HELP with blu ray converter
kenbra
Post by kenbra »
I DONE A BLU RAY AND IT DONT PLAY ONMY BLU RAY PLAYERS BUT IT WILL PLAY ON MY COMPUTER BUT IT IS A ZIP FILE I HAVE TO OPEN IT FIRST THEN IT WILL PLAY ON MY COMPUTER I NEED HELP HOWDO I POST MY LOG FILES OR ANY IDEAS I AM A NOOBY
SORRY I JUST NOTICED I HAVE CAP LOCK ON
i bought new burners twice because i did not think they were working i am useing 2 blu ray burners disc to disc
I don't know why you're talking about a ZIP file?
It seems you're trying to do a 1:1 copy, what about Blu-ray converter?
Thank you.
kenbra
Post by kenbra »
yes i am
i have a blu ray player it is a sonny and a sharp and i use windows 7 64
i dont know if that helps
how do i post a log i am new to this
The main purpose of Blu-ray converter is to convert a Blu-ray structure to other formats like DVD, AVI... (not Blu-ray format)
I don't know the file type you're trying to play with your Blu-ray home player, but if you use the Blu-ray converter output, that can't be Blu-ray structure...
kenbra
Post by kenbra »
cedric wrote:Hi,
i thout you can burn blu ray movie to a nother blu ray disc like disc to disc
If you wish to do BD to BD you can use any copying software that can burn BD media !
Of course with AnyDVD HD running in the background.
The BD blanks are so expensive, might as well go buy the original at the store and enjoy that :shock:
