar=48000</Item2>
<Item3>ab_by_channel=80000</Item3>
<Count>4</Count>
</AudioProfile>
<SubtitleProfile>
<Count>0</Count>
</SubtitleProfile>
<ImageIndex>6</ImageIndex>
<TemplateName>Custom profiles</TemplateName>
</VSO_custom_profile>
</BlurayConverter_profile>
Just to confirm that the problem is "really" fixed, can you try with profile in attachment?
Thank you.
Test Coral.rar
(557 Bytes) Downloaded 554 times
cedric wrote:Just to confirm that the problem is "really" fixed, can you try with profile in attachment?
Thank you.
Working fine with your modified profile.
Ok thanks, fix will be available in next release...
Hello Cedric,
There is a small problem regarding saving with the same name. Perhaps you can fix it in the next version.
If you try to convert the same file before closing the converter, you will be asked to clear the first project. Unless the project name is changed manually.
If the converter is closed project 2 will be generated.
Project auto naming option is only applied with new project.
That mean when your clear the tree (remove all items) then add a new video file.
If you convert "Project 1" then remove item from tree, new project name will be "Project 2" because "Project 1" already exists.
cedric wrote:Project auto naming option is only applied with new project.
Well. If it is meant to work that way, then it is working fine.
What's happening with the updates ??
Post by Annelise »
there is a new version 1.0.0.26 as official download: http://www.vso-software.fr/download.php
Annelise wrote:there is a new version 1.0.0.26 as official download: http://www.vso-software.fr/download.php
Hello Annelise,
Thank you for the update. It would be nice if you can update the link at the top of the thread and add "what's new"
Much Obliged.
Re: A new Video Converter beta version (1.0.0.26) is out!
Post by Annelise »
Done :-)
Annelise wrote:Done :-)
You're a smart girl :wink:
Señor Rossi
Cutting control
Post by Señor Rossi »
Would it be possible to allow VSO Video Converter a more precise control for cutting, e.g. by entering or changing numerical values instead of just clicking or drag and drop? By the way: The VSO Video Converter is a great piece of software!
Hello Senor Rossi,
You can change the cut start/end time by using the "F2" key just after creating a new section.
Select the start time or the end time field of the section you want to edit then hit "F2" key.
I will implement the double click to open editor for next version.
