VSO Blu-Ray To DVD Convertor (UK Blu-Ray 4.3.2.1.)
mrr19121970
Post by mrr19121970 »
I tried the same disk with 4.3.2.1. and VSO Blu-Ray to DVD convertor.
I will try Mencoder directly.
Code: Select all
2010-12-22 21:47:30	Info        	7 Menu templates loaded.
2010-12-22 21:47:29	Info        	Available Memory : 22365 Mb.
2010-12-22 21:47:29	Info        	Total Memory : 24556 Mb.
2010-12-22 21:47:29	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-22 21:47:29	Info        	Available Virtual Memory : 1817 Mb.
2010-12-22 21:47:29	Info        	Total Virtual Memory : 2047 Mb.
2010-12-22 21:47:29	Info        	Memory Load  : 15%
2010-12-22 21:47:29	Info        	Available Physical Memory : 10383 Mb.
2010-12-22 21:47:29	Info        	Total Physical Memory : 12279 Mb.
2010-12-22 21:47:29	Info        	System default language : English (United Kingdom)
2010-12-22 21:47:29	Info        	User default language   : English (United Kingdom)
2010-12-22 21:47:29	Info        	Version : 1.0.0.3
2010-12-22 21:47:29	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray to DVD converter\BlurayToDVDConverter.exe
2010-12-22 21:47:29	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-22 21:47:29	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-22 21:47:29	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 21:47:29	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 21:47:28	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-22 21:47:28	Info        	 Drive has Serial ATA physical interface
2010-12-22 21:47:28	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-22 21:47:28	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 21:47:28	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 21:47:28	Info        	 Using Advanced SPTI interface
2010-12-22 21:47:28	----        	******************** Log session start 22-Dec 21:47:28.734 PID 5924********************
2010-12-22 21:35:22	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-22 21:35:22	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 21:35:22	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 21:35:22	Info        	Conversion process completed successfully
2010-12-22 21:35:22	Info        	Rendering rate: 1.97 x Realtime
2010-12-22 21:35:22	Info        	DVD duration (incl. menus) 01:59:47 (~ 7187 sec.) - rendering time 01:00:52
2010-12-22 21:35:22	Info        	Generated duration 7187.28 sec., expected 7183.00 sec.
2010-12-22 21:34:39	Info        	2435 subtitles frames encoded in subtitle stream #2
2010-12-22 21:34:39	Info        	1576 subtitles frames encoded in subtitle stream #1
2010-12-22 21:34:39	Info        	P-SDT buffer Underflow 1 times, 285 bytes peak
2010-12-22 21:28:57	Info        	Chapter #10 start at 103:54.220
2010-12-22 21:22:04	Info        	Chapter #9 start at 91:13.960
2010-12-22 21:16:00	Info        	Chapter #8 start at 80:2.300
2010-12-22 21:10:03	Info        	Chapter #7 start at 68:39.120
2010-12-22 21:03:52	Info        	Chapter #6 start at 56:31.880
2010-12-22 20:58:07	Info        	Chapter #5 start at 45:31.220
2010-12-22 20:51:54	Info        	Chapter #4 start at 33:4.480
2010-12-22 20:46:28	Info        	Chapter #3 start at 21:59.320
2010-12-22 20:40:28	Info        	Chapter #2 start at 10:48.640
2010-12-22 20:34:29	Info        	Stream #2 - Audio sync at 53.33 ms: 52.38 ms added
2010-12-22 20:34:29	Info        	Output Stream #4 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-22 20:34:29	Info        	Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-22 20:34:29	Info        	Audio settings: Automatic With DTS -> AC-3 conversion
2010-12-22 20:34:29	Info        	Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, 448 kb/s
2010-12-22 20:34:29	Info        	Encoding English, AC3, 6 ch. with 8 threads
2010-12-22 20:34:29	Info        	Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=1-31, 4395 kb/s, pulldown: 23.976 -> 25.00 Fps
2010-12-22 20:34:29	Info        	Encoding MPEG-2 with 8 threads
2010-12-22 20:34:29	Info        	Decoding Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s with 8 threads
2010-12-22 20:34:29	Info        	Decoding Video: VC1 DMO, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 9311 kb/s with 8 threads
2010-12-22 20:34:29	Info        	Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 8 threads
2010-12-22 20:34:29	Info        	12 Stream(s) found - est. duration 01:56:42.996, reference 01:56:42.996
2010-12-22 20:34:29	Info        	Opening file "S:\BDMV\PLAYLIST\00026.mpls"
2010-12-22 20:34:28	Important   	****************************************Conversion process : session start****************************************
2010-12-22 20:34:28	Info        	Selected DVD menu template : Default, simple menu
2010-12-22 20:33:13	Info        	 No disc in drive.
