I'm running Win7 64-bit. After checking the BD structure I get this error every time.
[/img]
Error message
Error message
- screen.png (248.09 KiB) Viewed 5317 times
error message
i did try this program free version first to see if it worked and it did
but you got the watermark and it was only able to choose one audio and
one subtitle it did convert perfectly so now when it got relesed i did buy it
now can i choose all audio and subtitles but when i hit next button to convert i get error message witch say list out off bounds and everything freeze log files follows: (PS it is the same file i try to convert)
2010-11-28 09:52:00 ---- ******************** Log session stop 28-nov 09:52:00.109 PID 784********************
2010-11-28 09:50:21 Info 7 Menu templates loaded.
2010-11-28 09:50:18 Info Available Memory : 4568 Mb.
2010-11-28 09:50:18 Info Total Memory : 4955 Mb.
2010-11-28 09:50:18 Info Available extended Virtual Memory : 0 Mb.
2010-11-28 09:50:18 Info Available Virtual Memory : 1936 Mb.
2010-11-28 09:50:18 Info Total Virtual Memory : 2047 Mb.
2010-11-28 09:50:18 Info Memory Load : 19%
2010-11-28 09:50:18 Info Available Physical Memory : 2476 Mb.
2010-11-28 09:50:18 Info Total Physical Memory : 3070 Mb.
2010-11-28 09:50:18 Info System default language : Svenska
2010-11-28 09:50:18 Info User default language : Svenska
2010-11-28 09:50:18 Info Version : 0.1.0.5
2010-11-28 09:50:18 Info ExeName : C:\Program\VSO\Blu-ray to DVD converter\BlurayToDVDConverter.exe
2010-11-28 09:50:18 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
2010-11-28 09:50:17 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-11-28 09:50:17 Info Drive has IDE-ATAPI physical interface
2010-11-28 09:50:17 Info New Drive selected : 0:0:0 - Optiarc DVD RW AD-7590A 1.41 [E] (Ide)
2010-11-28 09:50:17 Info Using Advanced SPTI interface
2010-11-28 09:50:17 ---- ******************** Log session start 28-nov 09:50:17.453 PID 784********************
Please, can you try with this new version:
http://oasis.vso-software.fr/Beta/Blura ... .0.0.0.exe
Thank you!
Thank you!
Wow!
That fixed my problem. I REALLY like the user interface on this program, it is super easy to use. I like the way that it remembers my last choices for subtitles, etc.
error message
That version worked for mee to did tried yesterday with the file
it worked really well. tomolo
