ConvertXtoVideo - Latest beta - 2.0.0.97 released!
felicia
Re: ConvertXtoVideo - latest beta version 2.0.0.83
Post by felicia »
New beta posted
wtin
2.0.0.83 hard crash
Post by wtin »
https://www.youtube.com/watch?v=Vq2Re99taFA
Steps to produce.
1. Load a few files.
2. In this case, I use Playon to download these files. For my own use of course.
3. I want to chop off a few seconds of the beginning of each file and at the end.
4. Convert X to Video 2.0082 hard crashes when I move the slide thingie around. Please watch the video at Youtube above.
It actually has been happening for the last few versions. This bug is unpredictable. It doesn't happen all the time, but when it happens, I lose what ever has been edited (before saving).
The blue boxes were added to cover some personal info (IP address, etc.)
felicia
Re: 2.0.0.83 hard crash
Post by felicia »
wtin wrote:https://www.youtube.com/watch?v=Vq2Re99taFA
Steps to produce.
Thanks for the heads up. Will be fixed in next build.
mue.mat
Latest beta version 2.0.0.83 - Only remuxing (bug)
Post by mue.mat »
I'm using my own user settings for conversion.
But while configuring settings, I don't want copy (remux) video codec, so I don't tick the box.
But settings are automacially reset to copy (remux). But like that it's not possible to change video settings in enhanced menu.
Please fix it.
Thanks and kind regards
mue.mat
Picture 1.jpg (49.12 KiB) Viewed 94854 times
felicia
Re: Latest beta version 2.0.0.83 - Only remuxing (bug)
Post by felicia »
mue.mat wrote:Hi
Please fix it.
mue.mat
Please send bug report, I need the full profile and settings.
You need to launch a concersion that has the issue so I have all the data, the conversion does not need to fully complete.
BR,
Felicià
mue.mat
Re: ConvertXtoVideo - latest beta version 2.0.0.84
Post by mue.mat »
... new beta version works fine for me so far.
mue.mat
wtin
2.0.0.84 audio language
Post by wtin »
Program set to English audio. Loaded files and it shows "unspecified".
mue.mat
Post by mue.mat »
Yes, bug confirmed, if in enhanced settings audio AND subtitles language isn't recognized automatically and you put manually the correct language, settings "keep" audio AND subtitles "unspecified".
mue.mat
wtin
2.0.0.84 bit rate incorrect
Post by wtin »
I think this was carried over from a couple of versions ago.
Steps to reproduce.
Load program.
Load a file (or more than one file).
Change profile to, say, Blu ray 1080p.
Under bitrate, it should be much higher than 3 or 4 MB per second.
Change profile to DVD.
Change it back to BR 1080p.
It is now correct.
Note: I set my bit rate (under hardware) to the max of 30,000,000. (I know, I like it big!!)
But it no longer crashes at random when I move the bar thing around. I am happy with this. :D
Cronm
Post by Cronm »
mue.mat wrote:Yes, bug confirmed, if in enhanced settings audio AND subtitles language isn't recognized automatically and you put manually the correct language, settings "keep" audio AND subtitles "unspecified".
mue.mat
Same here with spanish...
dosibo51
Post by dosibo51 »
2.0.0.84 never remembers or selects "my" preferred languages - German / Deu in my case.
Default identifier in settings / conversion for audio & subtitle is also set to German.
felicia
Post by felicia »
dosibo51 wrote:2.0.0.84 never remembers or selects "my" preferred languages - German / Deu in my case.
Default identifier is only used when no language tag is found in the stream metadata
dosibo51
Post by dosibo51 »
Yes, but blu-ray converter ultimate remembers the languages I want for audio/subtitles - e.g. always German/deu in my case. CXV doesn't. Would be great to do the same here - maybe it was before and it's a new bug. I didn't use it for a longer time.
dosibo51
Post by dosibo51 »
CXV 2.0.0.84 shows 2 German with 1920x576 subtitle size but MediaInfo shows 1920x1080
Code: Select all
General
Unique ID                                : 127891816767014205742733149327966470282 (0x6037116585E262DCBD2FEA7C44BA008A)
Complete name                            : Der Herr Der Ringe 1 - Die Gefährten_(2001)_[FSK12]_[BR].mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 29.7 GiB
Duration                                 : 2 h 58 min
Overall bit rate                         : 23.8 Mb/s
Writing application                      : Lavf56.30.100
Writing library                          : Lavf56.30.100
LABEL                                    : Chapter 41
Language                                 : eng
TCHAPTER                                 : 201248000
Video
Format                                   : VC-1
Format profile                           : Advanced@L3
Codec ID                                 : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint                            : Microsoft
Bit rate                                 : 22.9 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 0.461
Stream size                              : 28.5 GiB (96%)
Default                                  : Yes
Forced                                   : No
Track/Position                           : 0
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Codec ID                                 : A_AC3
Bit rate mode                            : Constant
Bit rate                                 : 448 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Stream size                              : 572 MiB (2%)
Title                                    : ac3 48000Hz 6Ch.
