New beta version 1.5.0.11
Re: New beta version 1.5.0.9
what are you converting to?
what do you mean by widescreen?
Is there a conversion you have tried and you do not like the output result?
deathsatans
Re: New beta version 1.5.0.10
Post by deathsatans »
dear cedric...
from vso convertXtodvd until vso video converter, there is still a main bug :
- it can't read and decoded "♪ " text
can you solve this problem? thx
deathsatans
Claire wrote:what are you converting to?
my questions has been answered by the release of 1.5.0.10.
thank you. it may because of my bad english tehehe...
i like the output result, as i use pan and scan, but sadly it crop the left and right portion of the screen.
i now will try to use 1.5.0.10
deathsatans
Re: New beta version 1.5.0.11
why in v1.5.0.10 the DVD Menu screen getting worsed? the text is jaggy and the movie preview so bad?
igor_lvk
Post by igor_lvk »
Encoding to 60fps is fake. There's no such smoothness in resulting video. And BD format can't reach the size no matter 25 or 50 GB.
igor_lvk, I don't understand your last post. Are you commenting on the software or replying to someone?
What do you mean 60fps is fake?
The quality of the menus will be improved in the next beta, thanks for reporting.
deathsatans wrote:dear cedric...
Do you have a sample you can provide to us?
Is that symbol in the menu or part of a subtitle file?
igor_lvk
Post by igor_lvk »
Claire wrote:igor_lvk, I don't understand your last post. Are you commenting on the software or replying to someone?
I just try to convert a clip to 60fps with my manual profile and converter couldn't reach it.
Could not reach it? It is not speed of conversion.
It is frame rate of converted movie, NTSC interlaced.
igor_lvk
Post by igor_lvk »
No, JJ. I'm talking about conversion to 60fps custom preset.
Copnm
Post by Copnm »
Hello igor_lvk,
Just to be sure... You're referring to you converting a video file from X frame rate to 60 fps AKA duplicating frames, correct?
Thanks for reading,
Neil M
igor_lvk
Post by igor_lvk »
Oh, guys. It's no so hard to understand i think. I mean when i choose a 60fps preset to convert any video for example let it be in 24fps or 25fps the frame rate that mediaplayer shows in resulting file will be 60fps but it's only show that. There's no real 60fps video rate. The framerate will be the same like in original file. You can try to convert any video to 60fps by yourself. And i hope you'll see what i want to say.
deathsatans
[quote="Claire"][quote="deathsatans"]dear cedric...
can you solve this problem? thx[/quote]
Is that symbol in the menu or part of a subtitle file?[/quote]
thankyou for the reply about "The quality of the menus".
About "♪ " text, I will upload the pictures soon once i have found again a movies with that symbol.
The symbol is part of a subtitle file (srt).
thank you
deathsatans
just info...
i use 1.5.0.8 and it can't create bluray structure with DTS sound, although the source has it.
i am not use 1.5.0.11 as the menu preview disappointed me
btw, any plan to include 3D Half SBS dvd converter ability? Just wondering...:)
and no news about upcoming beta version?