2010-12-22 20:32:35	Info        	7 Menu templates loaded.
2010-12-22 20:32:35	Info        	Available Memory : 22020 Mb.
2010-12-22 20:32:35	Info        	Total Memory : 24556 Mb.
2010-12-22 20:32:35	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-22 20:32:35	Info        	Available Virtual Memory : 1817 Mb.
2010-12-22 20:32:35	Info        	Total Virtual Memory : 2047 Mb.
2010-12-22 20:32:35	Info        	Memory Load  : 17%
2010-12-22 20:32:35	Info        	Available Physical Memory : 10094 Mb.
2010-12-22 20:32:35	Info        	Total Physical Memory : 12279 Mb.
2010-12-22 20:32:35	Info        	System default language : English (United Kingdom)
2010-12-22 20:32:35	Info        	User default language   : English (United Kingdom)
2010-12-22 20:32:35	Info        	Version : 1.0.0.3
2010-12-22 20:32:35	Info        	ExeName : C:\Program Files (x86)\vso\Blu-ray to DVD converter\BlurayToDVDConverter.exe
2010-12-22 20:32:35	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-22 20:32:34	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-22 20:32:34	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 20:32:34	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 20:32:34	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-22 20:32:34	Info        	 Drive has Serial ATA physical interface
2010-12-22 20:32:34	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-22 20:32:34	Info        	 Using Advanced SPTI interface
2010-12-22 20:32:34	----        	******************** Log session start 22-Dec 20:32:34.020 PID 5200********************
2010-12-22 20:31:21	----        	******************** Log session stop  22-Dec 20:31:21.702 PID 2912********************
2010-12-22 20:31:21	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-22 20:31:21	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 20:31:21	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 20:31:20	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-22 20:31:20	Info        	 Drive has Serial ATA physical interface
2010-12-22 20:31:20	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-22 20:31:20	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 20:31:20	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 20:22:25	Info        	7 Menu templates loaded.
2010-12-22 20:22:24	Info        	Available Memory : 22086 Mb.
2010-12-22 20:22:24	Info        	Total Memory : 24556 Mb.
2010-12-22 20:22:24	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-22 20:22:24	Info        	Available Virtual Memory : 1819 Mb.
2010-12-22 20:22:24	Info        	Total Virtual Memory : 2047 Mb.
2010-12-22 20:22:24	Info        	Memory Load  : 17%
2010-12-22 20:22:24	Info        	Available Physical Memory : 10160 Mb.
2010-12-22 20:22:24	Info        	Total Physical Memory : 12279 Mb.