Language                                 : German
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Track/Position                           : 1
Text #1
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Title                                    : hdmv_pgs_subtitle 1920x1080
Language                                 : German
Default                                  : Yes
Forced                                   : No
Track/Position                           : 2
Text #2
Format                                   : PGS
Language                                 : German
Default                                  : Yes
Forced                                   : No
Track/Position                           : 3
dosibo51
Post by dosibo51 »
Ooops, 2.0.0.84
see this - after converting no video in result file (file size 722 MB) .. and not the first time.
Source file:
Code: Select all
General
Unique ID                                : 113864130327241353387057821349890943901 (0x55A96F0EC1214738EFF23DE98C7AEB9D)
Complete name                            : Der Herr Der Ringe 2 - Die Zwei Türme_(2002)_[FSK12]_[BR].mkv
Format                                   : Matroska
File size                                : 29.1 GiB
Duration                                 : 2 h 59 min
Overall bit rate                         : 23.2 Mb/s
LABEL                                    : Chapter 54
Language                                 : eng
TCHAPTER                                 : 212303648
Video
Format                                   : VC-1
Bit rate                                 : 22.3 Mb/s
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.449
Stream size                              : 28.0 GiB (96%)
Default                                  : Yes
Forced                                   : No
Track/Position                           : 0
Audio
Format                                   : AC-3
Codec ID                                 : A_AC3
Bit rate                                 : 448 kb/s
Bit depth                                : 16 bits
Stream size                              : 575 MiB (2%)
Language                                 : German
Default                                  : Yes
Forced                                   : No
Track/Position                           : 1
Text #1
Format                                   : PGS
Language                                 : German
Default                                  : Yes
Forced                                   : No
Track/Position                           : 2
Text #2
Format                                   : PGS
Language                                 : German
Default                                  : Yes
Forced                                   : No
Track/Position                           : 3
Profile:
convert to H264 - max. 11.99 MB/s (less space on Linux SAT receiver for children), AC3
Code: Select all
---- Output profile informations ----
   * Custom profile name: M2TS (H264, AC3, RX)
   * File format (container): M2TS (Blu-ray)
   * File extension: m2ts
   * Output folder: L:\GRVD03\_Converted_
---- VIDEO track informations ----
Video stream will be encoded using these settings:
   * codec: H.264 (Generic)
   * framerate: Same as source (if compatible)
   * width: Same as source (if compatible)
   * height: Same as source (if compatible)
   * aspect ratio: Fit on destination
   * max bitrate: 11,99 Mb/s
---- AUDIO tracks informations ----
Audio streams will be encoded using these settings:
   * codec: AC3 (ATSC A/52A)
   * channels/bitrate: Same as source (if compatible)
   * samplerate: Same as source (if compatible)Hz
---- SUBTITLE tracks informations ----
If possible, subtitle streams will be copied (remuxed).
Otherwise, they will be encoded using these settings:
   * codec: Blu-ray Subtitle
deathsatans
Post by deathsatans »
Why i can't lauch version 2 anymore?
"Exception EConvertError in module vsoVideoConverter.exe at 00027926.
'_' is not a valid integer value.
I am using Windows 8.
Previous version of ConvertX is OK, which is 1.6.0.47
Roshi
Post by Roshi »
Good morning. I'd like to make a feature request. I remember to see in previous versions of CX2DVD, when the conversion ended, we had in the bottom the time that the conversion took. If we notice, there are three places were is shown the percentage of conversion and remaining time. Can we have that feature?
Thanks in advance,
Roshi.
felicia
Post by felicia »
Roshi wrote:Good morning. I'd like to make a feature request. I remember to see in previous versions of CX2DVD, when the conversion ended, we had in the botton the time that the conversion took. If we notice, there are three places were is shown the percentage of conversion and remaining time. Can we have that feature?
Thanks in advane,
Roshi.
As CxV can output mutiple files with each a diferent conversion time this information is not displayed in the main inteface, but can be retrieved in the log window
Roshi
Post by Roshi »
Thanks in advane,
Roshi.
I understand that, but that info could be shown even if multiple files with diferent conversion times were converted, what was going to be shown was the total spent time, not the time for each file...
felicia
Re: ConvertXtoVideo - latest beta version 2.0.0.85
Post by felicia »
New beta posted
