ConvertXtoHD pre-release version v1.0.0.22
igor_lvk
Re: ConvertXtoHD alpha version v1.0.0.6
Post by igor_lvk »
Claire wrote:about this info in the log
[encoder][h264]: H.264 preset slower not found
I don't get this, and it seems you don't get it for every file converted either.
If you convert only Macarena.vob do you still get that info in the log?
Could you send us the file?
Hi, Claire. I've got it almost on every movie.
Here is an example
:std_log='C:\ProgramData\VSO\ConvertXtoHD\1\Log\ConvertXtoHD 1_mainlog_.20141007.180152.798.log'
:library=false
:app_name=ConvertXToHD.exe
:app_version=1.0.0.6
:most_recent=first
:event_header='{time} {type}'
:ShortDateFormat=dd mmm
:ShortTimeFormat=hh":"nn":"ss
:status=started
:group_indent=4
18:01:49.575 Info [ ] Loop playback
18:01:49.574 Info [ ] Play titles one after the other
18:01:49.572 Info [x] Don't create title menu for single video
18:01:49.571 Info [x] Return to title menu after titleset playback
18:01:49.569 Info [x] Skip root menu initially
18:01:49.568 Info [ ] Auto-start playback
18:01:49.566 Info Template: Minimal, the most simple menu, contains 1 page(s)
18:01:49.566 Group Blu-ray/AVCHD menu options
18:01:49.565 Info Output target size : Custom value (23000 MB)
18:01:49.564 Info Number of core(s) used for encoding : 2
18:01:49.562 Info Number of core(s) used for decoding : 2
18:01:49.561 Info [x] Use 2 pass encoding
18:01:49.560 Info [x] Use best video quality settings
18:01:49.558 Info [ ] Use hardware encoding (if possible)
18:01:49.557 Info [x] Use hardware decoding (if possible)
18:01:49.556 Info Max simultaneous conversions: 2
18:01:49.556 Group Advanced encoding options
18:01:49.901 Warning [encoder][h264]: H.264 preset slower not found
18:01:49.812 ------------ г==> [audio #3 - RAW copy]
L=[audio ac3 main audio 6 Ch., 48000 Hz, 384 Kbps]
г==> [audio #2 - ac3 audio, 48000Hz, 2 Ch., 192000 bps [un]]
L=[audio mp3 main audio 2 Ch., 44100 Hz, 224 Kbps]
г==> [video #1 - h264 video, 1920x1080, yuv420p, 16x9, 23,98Fps, 31120 Kbps [un]]
L=[video mpeg4 720x304 45:19 yuv420p, 23,98 fps, 0 Kbps]
Output file: C:\Users\Igor\Documents\ConvertXtoHD\Hick.2011.HDRip\BDMV\STREAM\00000.m2ts (Blu-ray structure)
Input file: D:\Архив Фильмов\Hick.2011.HDRip.avi
Video filters used:
- DeInterlace filter: FFmpeg
- Scale filter: . Fit method: (Padding: top: 76, bottom: 76, left: 0, right: 0. Cropping: top: 0, bottom: 0, left: 46, right: 46)
18:01:49.811 Info Chapters to generate: 20
18:01:49.554 Info Added in conversion queue list...
18:01:49.371 Group ******************** Titleset #1 - ~98 min. File: "Hick.2011.HDRip" -> 00000.m2ts - Blu-ray structure ********************|GK_TITLESET|
18:01:49.370 Info Encoding options: Short Projects
18:01:49.368 Info Target size: 22,46 Gb.
18:01:49.208 Info Log FFMpeg warnings and errors
18:01:49.207 ------------ ***************************************************Burn settings end****************************************************
18:01:49.206 Info Default speed selected: 4x
18:01:49.204 Info [ ] Delete vsomsl files after burn complete
18:01:49.204 Info [ ] Delete output folder after burn complete
18:01:49.203 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
18:01:49.202 Info SAO setting: Automatic
18:01:49.201 Info [ ] Burn result to disk / as ISO file in working folder
18:01:49.200 ------------ **************************************************Burn settings begin***************************************************
18:01:49.200 Group Conversion to "Encoding session started at 18:01:49: 1 titleset(s) to encode" started at 18:01:49: 1 sequence(s) to encode|GK_CONVERT_SESSION|
18:01:45.715 Info #1 Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x304 [PAR 1:1 DAR 45:19]
18:01:45.713 Group Video streams
18:01:45.714 Info #2 Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16p, 224 kb/s - Unspecified
18:01:45.713 Info #3 Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 6 channels, fltp, 384 kb/s - Unspecified
18:01:45.713 Group Audio streams
18:01:45.713 Group Added file: D:\Архив Фильмов\Hick.2011.HDRip.avi
18:01:45.435 Verbose FFmpeg Opening file D:\Архив Фильмов\Hick.2011.HDRip.avi
18:01:45.414 Group File loading events
tonyk
Post by tonyk »
the ConvertXtoHD alpha version v1.0.0.6 is extremely slow 21 hours to convert a bd25gb movie, knowing that i have an NVIDIA
Can you post a log file of a conversion that has started?
