New VSO Blu-ray Converter Ultimate BETA version (1.4.0.8)
zebadee
Post by zebadee »
Hi :)
Marvellous that is two members had keys for Ultimate emailed to them.
While I wait.
Good job for me I am back at work.
Though I do not really understand.
Why GoldMembers can not generate their key for Ultimate.
Especially recent members.
Blu-ray Converter appears on hold..... :shock:
mrr19121970
Post by mrr19121970 »
Just bumping the thread as version 1008 is now available incase anyone else like me overlooked it. Download link in post #1
mrr19121970
mrr19121970 wrote:The preview shows subtitles even though they are turned off. They are also in the file that is saved. Profile PS3/720p & IPAD tested as not OK.
Update
Manually changing
Code: Select all
HKCU\Software\VSO\Blu-Ray Converter Ultimate\DefaultSubtitleTrackLCID
from 1033 to 0 is a workaround.
This appears to have been corrected in build 1008. Thanks.
Is it possible to auto ajust height? In mediacoder on iPAD this is standard. The resulting 1024x768 video is then adjsuted to fit the source if needed. My my case (in Salt) this means 1024x568 (ie no black bars to & bottom)
mrr19121970
I'm not 100% sure that selecting a PS3 quality should also leave the previous setting also in green?
The encoder profile selector display problem has been fixed in last version (1.0.0.9)
mrr19121970
There is a problem with subtitle selection. You select subtitle on 'source' (say no subtitle).
Issues
1) You select video profile and quality on 'settings', this reset subtitles back to English
2) During process, you stop and press 'previous step', this resets subtitles back to English
I'm not sure what the solution is, but maybe Audio and Subtitle settings belong in the 'settings' tab?
2nd Issue
In 'process', it says 8 cores are being used, but the 'time left' for a 2 hour film (720p profile) is over 5 hours. I'm sure on version 1006 it was faster.[/u] Update mencoder gives me 32fps with the same settings as BD Converter. BD Converter gives me 11pfs.
mrr19121970
Hi Cedric!
1100 is not good.
Code: Select all
2010-12-31 16:44:52	Important   	****************************************Conversion process : session end****************************************
2010-12-31 16:44:52	Info        	An error occured while converting
2010-12-31 16:44:51	Info        	Starting to encode THE_KARATE_KID.mp4 output file : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2010-12-31 16:44:51	Info        	Only one file to encode
2010-12-31 16:44:50	Important   	****************************************Conversion process : session start****************************************
2010-12-31 16:44:42	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-31 16:44:42	Info        	 Drive has IDE-ATAPI physical interface
2010-12-31 16:44:42	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-31 16:44:42	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-31 16:44:42	Info        	 Drive has Serial ATA physical interface
2010-12-31 16:44:42	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-31 16:44:41	Info        	7 Menu templates loaded.
2010-12-31 16:44:41	Info        	Available Memory : 21367 Mb.
2010-12-31 16:44:41	Info        	Total Memory : 24556 Mb.
2010-12-31 16:44:41	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-31 16:44:41	Info        	Available Virtual Memory : 1818 Mb.
2010-12-31 16:44:41	Info        	Total Virtual Memory : 2047 Mb.
2010-12-31 16:44:41	Info        	Memory Load  : 23%
2010-12-31 16:44:41	Info        	Available Physical Memory : 9367 Mb.
2010-12-31 16:44:41	Info        	Total Physical Memory : 12279 Mb.
2010-12-31 16:44:41	Info        	System default language : English (United Kingdom)
2010-12-31 16:44:41	Info        	User default language   : English (United Kingdom)
2010-12-31 16:44:41	Info        	Version : 1.1.0.0
2010-12-31 16:44:41	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-31 16:44:41	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-31 16:44:40	Info        	 Using Advanced SPTI interface
2010-12-31 16:44:40	----        	******************** Log session start 31-Dec 16:44:40.369 PID 5668********************
mrr19121970
Now using the new 1100, it too slow. Mencoder alone needed 1hour 55 mins.
