Version 1.2.0.8 won't run
Re: Version 1.2.0.8 won't run
You do not need the Internet to run the software. Are you coming a file that ends with .exe ?
maonstad wrote:I currently don't have internet at home due to an upgrade that will be installed in two weeks. (new modem, and new router, etc). Right now,
I'm at work, and so I copy the file (this version) at work and install it on my home computer. It doens't run after the install so I believe not having
internet may be the problem. Shutting down the computer does prompt me to 'end the program'. If anybody wants to test the program and
shut down the internet, it may be duplicated???
Mark
HiClaire wrote:You do not need the Internet to run the software. Are you coming a file that ends with .exe ?
I an confirm you do not need internet connection.
I removed Blu-ray converter ultimate.
Then ran "Clean VSO Tool".
Re-installed version 1.2.0.16.
All while disconnected from the net.
Things are working as they should.
I have tried all the way up 1.2.0.14 and it will run once. Exit the program and then it doesn't run again until I reboot the computer and run it and it does prompt me for the try, buy or activate and does run once.
Now I have tried version 1.2.0.16 and it works perfectly every time now. (This is the ultimate version beta).
(without internet). Something has changed between version 14 and 16. (other than the differences between ultimate and just the converter.
ok thanks for reporting back.
Update: With the new version 1.2.1.15, This program runs every time now. Just keeping up to date.
ok thanks very much