2010-12-22 20:22:24	Info        	System default language : English (United Kingdom)
2010-12-22 20:22:24	Info        	User default language   : English (United Kingdom)
2010-12-22 20:22:24	Info        	Version : 1.0.0.6
2010-12-22 20:22:24	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-22 20:22:24	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-22 20:22:24	Info        	 Using Advanced SPTI interface
2010-12-22 20:22:24	----        	******************** Log session start 22-Dec 20:22:24.232 PID 2912********************
2010-12-22 20:22:18	----        	******************** Log session stop  22-Dec 20:22:18.567 PID 3004********************
2010-12-22 20:22:15	Important   	****************************************Conversion process : session end****************************************
2010-12-22 20:22:13	Info        	Conversion process has been aborted by user
2010-12-22 20:15:55	Info        	Chapter #3 start at 21:59.320
2010-12-22 20:09:10	Info        	Chapter #2 start at 10:48.640
2010-12-22 20:03:28	Info        	Stream #2 - Audio sync at 53.33 ms: 52.38 ms added
2010-12-22 20:03:28	Info        	Output Stream #4 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-22 20:03:28	Info        	Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-22 20:03:28	Info        	Audio settings: AC-3, 5.1 Channels
2010-12-22 20:03:28	Info        	Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, 448 kb/s
2010-12-22 20:03:28	Info        	Encoding English, AC3, 6 ch. with 8 threads
2010-12-22 20:03:28	Info        	Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=1-31, 4395 kb/s, pulldown: 23.976 -> 25.00 Fps
2010-12-22 20:03:28	Info        	Encoding MPEG-2 with 8 threads
2010-12-22 20:03:28	Info        	Decoding Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s with 8 threads
2010-12-22 20:03:28	Info        	Decoding Video: VC1 DMO, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 9311 kb/s with 8 threads
2010-12-22 20:03:28	Info        	Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 8 threads
2010-12-22 20:03:28	Info        	12 Stream(s) found - est. duration 01:56:42.996, reference 01:56:42.996
2010-12-22 20:03:28	Info        	Opening file "S:\BDMV\PLAYLIST\00026.mpls"
2010-12-22 20:03:27	Important   	****************************************Conversion process : session start****************************************
2010-12-22 20:03:26	Info        	Selected DVD menu template : Default, simple menu
2010-12-22 19:50:09	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-22 19:50:09	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 19:50:09	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 19:50:09	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-22 19:50:09	Info        	 Drive has Serial ATA physical interface
2010-12-22 19:50:09	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-22 19:50:08	Info        	Trial version
2010-12-22 19:50:07	Info        	7 Menu templates loaded.
2010-12-22 19:50:07	Info        	Available Memory : 22009 Mb.
2010-12-22 19:50:07	Info        	Total Memory : 24556 Mb.
2010-12-22 19:50:07	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-22 19:50:07	Info        	Available Virtual Memory : 1819 Mb.
2010-12-22 19:50:07	Info        	Total Virtual Memory : 2047 Mb.
2010-12-22 19:50:07	Info        	Memory Load  : 22%
2010-12-22 19:50:07	Info        	Available Physical Memory : 9481 Mb.
2010-12-22 19:50:07	Info        	Total Physical Memory : 12279 Mb.
2010-12-22 19:50:07	Info        	System default language : English (United Kingdom)
2010-12-22 19:50:07	Info        	User default language   : English (United Kingdom)
2010-12-22 19:50:07	Info        	Version : 1.0.0.6
2010-12-22 19:50:07	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-22 19:50:07	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-22 19:50:06	Info        	 Using Advanced SPTI interface
2010-12-22 19:50:06	----        	******************** Log session start 22-Dec 19:50:06.386 PID 3004********************
2010-12-22 19:50:00	----        	******************** Log session stop  22-Dec 19:50:00.876 PID 3712********************
2010-12-22 19:46:27	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-22 19:46:27	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 19:46:27	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 19:46:27	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-22 19:46:27	Info        	 Drive has Serial ATA physical interface
2010-12-22 19:46:27	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-22 19:46:27	Info        	Trial version
2010-12-22 19:46:21	Info        	7 Menu templates loaded.
2010-12-22 19:46:20	Info        	Available Memory : 21613 Mb.
2010-12-22 19:46:20	Info        	Total Memory : 24556 Mb.
2010-12-22 19:46:20	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-22 19:46:20	Info        	Available Virtual Memory : 1819 Mb.
2010-12-22 19:46:20	Info        	Total Virtual Memory : 2047 Mb.
2010-12-22 19:46:20	Info        	Memory Load  : 20%
2010-12-22 19:46:20	Info        	Available Physical Memory : 9792 Mb.
2010-12-22 19:46:20	Info        	Total Physical Memory : 12279 Mb.
