Unable to load new project when started from a folder
Frederik
Re: Unable to load new project when started from a folder
Post by Frederik »
SOLVED! I can sleep again.
The problem would appear to be related to incorrect error trapping action when a folder contains an "invalid folder" structure. In my video example the folder "Baader Meinhof Complex" contained legitimate files but they were not contained in a VIDEO_TS folder. When this was fixed all worked properly.
SUGGESTION:
1. If no VIDEO_TS file - don't worry about it, who needs it anyway.
2. If no IFO file just string the VOB files together sequentially (this is the default action of DivX converter that I use constantly).
Thanks for you help.
Ahh, that was tricky! :)
Good that you found it out, quite impossible to find any other way - except with luck!
