I am a bit confused re the quality of the results when converting from br to dvd9. I used The 300 & Sin City . I used Any Dvd HD to rip & clone to burn at 4 x. I checked the disc's with image burn and they come back with no errors . I have a new Panasonic 42" plasma & Panasonic blu ray player. The image when playing back on the telly is sharp and lip sync is
correct the colour is also good and it runs without any stutter this is on DL
disc's so not too squashed .But I get weird lines on some edges.I could post you a disc for you to have a look at if it helps..I suppose the words
Anti-aliasing & Moire come to mind... Using latest version..Progress does take a bit of time.
Video Quality
Hello Cedric,I got in touch with Panasonic they did not offer any help,they said if I have no problems with shop bought disc's then it must be a fault with the authoring process.......I use a media server called TWONKY that works via DLNA with the tv, if I load the vobs into this and view them on the screen they show without the wierd effects.So upscaling from the blu ray player could be causing the problem. I can't turn it off so I will probably stick with ripping DVD's burning them on DL9 and let the player upsacle.
Hibertgripper wrote:Hello Cedric,I got in touch with Panasonic they did not offer any help,they said if I have no problems with shop bought disc's then it must be a fault with the authoring process.......I use a media server called TWONKY that works via DLNA with the tv, if I load the vobs into this and view them on the screen they show without the wierd effects.So upscaling from the blu ray player could be causing the problem. I can't turn it off so I will probably stick with ripping DVD's burning them on DL9 and let the player upsacle.
You can limit settings.
On remote control
Press "Setup" button > Select "TV/Device" > Select "HDMI Connection" > Select "HDMI Format"
You should be able to select output from 576p/480p.
I don't know if you've already tried this.
It makes a marginal difference on my set up.
But then I am not having the same problem as you.
Thanks for the reply chaps.Looks like Russia got the World Cup.
Anyway the problem lies with ripped blu ray's it's like the player/tv upscales something that should not be upscaled :ie it's HD already.When I rip a DVD & burn to dvd5 or dvd9 it upscales and it looks great. I will have another look at the setting and try to drop it down,but if this is the answer I will stick with DVD'S for ripping and burning and buy/watch blu rays..I will have go at creating a 1080 AVI and putting it on a USB stick to do a test I think the player should play it.
Please, can you try the last beta version I’ve just published :
You should use the "HQ" stamped profiles (PS3 or mkv 720p & 1080p) to have best quality available!
I’m waiting for your feedback…
Thank you!
Thank you!
