Re: CXD - Latest beta - 7.0.0.67 released!
It's working fine and automatically for me... mmh, what's exactly happening? when the timer get to 0 it starts again? (please send me an email to support@vsosoftware.fr, easier for me to help)
- VSO Fanatic
It stuck at that point and asks me to Insert The MediaMaggie wrote: Thu Oct 03, 2019 11:11 am It's working fine and automatically for me... mmh, what's exactly happening? when the timer get to 0 it starts again? (please send me an email to support@vsosoftware.fr, easier for me to help)
well what brand and type of discs are you using? Can you post the log so we can see the Disc/Media ID (DID/MID)?
Desktop: Project Phoenix
- VSO Fanatic
I don't Burn DVD, I just want to create ISO fileCh3vr0n wrote: Mon Oct 07, 2019 3:01 pm well what brand and type of discs are you using? Can you post the log so we can see the Disc/Media ID (DID/MID)?
- ConvertXtoDVD 7_crashlog.20191007.180118.704.log
- (8.15 KiB) Downloaded 1132 times
I think that this is where the problem lies:deadlyshadow wrote: Mon Oct 07, 2019 3:14 pmI don't Burn DVD, I just want to create ISO fileCh3vr0n wrote: Mon Oct 07, 2019 3:01 pm well what brand and type of discs are you using? Can you post the log so we can see the Disc/Media ID (DID/MID)?
18:03:10.091 Info [x] Burn result to disk / as ISO file in working folder.
The ISO is not being produced and the application tries to burn the conversion.
Since ISO media are being created without a hitch for us, we cannot help! We need to check on your machine, please send us an email to support@vsosoftware.fr. We'll organize a remote control session.
- VSO Fanatic
I prefer to use the previous version and wait till you or somebody else can reproduce this issueMaggie wrote: Tue Oct 08, 2019 11:24 am Since ISO media are being created without a hitch for us, we cannot help! We need to check on your machine, please send us an email to support@vsosoftware.fr. We'll organize a remote control session.
@ deadlyshadow
Make sure you follow this procedure:
1) DO NOT LOAD ANY MOVIE FILES.
2) Set settings as in picture. Click OK.
3) Load movie
4) Do a normal conversion. No need to insert a blank media disk.
5) Wait to see the message as in the bottom picture.
6) If no ISO file is produced, click on the refresh button at the top right (see bottom picture).
3) Load movie
- VSO Fanatic
Thank You, CoralCoral wrote: Wed Oct 09, 2019 5:10 am @ deadlyshadow
3) Load movie
I'm not a novice User
I've told before it doesn't start creating ISO file Automatically, If I Click on Refresh or Reselect "ISO Image in Working Folder" it creates ISO file
Yes, it happend to me once too. All I did was to ignore the "lncert Media" alert and just clicked refresh.deadlyshadow wrote: Mon Oct 07, 2019 2:23 pmIt stuck at that point and asks me to Insert The MediaMaggie wrote: Thu Oct 03, 2019 11:11 am It's working fine and automatically for me... mmh, what's exactly happening? when the timer get to 0 it starts again? (please send me an email to support@vsosoftware.fr, easier for me to help)
I don't know if that is a bug or intentional. But at the end the ISO file is produced.
- VSO Fanatic
ThanksCoral wrote: Wed Oct 09, 2019 2:03 pmYes, it happend to me once too. All I did was to ignore the "lncert Media" alert and just clicked refresh.deadlyshadow wrote: Mon Oct 07, 2019 2:23 pmIt stuck at that point and asks me to Insert The MediaMaggie wrote: Thu Oct 03, 2019 11:11 am It's working fine and automatically for me... mmh, what's exactly happening? when the timer get to 0 it starts again? (please send me an email to support@vsosoftware.fr, easier for me to help)
Unfortunately it happens every time for me
Was wondering why the word "custom" was changed to "personnaliser" when selecting various options like color changes?
@deadlyshadow
Will you be ok to do a remote control session?
@filmczy
Thanks for reporting this, could you please send us a screenshot?
I may be due to the update we've made on the translation tool. We'll correct it.
@filmczy
"Personnaliser" appears in the Template Editor. It is in all color changing options.
Thanks Coral (again!)
I've reported it: https://bugs.vso-software.fr/view.php?id=13769
I'm having this same issue. Also happens on 7.0.0.68. It no longer automatically creates the .iso file unless I press the refresh button. I even did a clean install of 7.0.0.68.deadlyshadow wrote: Wed Oct 09, 2019 2:36 pmThanksCoral wrote: Wed Oct 09, 2019 2:03 pmYes, it happend to me once too. All I did was to ignore the "lncert Media" alert and just clicked refresh.
So, here's the log file. ConvertX hangs at the point in the attached picture, repeating the "Insert media to continue". (Or whatever the message is.) I have to press the "refresh" button to get it to burn the .iso file. This only began with .68, though I was previously on .64.
- ConvertXtoDVD 7_crashlog.20191110.200930.018.log
- (9.13 KiB) Downloaded 1019 times
OK, so it seems I'm having the same issue on ConvertXtoHD 3.0.0.70.
Try and click on the disk icon on top at right.
- VSO Fanatic
Yes, It happens with both build 67 and 68OutbackJon wrote: Mon Nov 11, 2019 1:07 amI'm having this same issue. Also happens on 7.0.0.68. It no longer automatically creates the .iso file unless I press the refresh button. I even did a clean install of 7.0.0.68.deadlyshadow wrote: Wed Oct 09, 2019 2:36 pmThanksCoral wrote: Wed Oct 09, 2019 2:03 pm