2010-12-22 19:46:20	Info        	System default language : English (United Kingdom)
2010-12-22 19:46:20	Info        	User default language   : English (United Kingdom)
2010-12-22 19:46:20	Info        	Version : 1.0.0.6
2010-12-22 19:46:20	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-22 19:46:20	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-22 19:46:19	Info        	 Using Advanced SPTI interface
2010-12-22 19:46:19	----        	******************** Log session start 22-Dec 19:46:19.132 PID 3712********************
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38534 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38529 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38524 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38519 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38514 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38510 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38505 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38500 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38495 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38490 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38485 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38480 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38464 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38403 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38384 - Skipped
2010-12-22 17:56:00	Error       	Exception [Out of memory] while reading packet #38266 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38144 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38136 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38081 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38070 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38049 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38039 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38029 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38026 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #38013 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37986 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37945 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37934 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37923 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37899 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37893 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37882 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37851 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37831 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37810 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37789 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37778 - Skipped
2010-12-22 17:55:59	Error       	Exception [Out of memory] while reading packet #37771 - Skipped
2010-12-22 17:55:58	Error       	Exception [Out of memory] while reading packet #37708 - Skipped
2010-12-22 17:55:58	Error       	Exception [Out of memory] while reading packet #37669 - Skipped
2010-12-22 17:55:58	Error       	Exception [Out of memory] while reading packet #37632 - Skipped
2010-12-22 17:55:58	Error       	Exception [Out of memory] while reading packet #37471 - Skipped
2010-12-22 17:55:57	Error       	Exception [Out of memory] while reading packet #37346 - Skipped
2010-12-22 17:55:57	Error       	Exception [Out of memory] while reading packet #37289 - Skipped
2010-12-22 17:55:57	Error       	Exception [Out of memory] while reading packet #37171 - Skipped
2010-12-22 17:55:57	Error       	Exception [Out of memory] while reading packet #37046 - Skipped
2010-12-22 17:55:57	Error       	Exception [Out of memory] while reading packet #36972 - Skipped
2010-12-22 17:55:56	Error       	Exception [Out of memory] while reading packet #36842 - Skipped
2010-12-22 17:55:56	Error       	Exception [Out of memory] while reading packet #36567 - Skipped
2010-12-22 17:55:55	Error       	Exception [Out of memory] while reading packet #36206 - Skipped
2010-12-22 17:55:55	Error       	Exception [Out of memory] while reading packet #36132 - Skipped
2010-12-22 17:55:54	Error       	Exception [Out of memory] while reading packet #36007 - Skipped
2010-12-22 17:55:54	Error       	Exception [Out of memory] while reading packet #35998 - Skipped
2010-12-22 17:55:54	Error       	Exception [Out of memory] while reading packet #35867 - Skipped
2010-12-22 17:55:54	Error       	Exception [Out of memory] while reading packet #35750 - Skipped
2010-12-22 17:55:53	Error       	Exception [Out of memory] while reading packet #35632 - Skipped
