Audio out of sync
Audio out of sync
Well after many conversions and several burnt discs keep getting the same problem - audio is completely out of sync.
I have tried burning as both NTSC and PAL, all convert fine and play fine on the computer but as soon as you burn them to a disc and try them on a stand alone DVD player or even Blu Ray player the audio is completely out of sync. Both players can play either NTSC or PAL so that is not an issue.
I have tried burning the discs via Nero and ImageBurn - all result in out of sync films when played on standalone DVD players.
Any suggestions?
Any suggestions?
Just started a new conversion - all the same settings as before:
This is the log file that has been generated so far:
2010-11-15 12:46:50 Info Output Stream #4 (SUBTITLE) - dvdsub, 64 kb/s
2010-11-15 12:46:50 Info Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2010-11-15 12:46:50 Info Audio settings: Automatic With DTS -> AC-3 conversion
2010-11-15 12:46:50 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, 448 kb/s
2010-11-15 12:46:50 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=1-31, 3403 kb/s, pulldown: 23.976 -> 29.97 Fps
2010-11-15 12:46:50 Info Video processing: Lanczos (VSO) resampler (1920*1080)->(720*480) 4 threads
2010-11-15 12:46:50 Info 22 Stream(s) found - est. duration 02:30:50.208, reference 02:30:50.208
2010-11-15 12:46:50 Info Opening file "G:\MKV Files\Video\Armageddon Blu Ray\ARMAGEDDON_GBR\BDMV\PLAYLIST\00100.mpls"
2010-11-15 12:46:50 Info DVD encoding start
2010-11-15 12:46:22 Info Trial version
2010-11-15 12:46:10 Info 5 Menu templates loaded.
2010-11-15 12:46:09 Info Using Advanced SPTI interface
2010-11-15 12:46:08 ---- ******************** Log session start 2010-11-15 12:46:08.582 PID 6564********************
Using BlurayToDVDConverter verion 0.0.2.2 - currently running as Trial (evaluating before purchase)
Many thanks. eon
Many thanks. eon
The conversion has just completed:
This is the new log file:
2010-11-15 13:57:16 Info Convertion process completed successfully
2010-11-15 13:57:16 Info Rendering rate: 2.14 x Realtime
2010-11-15 13:57:16 Info DVD duration (incl. menus) 02:30:49 (~ 9049 sec.) - rendering time 01:10:26
2010-11-15 13:57:15 Info Generated duration 9049.37 sec., expected 9050.21 sec.
2010-11-15 13:57:15 Info 2576 subtitles frames encoded in subtitle stream #2
2010-11-15 13:57:15 Info 2311 subtitles frames encoded in subtitle stream #1
2010-11-15 13:57:15 Info 2 frames duplicated
2010-11-15 13:52:09 Info Chapter #12 start at 143:56.127
2010-11-15 13:44:04 Info Chapter #11 start at 125:21.514
2010-11-15 13:38:06 Info Chapter #10 start at 111:56.209
2010-11-15 13:29:16 Info Chapter #9 start at 92:43.057
2010-11-15 13:24:01 Info Chapter #8 start at 81:2.858
2010-11-15 13:17:40 Info Chapter #7 start at 67:15.531
2010-11-15 13:13:02 Info Chapter #6 start at 56:27.384
2010-11-15 13:07:34 Info Chapter #5 start at 45:56.253
2010-11-15 13:02:52 Info Chapter #4 start at 35:30.628
2010-11-15 12:57:32 Info Chapter #3 start at 23:14.893
2010-11-15 12:52:24 Info Chapter #2 start at 11:56.716
Please, can you try with last version :
Can you tell me if the film you're trying to convert is a multiversion type (like short & long version)?
Thank you.
Thank you.
If the converted project play fine on your computer (do you use VIDEO_TS.IFO file or do you play .VOB files separately?), it seems the problem is with the burn process or because the converted file structure is corrupted.
Before I add the function to clean the output folder before starting the procees in next version, can you delete the output folder manually before starting your test?
Maybe some old files (from partially converted project) are there and can cause these issues (because they are merged with new encoded files...)
We should try to reproduce by starting to convert, stopping the process then retry a complete process without cleaning the output folder...
Thank you for your tests
When playing from the computer I can select both the IFO file or the VOB files, they all play fine.
One thing I am going to try is using the burner within this software. Forgot to say that I was not burning to a disc from within the BluRay to DVD software. I have been using Nero and Imageburn instead. (I like to test the files on the hard drive before burning)
However, I will use the ultimate version and convert and burn directly within the software and get back to you.
I'll also use a completely different output folder in case there were some old files within.
Well did a couple of other tests: Using the Ultimate version did not make any difference - the end result was still out of sync.
Did another conversion using a different BluRay - This time used Daybreakers and Terminator Salvation - unfortunately again these were slightly out of sync. Although Terminator Salvation was very very close, no where near as bad as Armageddon?
I tried to let the Blu-Ray Converter software do the burning too, but then after reading this forum found that the burning part has not been implemented yet.
Previously I would use ClownBD to extract and combine the M2TS files into one file, I would then load this into ConvertXtoDVD and let that run. The end results would play ok on both the computer and a stand alone DVD player? Its a long and faffy way to do it, so really hope you can get this software working ok? Fingers crossed
The burn feature should be fixed in current version (0.0.2.4), please check the download link here :
Thank you.
Thank you.
