Latest ConvertXtoVideo version - 2.0.0.5
igor_lvk
Re: Latest ConvertXtoVideo beta version - 1.6.0.2
Post by igor_lvk »
cedric wrote:It was an installer problem I think... rebuilt now
Can you retry by re-DOWNLOADING then install the last version?
Thank you.
All ok now! Thanks.
JEMA
Re: Latest ConvertXtoVideo beta version - 1.6.0.4
Post by JEMA »
Version 1.6.0.4. Nice program but there is an important problem. It's not possible anymore to copy an audio track in HD (DTS HD MA for instance).
I make for example a custom profile in MKV. In step 3 (audio tracks), I choose for "Copy (remux if possible ..." (put a little "v").
It doesn't work : the final result is that the audio track looses in any cases his HD : it becomes normal AC3 or DTS without HD and if the track is in 7.1, it becomes 5.1 whatever I do.
In (and till) version 1.5.0.36, there was no problem to copy an audio track in DTS HD MA. Has someone else observed the same problem? I hope it will be fixed as soon as possible.
Thank tou very much.
thanks for reporting will be fixed in the next version
http://bugs.vso-software.fr/view.php?id=9798
peter7769
Re: Latest ConvertXtoVideo beta version - 1.6.0.5
Post by peter7769 »
Not sure if this is a bug as i don't use this program a great deal, but today i went to convert a film and had to crop some of the picture, but when i clicked on apply and then convert the crop wasn't taken into affect, so i tried it again and got the same results, could someone check & confirm?
Pete
Do you see the changes applying in the preview window when playing the video?
What format are you converting to?
Can you post your log file?
I did a quick test cropping and converting to AVI +mp3 and no problem.
peter7769
Post by peter7769 »
Claire wrote:Do you see the changes applying in the preview window when playing the video?
firstly when playing the video in the preview window within the editor it looked fine, but after starting the conversion and then clicking the preview window no changes had been made.
im converting to MKV(H264 + AAc)
i have included some screenshots and a log file, but the log file is only a short one as i started the conversion and then stopped it when i realised that something was wrong.
Hope this helps
Pete
ConvertXtoVideo Ultimate 1_crashlog_.20150511.211747.328.log
(3.81 KiB) Downloaded 607 times
confirmed bug now reported here, thanks
http://bugs.vso-software.fr/view.php?id=9853
peter7769
Post by peter7769 »
Thanks Claire.
Maikel
Re: Latest ConvertXtoVideo beta version - 1.6.0.6
Post by Maikel »
Im having crashing issues while encoding With Nvidia Drivers 352.84, for Windows 10
Its the first official Nvidia driver that supports DirectX 12.
The previous one, 347.55, worked great on Windows 10.
ConvertXtoVideo Ultimate 1_crashlog_.20150516.103215.973.log
Crash log
(5.52 KiB) Downloaded 579 times
Thanks for reporting we will have to look into it, but we might wait until official release of Windows 10, things might change on both their sides
peter7769
Post by peter7769 »
Claire wrote:confirmed bug now reported here, thanks
Any idea when this Bug maybe fixed?
Re: Latest ConvertXtoVideo beta version - 1.6.0.9
should now be fixed in 1.6.0.9
available here
http://www.vso-software.fr/products/vid ... -video.php
Maikel
Re: Latest ConvertXtoVideo beta version - 1.6.0.13
Post by Maikel »
Im trying the Intel Quick Sync conversion, but in the Frame Rate is really low, it is showing 11 - 12 FPS.
Is that the average framerate got with Quick Sync?
I ve got a Core i7 -4810MQ CPU, 2.80 GHz, quad core, Intel HD 4600 Graphics
It seens too slow to this CPU.
Software encoding is far more fast, with 40 FPS.
Isnt the hardware encoding supposed to be faster?
Hello Maikel,
Please, do not post the same report on multiple threads:
http://forums.vso-software.fr/latest-cx ... tml#p94268
Maikel
Re: Latest ConvertXtoVideo beta version - 1.6.0.17
Post by Maikel »
In the latest 1.6.0.17 version, there is no graphic adapter to choose from in the dropdown menu.
Tried to run the software as Administrator, got the same
Maikel
Post by Maikel »
Always crash while selecting subtitle stream to change language
ConvertXtoVideo Ultimate 1_mainlog_.20150625.192749.793.log
crash
(1.98 KiB) Downloaded 550 times
ConvertXtoVideo Ultimate 1_crashlog_.20150625.192825.232.log
crash
(1.78 KiB) Downloaded 537 times
Maikel wrote:Always crash while selecting subtitle stream to change language
It crashes when you make the selection? Can you post a screenshot? Or it crashes when you start the conversion?
Maikel
Post by Maikel »
It crashes when I click in the subtitle stream, in the Advanced Edit window
ok thanks, but I can't seem to reproduce. If you find out more info please let us know.
Maikel
Post by Maikel »
here is the screenshot