2010-12-22 17:55:53	Error       	Exception [Out of memory] while reading packet #35508 - Skipped
2010-12-22 17:55:53	Error       	Exception [Out of memory] while reading packet #35383 - Skipped
2010-12-22 17:55:52	Error       	Exception [Out of memory] while reading packet #35265 - Skipped
2010-12-22 17:55:52	Error       	Exception [Out of memory] while reading packet #35147 - Skipped
2010-12-22 17:55:52	Error       	Exception [Out of memory] while reading packet #35017 - Skipped
2010-12-22 17:55:52	Error       	Exception [Out of memory] while reading packet #34919 - Skipped
2010-12-22 17:55:51	Error       	Exception [Out of memory] while reading packet #34799 - Skipped
2010-12-22 17:55:51	Error       	Exception [Out of memory] while reading packet #34681 - Skipped
2010-12-22 17:55:50	Error       	Exception [Out of memory] while reading packet #34256 - Skipped
2010-12-22 17:55:50	Error       	Exception [Out of memory] while reading packet #34131 - Skipped
2010-12-22 17:55:50	Error       	Exception [Out of memory] while reading packet #34022 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33963 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33948 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33929 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33863 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33853 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33843 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33833 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33823 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33814 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33774 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33755 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33745 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33720 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33707 - Skipped
2010-12-22 17:55:49	Error       	Exception [Out of memory] while reading packet #33699 - Skipped
2010-12-22 17:55:48	Error       	Exception [Out of memory] while reading packet #33462 - Skipped
2010-12-22 17:55:48	Error       	Exception [Out of memory] while reading packet #33392 - Skipped
2010-12-22 17:55:48	Error       	Exception [Out of memory] while reading packet #33267 - Skipped
2010-12-22 17:55:47	Error       	Exception [Out of memory] while reading packet #32885 - Skipped
2010-12-22 17:55:46	Error       	Exception [Out of memory] while reading packet #32767 - Skipped
2010-12-22 17:55:46	Error       	Exception [Out of memory] while reading packet #32649 - Skipped
2010-12-22 17:55:46	Error       	Exception [Out of memory] while reading packet #32535 - Skipped
2010-12-22 17:55:45	Error       	Exception [Out of memory] while reading packet #32358 - Skipped
2010-12-22 17:55:45	Error       	Exception [Out of memory] while reading packet #32285 - Skipped
2010-12-22 17:55:44	Error       	Exception [Out of memory] while reading packet #31886 - Skipped
2010-12-22 17:55:44	Error       	Exception [Out of memory] while reading packet #31847 - Skipped
2010-12-22 17:55:44	Error       	Exception [Out of memory] while reading packet #31762 - Skipped
2010-12-22 17:55:44	Error       	Exception [Out of memory] while reading packet #31645 - Skipped
2010-12-22 17:55:44	Error       	Exception [Out of memory] while reading packet #31598 - Skipped
2010-12-22 17:55:43	Error       	Exception [Out of memory] while reading packet #31468 - Skipped
2010-12-22 17:55:43	Error       	Exception [Out of memory] while reading packet #31297 - Skipped
2010-12-22 17:55:43	Error       	Exception [Out of memory] while reading packet #31264 - Skipped
2010-12-22 17:55:43	Error       	Exception [Out of memory] while reading packet #31233 - Skipped
2010-12-22 17:55:43	Error       	Exception [Out of memory] while reading packet #31226 - Skipped
2010-12-22 17:55:42	Error       	Exception [Out of memory] while reading packet #31102 - Skipped
2010-12-22 17:55:42	Error       	Exception [Out of memory] while reading packet #31082 - Skipped
2010-12-22 17:55:42	Error       	Exception [Out of memory] while reading packet #31038 - Skipped
2010-12-22 17:55:42	Error       	Exception [Out of memory] while reading packet #31028 - Skipped
2010-12-22 17:55:42	Error       	Exception [Out of memory] while reading packet #30875 - Skipped
2010-12-22 17:55:42	Error       	Exception [Out of memory] while reading packet #30836 - Skipped
2010-12-22 17:55:41	Error       	Exception [Out of memory] while reading packet #30740 - Skipped
2010-12-22 17:55:41	Error       	Exception [Out of memory] while reading packet #30690 - Skipped
