wtin wrote:Hi,
I meant to focus on CXD and CXV for the two major products and leave DVD / BR converter / CXH behind because the first two already can do what these can.
Wtin
I'm sure your feedback is most welcomed by the VSO team.
However I think they are the best judges, since they would know what is on demand.
Maikel
Re: CXD latest beta version 7.0.0.31
Post by Maikel »
After modifying a project, and choose the option to save the project as, choosing a new filename, the file isnt being saved with the name I typed.
The last characters of the filename are missing
Version: 7.0.0.31
Maikel wrote:After modifying a project, and choose the option to save the project as, choosing a new filename, the file isnt being saved with the name I typed.
Version: 7.0.0.31
For example what? So far we cannot reproduce.
ichido
Post by ichido »
When you bring up the audio button DVD player to get rid of subtitles, the play button triangle shows up. It does go out when you shut off the display. Did not do this in previous versions.
Maikel
Post by Maikel »
Version: 7.0.0.31
Strange.
I tried to reproduce the bug with a new file created project, and it seens it doesnt happen.
But with the project that I already have saved, the bug always happen. If I make any modification and save project as *(shift+ctrl+S), the new created filename doesnt have some characters in the end.
For exemple, the project file is "Colony.S02D3" and i make some modifications in the file, and then save it as "Colony.S02D4", but the saved file is only "Colony".
It seens some bug happened in the project file that causes this.
Im gonna attach the file in this post.
Its weird.
Colony.S02D4.zip
Project with bug
(19.94 KiB) Downloaded 702 times
sampa2007
Post by sampa2007 »
Subtitle in portugues (BR) not working..... Why?
@sampa2007 we will need more info. Can you post the subtitle file here on the forum, and describe the problem a bit more, maybe add some screenshots?
Version: 7.0.0.31
Try using a different separator. Example "_" or "-" instead of "."
felicia
Post by felicia »
ichido wrote:When you bring up the audio button DVD player to get rid of subtitles, the play button triangle shows up. It does go out when you shut off the display. Did not do this in previous versions.
Are you talking about playback or when you're editing your project?
What do you mean by "bring up the audio button DVD player"?
Maikel
Post by Maikel »
Version: 7.0.0.31
It seens the app ignores everything after the first dot in the filename
Using a different separator the bug doesnt happen.
I have tried with a new project, and the same has happen once.
Sometimes it happens and sometimes it wont.
But with the project that I already have done it always happen if the filename has a dot in it
AtelierD
Post by AtelierD »
Hello Team,
I've been keeping up with the updates on the CXtoDVD and CXtoVideo. This current version, 7.0.0.31, has a couple of things I wanted to mention:
1. When I preview the menu, the custom menu title doesn't show. For example: instead of "Video Compilation," it shows "Video 1" (the name of the first video on the menu).
If I use the advanced menu editor, I can put into effect the custom menu title.
2. When editing the menu in French, there are some typing errors:
The menu says "Éditionr avancée" and when exiting the advanced menu editor without saving changes, it asks "Annuler les changements et fermerl'éditeur de menu ?"
There may be more, but those are what I remember finding.
Thanks for the support!
ROBERT46055
Post by ROBERT46055 »
I'm still using 6 but how do i get beater guilty out of a 3 hours 30 Minutes file its still on good tried enhance with programs on the 6 but still nothing trying best guilty on a DVD rip file :cry: :oops: :( sorry the file for the codec is beater then the dvd
ROBERT46055 wrote:I'm still using 6 but how do i get beater guilty out of a 3 hours 30 Minutes file its still on good tried enhance with programs on the 6 but still nothing trying best guilty on a DVD rip file :cry: :oops: :( sorry the file for the codec is beater then the dvd
The original file quality will always be better. Keep in mind that the resolution on the original file could be higher than that of the DVD specification of 720X576 or 720X480.
wtin
Project name bug 7.0.0.31
Post by wtin »
I created the video so you can see the steps
https://www.youtube.com/watch?v=Ip-UI3s ... e=youtu.be
Steps to reproduce:
Load some files. In this case, MP4 and ASS subtitle files. Obtained from Crunchyroll.com :-)
Choose basic menu ("10 titles per page without submenu")
Click on preview of the menu.
The title of the project shows the name of the first file.
Edit it.
Project name now changed.
Preview it. Shows original name.
Now is the way to get around this:
EDIT the menu.
Change the name in the editing screen.
Exit the editing screen.
Preview it. It now shows correct name.
The program renders the files beautifully. It is far superior to Nero Video, Cyberlink PowerDirector and everything else I have tried. :-p
felicia
Post by felicia »
@wtin: This issue is fixed in the next build
felicia
Post by felicia »
AtelierD wrote:Hello Team,
1. Should be fixed in the next build
2. Fixed in the next build
wtin
"do not create menu for single title"
Post by wtin »
It still does in 7.0031.
Thank you.
felicia
Re: "do not create menu for single title"
Post by felicia »
wtin wrote:It still does in 7.0031.
Thank you.
The option states "Don't create Title menu for single video", it still will create the other menus. If you don't want a menu select "No menu"
ira
Post by ira »
wtin wrote:Hi,
Wtin
I disagree! I have BRC for years, recently installed CXTD and CXTV and believe BRC and CXTD add a bit more for their single purpose than CXTV. I like all three products. Keep them all alive.
Ira
Re: CXD latest beta version 7.0.0.32
new 7.0.0.32 beta posted
