BR/DVD Converter 4, new BETA version! 4.0.0.61
Re: BR/DVD Converter 4, new BETA version! 4.0.0.38
new beta posted
installed 4.0.0.38, found some problems:
Standard audio is not detected, it will always select all possible languages.
Audio is not manually selectable using an BD with episodes. I can select audio für the first one but trying the same on the others just opens explorer showing the BD content.
On .36 it crashed selecting audio on the second episode
Thanks I confirm the problemHarryHirsch wrote:Standard audio is not detected, it will always select all possible languages.
Can you tell me more of what you mean, and or post a screenshot? I cannot reproduce this issue, try if possible with 4.0.0.39.HarryHirsch wrote:Audio is not manually selectable using an BD with episodes. I can select audio für the first one but trying the same on the others just opens explorer showing the BD content.
Re: BR/DVD Converter 4, new BETA version! 4.0.0.43
Problem with audio tracks is now fixed in our new version 4.0.0.43
http://www.vso-software.fr/products/blu ... verter.php
Re: BR/DVD Converter 4, new BETA version! 4.0.0.47
There is a bug in the 4.0.0.47 version (and before).
One language will be detected wrong - I'm not sure but maybe it is Norwegian?
On the main windows you can see 2 German audio tracks but only the first is valid - as you can see on the "advanced edit" screen.
The 2nd audio track has the German flag - but no "[deu]" .. and finally isn't German.
I've this issue on Harry Potter BR's 1, 4, 5 (not on 2 + 3).
However - maybe it's not a bug but a bad mastering? Not important ...
MediaInfo, VLC and VSO Player show original timing of film and not the cutted version!
I've remuxed a BR into a MKV and cutted away the end of the film (with BR Converter 4.0.0.47). The original film is 1:56:27 long and cutted it's 1:51:14.
[*] See enclosed screen shot of JRiver Media Center which shows the correct timing 1:51:14 when I start the film.
[*] VLC and VSO Player show the wrong timing 1:56:27 at the right bottom and both finally stop at 1:51:14 (end-of-file).
Mediainfo shows this from the cutted film - all durations are 1:56 which is not true (is this a meta tag entry?).
For me it looks like the wrong final timing information will be written into the MKV files.
Hint: I've remuxed all Harry Potter 1-6 and cutted away the end and all show the correct timing. Video codec is VC-1. Then I did it with this new BR - not VC-1 codec - and have the wrong results.
Any idea?
Screen shot of JRiver Media Center which shows the correct timing (I think calculated?). UPDATE:
I've remuxed the edited into a M2TS - which shows 1:51:14 in MediaInfo. Then I've switched into the MKV profile and started again and then all entries in MediaPlayer also had 1:51:14. Mysterious that when I've started with MKV remux I've got the wrong timing. Have to retest tomorrow.
UPDATE 2:
Strange .. the 2nd time: I cutted another film at the end .. video runs until the cutted end but audio until the original end (5 minutes longer and video is black screen). Video in MediaInfo shows same length as audio. And funny VLC shows total running time 00:00 ? ... I'd the same problem yesterday and today again.
Code: Select all
General
Unique ID : 231264057398855164971243021428280578778 (0xADFBD65AA2CB91417268E01FBF44D2DA)
Complete name : x.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 27.4 GiB
Duration : 1 h 56 min
Overall bit rate : 33.6 Mb/s
Writing application : Lavf56.30.100
Writing library : Lavf56.30.100 / Lavf56.30.100
LABEL : Chapter 12
Language : eng
TCHAPTER : 258936672
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Maximum bit rate : 34.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 48.000 FPS
Original frame rate : 24.000 FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : h264 1920x1080 16/9
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Track/Position : 0
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 224 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -125 ms
Stream size : 187 MiB (1%)
Title : ac3 48000Hz 2Ch.
Language : German
Default : Yes
Forced : No
Track/Position : 1
Audio #2
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Codec ID : A_DTS
Bit rate mode : Variable / Constant
Bit rate : Unknown / 1 509 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Frame rate : 93.750 FPS (512 spf)
Bit depth : 16 bits
Compression mode : Lossless / Lossy
Title : dts 48000Hz 6Ch.
Language : German
Default : Yes
Forced : No
Track/Position : 2
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Title : hdmv_pgs_subtitle 1920x1080
Language : German
Default : Yes
Forced : No
Track/Position : 3
Menu
00:00:00.000 : :Chapter 1
00:08:54.375 : :Chapter 2
00:21:28.166 : :Chapter 3
00:29:33.250 : :Chapter 4
00:37:46.375 : :Chapter 5
00:48:02.916 : :Chapter 6
00:59:05.666 : :Chapter 7
01:08:06.250 : :Chapter 8
01:18:06.125 : :Chapter 9
01:28:41.958 : :Chapter 10
01:38:54.375 : :Chapter 11
01:51:05.875 : :Chapter 12
Any idea?