2010-12-22 17:55:41	Error       	Exception [Out of memory] while reading packet #30656 - Skipped
2010-12-22 17:55:41	Error       	Exception [Out of memory] while reading packet #30585 - Skipped
2010-12-22 17:55:40	Error       	Exception [Out of memory] while reading packet #30282 - Skipped
2010-12-22 17:55:40	Error       	Exception [Out of memory] while reading packet #30153 - Skipped
2010-12-22 17:55:39	Error       	Exception [Out of memory] while reading packet #29803 - Skipped
2010-12-22 17:55:39	Error       	Exception [Out of memory] while reading packet #29664 - Skipped
2010-12-22 17:55:39	Error       	Exception [Out of memory] while reading packet #29539 - Skipped
2010-12-22 17:55:38	Error       	Exception [Out of memory] while reading packet #29187 - Skipped
2010-12-22 17:55:36	Error       	Exception [Out of memory] while reading packet #28595 - Skipped
2010-12-22 17:55:35	Error       	Exception [Out of memory] while reading packet #27779 - Skipped
2010-12-22 17:55:33	Error       	Exception [Out of memory] while reading packet #27046 - Skipped
2010-12-22 17:55:33	Error       	Exception [Out of memory] while reading packet #26921 - Skipped
2010-12-22 17:55:33	Error       	Exception [Out of memory] while reading packet #26821 - Skipped
2010-12-22 17:55:32	Error       	Exception [Out of memory] while reading packet #26659 - Skipped
2010-12-22 17:55:32	Error       	Exception [Out of memory] while reading packet #26535 - Skipped
2010-12-22 17:55:30	Error       	Exception [Out of memory] while reading packet #25908 - Skipped
2010-12-22 17:55:30	Error       	Exception [Out of memory] while reading packet #25669 - Skipped
2010-12-22 17:55:30	Error       	Exception [Out of memory] while reading packet #25552 - Skipped
2010-12-22 17:55:29	Error       	Exception [Out of memory] while reading packet #25215 - Skipped
2010-12-22 17:55:29	Error       	Exception [Out of memory] while reading packet #25068 - Skipped
2010-12-22 17:55:28	Error       	Exception [Out of memory] while reading packet #24770 - Skipped
2010-12-22 17:55:28	Error       	Exception [Out of memory] while reading packet #24652 - Skipped
2010-12-22 17:55:28	Error       	Exception [Out of memory] while reading packet #24513 - Skipped
2010-12-22 17:55:27	Error       	Exception [Out of memory] while reading packet #24370 - Skipped
2010-12-22 17:55:27	Error       	Exception [Out of memory] while reading packet #24251 - Skipped
2010-12-22 17:55:27	Error       	Exception [Out of memory] while reading packet #24133 - Skipped
2010-12-22 17:55:27	Error       	Exception [Out of memory] while reading packet #24003 - Skipped
2010-12-22 17:55:27	Error       	Exception [Out of memory] while reading packet #23958 - Skipped
2010-12-22 17:55:26	Error       	Exception [Out of memory] while reading packet #23840 - Skipped
2010-12-22 17:55:24	Error       	Exception [Out of memory] while reading packet #22874 - Skipped
2010-12-22 17:55:24	Error       	Exception [Out of memory] while reading packet #22823 - Skipped
2010-12-22 17:55:24	Error       	Exception [Out of memory] while reading packet #22638 - Skipped
2010-12-22 17:55:23	Error       	Exception [Out of memory] while reading packet #22521 - Skipped
2010-12-22 17:55:23	Error       	Exception [Out of memory] while reading packet #22375 - Skipped
2010-12-22 17:55:23	Error       	Exception [Out of memory] while reading packet #22191 - Skipped
2010-12-22 17:55:22	Error       	Exception [Out of memory] while reading packet #22096 - Skipped
2010-12-22 17:55:22	Error       	Exception [Out of memory] while reading packet #22018 - Skipped
2010-12-22 17:55:22	Error       	Exception [Out of memory] while reading packet #21993 - Skipped
2010-12-22 17:55:22	Error       	Exception [Out of memory] while reading packet #21847 - Skipped
2010-12-22 17:55:22	Error       	Exception [Out of memory] while reading packet #21717 - Skipped
2010-12-22 17:55:21	Error       	Exception [Out of memory] while reading packet #21566 - Skipped
2010-12-22 17:55:20	Error       	Exception [Out of memory] while reading packet #21126 - Skipped
2010-12-22 17:55:20	Error       	Exception [Out of memory] while reading packet #21001 - Skipped
2010-12-22 17:55:19	Error       	Exception [Out of memory] while reading packet #20799 - Skipped
2010-12-22 17:55:18	Error       	Exception [Out of memory] while reading packet #20136 - Skipped
2010-12-22 17:55:17	Error       	Exception [Out of memory] while reading packet #19975 - Skipped
2010-12-22 17:55:17	Error       	Exception [Out of memory] while reading packet #19841 - Skipped
