CXtoHD - Latest beta - 3.0.0.69 released!
Re: CXtoHD - v2.0.0.56 beta version
new beta posted
framura
Re: CXtoHD - v2.0.0.57 beta version
Post by framura »
I just tried Smart Copy but in my case it doesn't works.
I imported a .m2ts file from a blu-ray and I tried but video track is processed.
The input file is obviously compatible.
At this time, smart copy will only works with Blu-ray structure in input.
Can you try by loading your whole BD structure?
In next version I will add more checks to accept any format...
Can you post your log file?
framura
Post by framura »
Just tried to load directly a BD with load a disc or load from folder or load iso image: two problems
1) I get only one titleset (but on BD disc I have many .m2ts files, it's a TV series disc)
2) If I click on "convert", I get always reencoding video track of this titleset
I attached log file.
Thanks for your help
ConvertXtoHD 2_mainlog_.20160804.221715.311.log
(8.45 KiB) Downloaded 1337 times
Hello framura,
Where did you found this (not compliant) 25p Blu-ray?
Is it a 50Fps interlaced Blu-ray?
Can you retry by enabling "Allow 25p, 30p, 50p and 60p framerates (less compatible)" option?
framura
Post by framura »
Hi cedric,
yes, is a 1080i 50fps disc: is a disc from TV Series.
I think 50fps interlaced is BD compliant (many TV series are made in this way).
Update: I just try enabling above feature "Allow 25p, 30p, ...." and.....WORKS: no more processing. Great.
Now I will made a complete test and I will post my final results.
At this point I have just one another request: how to create a single settings menu (and not one for each titleset?)
Thanks for help and for your work.
Ok, in this case the problem is our source framerate detection...
Thank you for your feedback.
framura
Post by framura »
Just edited my previous post: WORKS with "Allow 25p, 30p...." feature
framura
Post by framura »
Hi cedric,
I just made the BD disc: something is wrong the playlist files (*.mpls file): I can't play main menu.
Singles stream files (.m2ts files) seems to be ok (audio, video, subtitles).
I also checked BD structure of final disc with BDEdit but when I choose Playplist TAB on BDEdit, BDEdit crashes.
During conversion I get "Encoding mode: remuxing (RAW copy)", so I think SmartCopy works correctly: am I right?
Thanks in advance
You're right, if you see RAW copy, that mean Smart copy is applied...
Can you please re-dowload then re-install last beta version then retry?
We will do more test/fixes on output structure with Smart copy on next week...
framura
Post by framura »
I redownloaded and reainstalled last beta version but when I try to convert I get an error:
Error Error while initializing file: 00000.m2ts
framura wrote:Hi,
During installation tick the last 3 boxes. This will do a clean installation. You will have to do yours settings again.
Kincaid
Re: CXtoHD - v2.0.0.61 beta version
Post by Kincaid »
- 0011915: [Suggestion] Clean lower and upper filters while installing to avoid burning problems (cedric) - resolved.
:shock: Please at least make this optional.
This suggestion is breaking other software which isn't helpful at all. :evil:
Ch3vr0n
Post by Ch3vr0n »
Couldn't agree more. That's just a bad idea. Especially with the rate of versions that are released. Cleaning that filter order is just a disaster. It will break other software, requiring them to be reinstalled, and constantly causing the need for reboots. Burning issues aren't caused by the filter list. It's a dead/dying drive and/or lousy quality blanks
That suggestion has MONSTROUS BAD IDEA written all over it and will cause nothing but problems for other software developers!
Desktop: Project Phoenix
Ok ok, reverted back... :shock:
Maikel
Re: CXtoHD - v2.0.0.65 beta version
Post by Maikel »
the disks cannot be played on a Samsumg BD Player HT-F4505/ZD.
On Sony BD Players, they play fine.
the disc is not recognized.
AVCHD - Optical Disc
Resolution 1080p
DVD9
Template: Cinema - Navigation with buttons
I've tried various versions, and got the same result
felicia
Post by felicia »
Maikel wrote:the disks cannot be played on a Samsumg BD Player HT-F4505/ZD.
Resolution 1080p
DVD9
Could you try using an USB key as output on the samsung player and tell me if it works.
Br,
Do by chance you have this setting checked?
Try without it
Maikel
Post by Maikel »
Claire wrote:Do by chance you have this setting checked?
Try without it
It is disabled.
The Remux option is disabled too
I'm gonna test with the option USB Disk, and give you the feedback
ROBERT46055
Re: CXtoHD - v2.0.0.78 beta version
Post by ROBERT46055 »
the convertxtohd you can't go next or skip a little bit its like this you half to go to main menu then highlight the one you want very annoying :mrgreen: :oops:
