felicia
Re: CXD latest beta version 7.0.0.46
Post by felicia »
@deadlyshadow: Still unable to reproduce, please send bug report so I can grab your settings.
deadlyshadow
Post by deadlyshadow »
felicia wrote:@deadlyshadow: Still unable to reproduce, please send bug report so I can grab your settings.
Please do not compare Output and preview
convert the movie then watch output for example start with 7th minute, you can see that subtitle goes up and down
felicia
Post by felicia »
Just to be sure we use the same terms:
- Input -> Your source file
- Preview -> Self explanatory
- Output -> Conversion
In the image above I'm comparing the preview to the output (conversion), isn't that your issue?
deadlyshadow
No, It's not
Convert the source file then play output DVD, check subtitle position
felicia
Re: CXD latest beta version 7.0.0.47
Post by felicia »
new beta posted
Ch3vr0n
Post by Ch3vr0n »
felicia wrote:new beta posted
When did the logview pane become a seperate window instead of fixed at the bottom? I liked the old way better and it allowed me to view the log permanently without blocking any view of the main GUI.
Oh and it see the nl-BE locale likely wasn't synched in beta .47. There's no way there's nearly 1K new strings. Manually doing a sync from the online repo using the tool fixed the "974 new strings" issue. After synching there's only 8 new strings (which now have also been synched). This currently causes multiple strings in the main GUI and settings to be in English and not Dutch (nl-BE)
Desktop: Project Phoenix
It's been there for quite a while. Several versions back.
felicia
Re: CXD latest beta version 7.0.0.48
Post by felicia »
new beta posted
Ch3vr0n
Post by Ch3vr0n »
Installed fine, bust just as a precaution i checked language file status. Seems like 12 strings didn't get synched. Fixed that through repo connection.
vers 48 for both DVD7 and HD3 make coasters, unplayable data dvds. Converted on 2 different pcs and tested on two different Sony DVD/BD PLayers. Gone back to version 47 and all OK
reverseflash92
Post by reverseflash92 »
Hello all! I’m new to this forum, but have been using ConvertXtoDvd religiously for the past year.
I can echo yoyo57’s sentiments. Version 48 produces DVD that’s wont work, basically become coasters. Reverting back to Version 47 solves the issue.
felicia
Re: CXD latest beta version 7.0.0.49
Post by felicia »
new beta posted.
Fixes burning ssues
felicia
Post by felicia »
Ch3vr0n wrote:Installed fine, bust just as a precaution i checked language file status. Seems like 12 strings didn't get synched. Fixed that through repo connection.
I tried to reproduce what you describe from a clean install and got 13 updates instead of 12 and the second time I tried (also from a clean install) I got 2. So I'm changing the localisation tool so it can log the changes it has made.
I'll keep you posted.
felicia
Post by felicia »
Also, I haven't changed the locale file for the latest beta as I want to know what happens
Ch3vr0n
Post by Ch3vr0n »
excellent, feel free to e-mail me an (internal) pre-beta build :) if you want to do some prior testing
ROBERT46055
Post by ROBERT46055 »
just found out twenty things i copyed are data disks and the don't work in my blueray magerbug you make mistakes like that and i leave!?
ROBERT46055
the reading of the files when there transferring are slow as a wet noodle meager mistake again!? :twisted: :roll: :evil:
ROBERT46055
it want go to next file you half to go in menu to get the next file on list of 10 files 1-10 are like not there if you don't check ?! :evil:
ROBERT46055
I'm sorry the file was 265 that's why it goes slow sorry :D
Ch3vr0n
Post by Ch3vr0n »
there was a faulty burn issue in build 48. Was fixed in 49. It's your own risk to use beta's don't blame the staff. Oh and you do know u can EDIT a post right?