I received your email you sent to VSO Directly, I suggest we continue here on the forum.
igor_lvk
Post by igor_lvk »
When i'm not using best video option, in log i've got such string [encoder][h264]: H.264 preset superfast not found
And when i installed old Nvidia drivers, 337.88, with old way cuda supporting encoding process goes a little bit faster. I don't need to wait for 24 hours till conversion will be completed. But 2-pass not working at all with hardware optimisations...
Menu not creating too.
18:12:19.683 Info [ ] Loop playback
18:12:19.682 Info [ ] Play titles one after the other
18:12:19.680 Info [x] Don't create title menu for single video
18:12:19.679 Info [x] Return to title menu after titleset playback
18:12:19.677 Info [x] Skip root menu initially
18:12:19.676 Info [ ] Auto-start playback
18:12:19.674 Info Template: Minimal, the most simple menu, contains 1 page(s)
18:12:19.674 Group Blu-ray/AVCHD menu options
18:12:19.673 Info Output target size : Custom value (23000 MB)
18:12:19.672 Info Number of core(s) used for encoding : 2
18:12:19.670 Info Number of core(s) used for decoding : 2
18:12:19.669 Info [x] Use 2 pass encoding
18:12:19.668 Info [ ] Use best video quality settings
18:12:19.667 Info [ ] Use hardware encoding (if possible)
18:12:19.666 Info [x] Use hardware decoding (if possible)
18:12:19.664 Info Max simultaneous conversions: 2
18:12:19.664 Group Advanced encoding options
18:12:20.040 Warning [encoder][h264]: H.264 preset superfast not found
18:12:19.922 ------------ г==> [audio #3 - RAW copy]
Video filters used:
18:12:19.921 Info Chapters to generate: 20
18:12:19.663 Info Added in conversion queue list...
18:12:19.479 Group ******************** Titleset #1 - ~98 min. File: "Hick.2011.HDRip" -> 00000.m2ts - Blu-ray structure ********************|GK_TITLESET|
18:12:19.478 Info Encoding options: Short Projects
18:12:19.476 Info Target size: 22,46 Gb.
18:12:19.297 Info Log FFMpeg warnings and errors
18:12:19.295 ------------ ***************************************************Burn settings end****************************************************
18:12:19.294 Info Default speed selected: 4x
18:12:19.293 Info [ ] Delete vsomsl files after burn complete
18:12:19.292 Info [ ] Delete output folder after burn complete
18:12:19.292 Info [ ] Don't eject disc or open output folder in explorer, after burn complete
18:12:19.291 Info SAO setting: Automatic
18:12:19.290 Info [ ] Burn result to disk / as ISO file in working folder
18:12:19.289 ------------ **************************************************Burn settings begin***************************************************
18:12:19.289 Group Conversion to "Encoding session started at 18:12:19: 1 titleset(s) to encode" started at 18:12:19: 1 sequence(s) to encode|GK_CONVERT_SESSION|
18:12:13.913 Info #1 Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x304 [PAR 1:1 DAR 45:19]
18:12:13.911 Group Video streams
18:12:13.912 Info #2 Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16p, 224 kb/s - Unspecified
18:12:13.911 Info #3 Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 6 channels, fltp, 384 kb/s - Unspecified
18:12:13.911 Group Audio streams
18:12:13.911 Group Added file: D:\Архив Фильмов\Hick.2011.HDRip.avi
18:12:13.585 Verbose FFmpeg Opening file D:\Архив Фильмов\Hick.2011.HDRip.avi
18:12:13.479 Group File loading events
18:11:49.043 Info Menu templates loaded: 35
18:11:46.673 Info Total Physical Memory : 8190 Mb.
Available Physical Memory : 7043 Mb.
Memory Load : 14%
Available Virtual Memory : 1754 Mb.
Total Memory : 8188 Mb.
Available Memory : 6922 Mb.