Can you give me your MEncoder details like audio output format, H264 profile?
mrr19121970
Here are the settings I used in mediacoder:
Code: Select all
<xml>
<MediaCoderPrefs><node>Always</node><node>true</node><node>2</node><node>4799</node><node>E:\PS3_OUTPUT\</node><node>E:\MediaCoderWork\</node><node>MKVExtract</node><node>false</node><node>Original</node><node>HE-AAC</node><node>Nero Encoder</node><node>8210</node><node>Set PAR</node><node>1</node><node>1</node><node>Enabled</node><node>Disabled</node><node>plugins64/</node><node>plugins64/</node><node>.\codecs\lame64.exe</node><node>.\codecs\oggenc64.exe</node><node>500</node><node>256</node><node>MP4</node><node>Stereo</node><node>100</node><node>80</node><node>.\codecs\mp3sEncoder64.exe</node><node>.\codecs\mpcenc64.exe</node><node>.\codecs\enhAacPlusEnc64.exe</node><node>.\codecs\wavpack64.exe</node><node>.\codecs\wvunpack64.exe</node><node>.\codecs\flac64.exe</node><node>.\codecs\MACDll64.dll</node><node>.\codecs\ldecod64.exe</node><node>.\codecs\xvidcore64.dll</node><node>Main</node><node>31</node><node>3</node><node>Disabled</node><node>false</node><node>5000</node><node>2000</node><node>false</node><node>false</node><node>true</node><node>.\codecs\x264_64.exe</node><node>Main</node><node>31</node><node>.\codecs\cudaH264Enc64.exe</node><node>.\codecs\lencod64.exe</node><node>.\codecs\ffmpeg64\ffmpeg.exe</node><node>.\codecs\theora_encoder_64.exe</node><node>.\codecs\wmcodec64.exe</node><node>iPod</node><node>.\codecs\ffmpeg64\ffmpeg.exe</node><node>true</node><node>1280</node><node>720</node><node>Height</node><node>true</node><node>24000</node><node>1001</node><node>true</node></MediaCoderPrefs>
I think the only difference is the AAC is stero and a lower bitrate. I tried to match the VSO BD Convertor settings as best I could. (with 5.1 sound and 320kb/s FAAC.exe broke)
I worked around H264 MKV profiles today...
You will found 720p/1080p H264 profiles will fast settings, and 720p/1080p "HQ" profiles with high quality settings in last beta version (1.1.0.1)
Thank you.
MAX4
Re: VSO Blu-ray Converter ultimate beta (1.1.0.16)
Post by MAX4 »
Hi Cerdic
me gustaria que me enviases una llave de desbloqueo para poder probar y hacer prueblas
mi email es max4@ono.com
gracias de antemano
mrr19121970
Re: VSO Blu-ray Converter ultimate beta (1.1.0.17)
Neither Blu-Ray Ultimate or Blu-Ray to DVD work with Bambi. Both try to pick up the 1h 13m (4 chapter) extras as the main movie and not 00800.mpls (26 chapters).
AnyDVD_6.7.8.0_Info_S_BAMBI.zip
(455.55 KiB) Downloaded 668 times
Rich86
Post by Rich86 »
Similar issues . . .
"The Girl Who Kicked the Hornet's Nest" blu-ray - program doesn't even see or list main movie - it just lists the 8 1/2 minute collection of trailers.
I've never seen more than 1 available item listed for any source blu-ray. I thought the program could show all titles on the disc and let you choose which and how many you wanted on the output DVD? It only shows 1 available item - and it isn't necessarily the main movie.
Lastly - why do I get the same output regardless of what size I select for output? Specifically "Morning Glory" blu-ray results in a 2.5gb DVD movie output no matter what size I tell it and what MB/s rate it picks. And this is using "Best" for video quality. How can that be?
salov
Post by salov »
Nice Program - works fine for me :)
But a few issues are a bit annoying:
It should be possible to overwrite also the destination filename proposals before starting the process not only the project name. I have e.g. the Star Trek TOS BluRay Series, which I want to convert to my media server. The episodes are called all the same starting with the 2nd of the list (Bonusepisode).