UPDATE 2:
Re: BR/DVD Converter 4, new BETA version! 4.0.0.53
new beta available
Re: BR/DVD Converter latest BETA version - 3.6.0.17
this problem should be fixed in our latest betadosibo51 wrote:With 3.6.0.16 (but I'm sure .17 will not fix the problem) ...
DVD Converter hangs up during analyzing the music DVD http://www.discogs.com/Frankie-Goes-To- ... se/1367384 ... Start button always greyed out (can't be clicked anymore - waited over 2 hours ...).
When in preferences / chapters / Create on titleset per chapters ... is enabled.
This only happens with this music DVD. I've tried another music DVD (from Falco) - works.
See screen shot enclosed
I hope this can be fixed ... maybe remote on my PC again on Monday late afternoon?
http://forums.vso-software.fr/dvd-conve ... 18563.html
Re: BR/DVD Converter 4, new BETA version! 4.0.0.56
When opening from the 'Files' menu - 'Load from Disk, Load from Blu-ray folder, Load from ISO File, or 'Exit' there is an extra yellow box that is displayed as well.
Also from Action/'Burn an already converted project' - After choosing the file the program crashes.
Blu-ray Video Converter has stopped working.
Problem signature:
Problem Event Name: APPCRASH
Application Name: BlurayConverterUltimate.exe
Application Version: 4.0.0.56
Application Timestamp: 5891c408
Fault Module Name: USER32.dll
Fault Module Version: 6.1.7601.23528
Fault Module Timestamp: 57b27eef
Exception Code: c0000005
Exception Offset: 00020d31
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: e2dd
Additional Information 2: e2dd7333d88899e1a2dfb42c71a9feac
Additional Information 3: a478
Additional Information 4: a4782ef71f218c18e69a11ebca53d638
Problem signature:
Locale ID: 1033
The yellow box hint will be fixed in the next version, but for the other problems you report here I cannot reproduce them.
I wonder if there is a problem with the output and therefore it doesn't load.
Can you convert a file (like only 2 minutes of it, by cutting out most of the movie in the advanced editor) and try again? Can you burn this conversion by going to Action/'Burn an already converted project'?
I made a short video file from the editor, however 'Burn an already converted project' didn't work from the file and crashed the program.
I then tried to convert a small selection to DVD and then try to use 'already converted...from a DVD/Blu-ray/AVCHD folder', but the conversion process stuck at 'Rendering Root Menu'.
thanks for testing, but it appears that the conversion of the small file doesnt even complete then it would be impossible for you to
use " 'already converted...from a DVD/Blu-ray/AVCHD folder' "
What if you do the conversion to avi format, and then use 'already converted...from a singer file',
or What if you do the conversion to DVD format, but before in the default (top) setttings for DVd output you select the menu type "no menu" ?
Do you see the burning window appear or not at all? I mean this one
Re: BR/DVD Converter 4, new BETA version! 4.0.0.57
That's what I meant that I was going to test from a DVD/Blu-ray/AVCHD, but the rendering process didn't finish. However, I have fixed the issue now.
I restored my computer from a system backup and that seemed to do it, no crashes. I tried with no menu and everything went fine and then with a menu and the rendering completes.
ok glad to hear it, thanks for reporting back.
The latest beta 4.0.0.57 only has 40,6 MB instead of 56,7 MB (4.0.0.52) - after installation I noticed that my preferred theme Autumnsky is not there anymore.
Have you removed a lot of themes?
My preferred visual theme was Snow Leopard. I use 'Elegant' now.dosibo51 wrote:The latest beta 4.0.0.57 only has 40,6 MB instead of 56,7 MB (4.0.0.52) - after installation I noticed that my preferred theme Autumnsky is not there anymore.
A lot of them are gone and maybe there were too many before (over 100). Now there are 9.
Re: BR/DVD Converter 4, new BETA version! 4.0.0.61
The latest beta BR Converter Ultimate 4.0.0.62. Unable to merge chapters when extracting episodes from series that have one large video file for all the episodes.
Settings/Chapters/Create one titleset per chapter when loading file = On
In main screen select files to merge/Right Click Menu (all are grayed out)
All other settings default.
new beta and new beta thread here
http://forums.vso-software.fr/dvd-br-co ... 19581.html
@Echuir I confirm you cannot merge this way, but I've tested in 4.0.0.5, 4.0.0.41 and 4.0.0.60 and it doesn't appear as an option in any of these but is in 4.0.0.62 of ConvertXtoVideo, so I'm wondering of it was simply not added to Blu-Ray Converter as maybe not possible.
In the change log I found it in ConvertXtoVideo but not in Blu-ray Converter change log
Allow user to merge all selected titles in same title (using right click)
new beta posted, fixing some issues posted here in this thread