18:11:46.672 Info Processor Intel(R) Core(TM)2 Duo CPU E8600 @ 3.33GHz with 2 core(s) CPU
Pipeline(s): 2 - parallelize up to 2
Supported instruction set: MMX,sse,sse2,sse3,ssse3 (slow),sse41
18:11:46.649 Info OS : Windows 7 (64 bits), Build 7601, service pack 1.0
file name : C:\Program Files (x86)\VSO\ConvertXtoHD\1\ConvertXToHD.exe
file version : 1.0.0.6
igor_lvk
Re: ConvertXtoHD alpha version v1.0.0.7
Post by igor_lvk »
2-pass not working at all. Program just hanging up as always. And menu not creating or displaying. It's just start playing.
igor_lvk
Re: ConvertXtoHD alpha version v1.0.0.8
Post by igor_lvk »
2-pass not working with hardware acceleration and menu still not creating. But cuda is working.
igor_lvk wrote:2-pass not working with hardware acceleration and menu still not creating. But cuda is working.
2 pass is not supported by hardware acceleration.
As for the menu problem we will publish a new beta that hopefully will correct the issue. We cannot reproduce it so it is hard for us to know for sure.
igor_lvk
Post by igor_lvk »
Hm? Why 2-pass not supported with Hardware acceleration? Then you have to do something about it. Maybe some information mast be mentioned when choosing 2-pass and HA.
And yet, looks like BD-sizes still can't be reached.
igor_lvk
Re: ConvertXtoHD alpha version v1.0.0.10
Post by igor_lvk »
Anyway, i've got error even after uninstall. It's happening when i'm saving settings, but cx2hd dosen't save them...
2-pass hangs up even without HA.
wadjda
Post by wadjda »
Hi, I switched to the new "beta" version, but every time I try to change the target size of the media in default settings I get access violation message come up, so I have switched back to the "Alpha" thank you.
renits
Post by renits »
I have the exact same access error since updating.
igor_lvk
Re: ConvertXtoHD alpha version v1.0.0.11
Post by igor_lvk »
After conversion CX2HD sits in program manager,and yet only dvd sizes are creating. No BD at all.
Got erros after closing. Just like in CX2dvd
igor_lvk
Re: ConvertXtoHD alpha version v1.0.0.12
Post by igor_lvk »
12th beta looks good. No errors but menu still not creating.
Re: ConvertXtoHD alpha version v1.0.0.13
Maybe will you have more chance with menu creation using 13th ;)
igor_lvk
Post by igor_lvk »
cedric wrote:Maybe will you have more chance with menu creation using 13th ;)
Sorry, Cedric but menu still not creating. It's only showing in CX2HD that menu is rendering at the end of encoding. And it starts playing from the second title not the first. Strange.
strikerfox
Post by strikerfox »
Enfin un bon produit, mais il reste encore un travail a faire sur le temps de la conversation ( vraiment tres lens, pour un film en mkv de 4.5 giga le program a commencer par
plu ou moins 9-10 eure de conversation.
salutation.
strikerfox
@igor_lvk: can you explain me exactly the steps to reproduce your problem? (menu template selected, menu options, titlesets count...)
@strikerfox: est-ce que votre ordinateur supporte les accélérations matérielles comme Nvidia CUDA ou Intel QuickSync?
Si vous ne savez pas ce que sont ces accélérations, pouvez-vous poster les références de votre carte graphique et de votre carte mère?
strikerfox
Et voila.
processor: intel i5
carte mere: DH55HC
VIDEO ADAPTOR; intel5(R) HD Graphics
disc drive intel SSD 240 GB
merci.
@strikerfox: Votre ordinateur doit donc supporter Intel QuickSync...
Pouvez-vous relancer une conversion en ayant les réglages "Permettre l'utilisation de plusieurs décodeurs matériels en même temps" et "Utiliser l'encodeur H264 matériel" cochées?
J'attends votre retour...
PS: vous êtes en train de poster sur le forum anglais, pouvez-vous utiliser le forum Français pour vos prochains posts:
http://forums.vso-software.fr/convertxtodvd-fr-f7.html
igor_lvk
Post by igor_lvk »
cedric wrote:@igor_lvk: can you explain me exactly the steps to reproduce your problem? (menu template selected, menu options, titlesets count...)
The steps? Just put 2 videoclips for example to CX2HD and hit convert. Template i always use is "Minimal, the most simple menu, contains 1 page". Mediaplayers are - MPC-HC and Daum Pot Player. After drag-n-drop in player video just playing with no menu at start as it should be.
And Your favorite VLC can't show menu too.
ConvertXtoHD 1_mainlog_.20141112.220131.229.log
(10.19 KiB) Downloaded 540 times
