New ConvertXtoVideo 2.0.0.61 BETA version
JasonSGN
Re: New ConvertXtoVideo 2.0.0.2 beta version
Post by JasonSGN »
Can this be installed on the same computer as ConvertXtoVideo 1?
Yes!
I second Cherryman's request. Volume control would be outstanding in the editor window.
Added in last beta version...
Cherryman
Post by Cherryman »
Thanks Cedric :D
bigpoppa75
Post by bigpoppa75 »
Any support to convert from MKV to x256 codec. Is this coming soon or at else some type of support.
Mi`cah
bigpoppa75 wrote:Any support to convert from MKV to x256 codec. Is this coming soon or at else some type of support.
Mi`cah
I have opened an official request on the VSO Bug site for you, to have support en encode to x265
http://bugs.vso-software.fr/view.php?id=11099
Keep in mind .mkv or .mp4 for example are just containers (A file folder) that can hold different video and audio codecs.
So encoding to h265 would probably end up as an .mkv still but you would change the video codec from mpeg4 or h264 --> x265 in a new .mkv :)
Trezona
Post by Trezona »
I have a CXV licence for version 1.
Please can you send me version 2?
DIDOUDD
Re: New ConvertXtoVideo 2.0.0.3 beta version
Post by DIDOUDD »
Bonjour Claire (ou Cédric).
Je commence à tester la version 2 et j'ai une boite de dialogue me disant que je nécessite une nouvelle clé. Possédant une clé pour la version 1, faut-il changer de clé, racheter une clé pour la nouvelle version? Je ne me rappelle plus du type de License que j'avais pris.
Merci d'avance.
Bonjour,
Je vous ai envoyé par email votre nouvelle clé.
Bonne journée et weekend,
zioviru5
Post by zioviru5 »
Need another seasoned tester? I just heard and am interested in seeing the new version.
Panchdara
Post by Panchdara »
Hi. Any ideas when we can expect to be able to retrieve codes for V2.x from the site? I see we were able to get ConvertXtoHD 2.x codes, not ConvertXtoVideo 2.x codes... yet.
Thanks much
it was in place on Friday to automatically retrieve keys. Anyway I just sent you yours now by email.
Panchdara
Post by Panchdara »
Way too kind Claire. Thanks, so, so much.
Best
Hugh
DIDOUDD
Re: New ConvertXtoVideo 2.0.0.4 beta version
Post by DIDOUDD »
Merci Claire
Trezona
Post by Trezona »
Is it possible to show what the total file size will be before starting the project?
Re: New ConvertXtoVideo 2.0.0.5 beta version
There is an estimation in the bottom left of the interface, do you see it?
mpumpis
Re: New ConvertXtoVideo 2.0.0.11 beta version
Post by mpumpis »
watermark after 10 minutes disappears (version 2.0.0.11)
Trezona
Post by Trezona »
Claire wrote:Hello,
Hi Clair,
Sorry no i dont see it there. I am using Constant Rate Factor mode, so it only says "Unknown"
At the moment all i am doing is starting the project, waiting till it gets to 10% then multiplying the total MB by 10 :wink:
Its very rough, but it works for me :)
@ mpumpis thanks I confirm the bug it will be fixed in the next version.
SIMENON
Re: New ConvertXtoVideo 2.0.0.12 beta version
Post by SIMENON »
Bonjour Cedric
1°)Serait il possible d'avoir les sous-titres séparés ,un dans chaques fenètres lors de la visualisation paramètres avancés,car pour le moment les sous-titres sont au milieu de l'écran pour les deux fenètres.
2°) Y aurra t'il une version 64 bits et dans quelle delai la question a déja été poséé ,mais maintenat vous avez peut-être un delai plus précis
Et encore un grandmerci pour votre réactivité.
merci pour votre réponse
SMENON
Bonjour SIMENON,
1) l'affichage des sous-titres (en mode avant/après) sera réglé dans la prochaine version
2) nous travaillons sur les version 64bits mais ça risque de prendre longtemps...
Merci pour vos retours.
Cordialement,
