I must check/fix/improve all single file profiles for fututre version, but like we will launch Blu-ray to DVD software first, I'm working on DVD output profile at this time.
I will do a quick fix for your access violation in iPad profile for next release (0.0.2.5), and I will improve bitrate management (...and quality) in a future release.
To add a new isuue in our bug tracking system, select "Blu-ray converter Ultimate" in top right selector (after logging) then click on "Report issue". Fill all fields requested then click on "Submit report".
I have now entered it into your bug tracking software.
A few hints from a fellow developer regarding bug tracking.
I found it strange that Windows 7 profile was not available for selection since It is a popular OS. Also strange not to be able to select the build I am reporting the error on of the software.
See it as my 2 cents to make life easier regarding bug tracking and regression handling.