It looks like:
STAR_TREK_S1D1 (Episode 1)
STAR_TREK_S1D1 (Bonusepisode)
So I can not select all episodes at once - otherwise they will be overwritten by the process. I have to rip episode-by-episode.
Also, it is a bit annoying to de-select the subtitles episode by episode and the language is always the first in the list (e.g. Dansk).
I tried to convert to low resolution xvid without size limit (576x324) which produces usually files with the size between 550 and 650 MB which is what I expected. But there are some files with a target size of > 700 MB and one with over 1 GB. But all episodes have the same length. This bandwidth of target size is a bit surprising.
It would also be nice to be able to extract the subtitles to be external (.srt) or switchable in the target file.
pedu
Re: VSO Blu-ray Converter ultimate beta (1.2.0.0)
Post by pedu »
Nice work VSO - this could be just what I was looking for. Hopefully the following features could be implemented before release (please)?
1) Option to select more than one audio stream from source
2) Option to keep original audio stream(s) (True HD, DTS-MA) instead of encoding to AC3/320Kb. This could be implemented by letting the user decide between the following options:
- Keep original (copy bitstream)
- Extract core audio stream (in case of True HD or DTS-MA)
- Encode to 448/640 Kbit/s AC3
What I am trying to say is that I would prefer to keep the original audio streams if possible:-)
I realize certain output containers are limited to one audio stream in AAC format BUT my main concern is MKV - and this container can handle just about any stream you throw at it. My Xtreamer Sidewinder and Netgear NEO550 both play MKV with 7.1 HD audio streams nicely.
Keep up the good work guys
1) You can select more than one audio/subtitle track if you select an mkv profile. Be sure in step 2 you selected an mkv profile and go back to step 1, you will see the audio/subtitle lists are checkable and you can select all the tracks you want.
FYI :
PS3, XBOX360 & Apple profiles : You can select only one audio and only one subtitle track (merged in video)
AVI profile : All audio streams can be selected, but you can select only one subtitle track (merged in video)
MKV profile : All audio streams can be selected, same for subtitle tracks (encoded as separate DVD Subtitle tracks)
2) for DVD output profile, the original audio streams must be reencoded to be DVD compliant (like Blu-ray audio tracks have too high bitrate) BUT for all others profile types, maybe I can check if the original audio track can be copied without reencoding...
Thank you for your feedback...
pedu
Post by pedu »
Hi cedric,
1) Thanks for clearing things out. Maybe it would be easier to understand if the user started by selecting his desired target profile container instead - but I can cope with going back to step 1 :-)
2) I understand the restrictions related to DVD output but afaik 448Kb/s is the limit for AC3 streams - not 320Kb/s. Anyway I might have got this wrong since I hardly ever need to convert to DVD anymore:-)
Anyway the ideal solution imho would be to copy the original HD audio tracks or let the user extract the core audio tracks from True HD and DTS-MA streams if preferred. EAC3to can do both btw (core audio extracted by using -core switch). My point is to avoid reincoding whenever possible. It saves CPU cycles and most importantly keeps audio fidelity as high as possible. If you reencode a 320Kb MP3 file to 192Kb the audio quality will degrade as well, right?
I think you got one killer app coming up. I think the quality of the CUDA accelerated H264 encodings are much better than the ones produced by DVDFab8, FreeMake Video Converter, PavTube ByteCopy and MediaCoder. Actually it's on par (or even better) with BadaBoom2 though maybe a little bit slower? Anyway I can't wait to buy a licence when the product gets released :-). This is one all-in-one tool I have been looking for in a loooong time.
Please let me know if I can be of any help to you. I'm no expert in regards to eac3to but I do know how to extract the original audio streams or the core audio from those streams.
Cheers,
Peter
zebadee
Re: New VSO Blu-ray Converter Ultimate BETA version (1.2.1.1
Post by zebadee »
Hi :)
Despite link title.
I get DVD Converter on install! :shock:
the link will be corrected soon, thanks for point that out.
