Feature Request: High Definition Audio for AC3 and DTS
scorpion90
Re: Feature Request: High Definition Audio for AC3 and DTS
Post by scorpion90 »
Hi Cedric,
Yes, yes, yes!!!! The audio remux is working (V1.4.0.22) for both my custom MKV remux profile and my custom Blu-ray 1080p profile. I had to use the built in MKV H264 profile to remux a blu-ray structure and used this output file to base my custom MKV H264 profile on and now it works great.
Many thanks for the improvements in audio remux capability!!!!!!!
The control of options for video remux is also very impressive! The Cuda hardware acceleration is running as high as 84%, very good.
Many thanks, a great product!
Tony
is PCM still not working in 1.5.0.0?
MyMojo
Post by MyMojo »
Claire wrote:is PCM still not working in 1.5.0.0?
Hi Claire,
Just tried again and it still crashes when remuxing PCM audio. I was using 1.5.0.2b
Also, I had 2-pass encoding enabled but the log shows that it's not.
Crash log attached:
VSO Video Converter 1_mainlog_.20140922.155250.526.log
(2.74 KiB) Downloaded 402 times
ok thanks very much, bug entered
http://bugs.vso-software.fr/view.php?id=8565
@MyMojo: "Also, I had 2-pass encoding enabled but the log shows that it's not": 2 pass encoding can't be used in remux mode, so disabled in log report...
MyMojo
Post by MyMojo »
Thanks Cedric. Makes sense about 2-pass, I didn't think of that...duh! :-)
bug fixed, see new official version