2010-12-22 17:55:17	Error       	Exception [Out of memory] while reading packet #19819 - Skipped
2010-12-22 17:55:17	Error       	This is the 25th audio discontinuity, turning off report of audio discontinuities
2010-12-22 17:55:17	Info        	Stream #2 - Audio sync at 152063.04 ms: 42.67 ms added
2010-12-22 17:55:17	Error       	Exception [Out of memory] while reading packet #19701 - Skipped
2010-12-22 17:55:17	Error       	Exception [Out of memory] while reading packet #19664 - Skipped
2010-12-22 17:55:16	Error       	Exception [Out of memory] while reading packet #19546 - Skipped
2010-12-22 17:55:16	Error       	Exception [Out of memory] while reading packet #19318 - Skipped
2010-12-22 17:55:16	Info        	Stream #2 - Audio sync at 148895.04 ms: 42.67 ms added
2010-12-22 17:55:16	Error       	Exception [Out of memory] while reading packet #19309 - Skipped
2010-12-22 17:55:16	Error       	Exception [Out of memory] while reading packet #19191 - Skipped
2010-12-22 17:55:15	Error       	Exception [Out of memory] while reading packet #19114 - Skipped
2010-12-22 17:55:15	Error       	Exception [Out of memory] while reading packet #18984 - Skipped
2010-12-22 17:55:15	Info        	Stream #2 - Audio sync at 145343.04 ms: 42.67 ms added
2010-12-22 17:55:15	Error       	Exception [Out of memory] while reading packet #18866 - Skipped
2010-12-22 17:55:15	Error       	Exception [Out of memory] while reading packet #18802 - Skipped
2010-12-22 17:55:14	Error       	Exception [Out of memory] while reading packet #18388 - Skipped
2010-12-22 17:55:13	Error       	Exception [Out of memory] while reading packet #18270 - Skipped
2010-12-22 17:55:13	Info        	Stream #2 - Audio sync at 139423.04 ms: 42.67 ms added
2010-12-22 17:55:13	Error       	Exception [Out of memory] while reading packet #18155 - Skipped
2010-12-22 17:55:12	Error       	Exception [Out of memory] while reading packet #17804 - Skipped
2010-12-22 17:55:12	Error       	Exception [Out of memory] while reading packet #17680 - Skipped
2010-12-22 17:55:12	Error       	Exception [Out of memory] while reading packet #17571 - Skipped
2010-12-22 17:55:11	Info        	Stream #2 - Audio sync at 133588.38 ms: 42.67 ms added
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17447 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17353 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17267 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17246 - Skipped
2010-12-22 17:55:11	Info        	Stream #2 - Audio sync at 131785.71 ms: 42.67 ms added
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17233 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17223 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17214 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17204 - Skipped
2010-12-22 17:55:11	Info        	Stream #2 - Audio sync at 131455.04 ms: 42.67 ms added
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17194 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17187 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17181 - Skipped
2010-12-22 17:55:11	Error       	Exception [Out of memory] while reading packet #17172 - Skipped
2010-12-22 17:55:10	Info        	Stream #2 - Audio sync at 130804.38 ms: 42.67 ms added
2010-12-22 17:55:10	Error       	Exception [Out of memory] while reading packet #17117 - Skipped
2010-12-22 17:55:10	Error       	Exception [Out of memory] while reading packet #17099 - Skipped
2010-12-22 17:55:10	Error       	Exception [Out of memory] while reading packet #17078 - Skipped
2010-12-22 17:55:10	Error       	Exception [Out of memory] while reading packet #17067 - Skipped
2010-12-22 17:55:10	Info        	Stream #2 - Audio sync at 130313.71 ms: 42.67 ms added
2010-12-22 17:55:10	Error       	Exception [Out of memory] while reading packet #17061 - Skipped
2010-12-22 17:55:10	Error       	Exception [Out of memory] while reading packet #17054 - Skipped
2010-12-22 17:55:09	Error       	Exception [Out of memory] while reading packet #16585 - Skipped
2010-12-22 17:55:08	Error       	Exception [Out of memory] while reading packet #16128 - Skipped
2010-12-22 17:55:07	Info        	Stream #2 - Audio sync at 121151.04 ms: 42.67 ms added
2010-12-22 17:55:07	Error       	Exception [Out of memory] while reading packet #15961 - Skipped
2010-12-22 17:55:07	Error       	Exception [Out of memory] while reading packet #15837 - Skipped
2010-12-22 17:55:07	Error       	Exception [Out of memory] while reading packet #15763 - Skipped
2010-12-22 17:55:07	Error       	Exception [Out of memory] while reading packet #15689 - Skipped
2010-12-22 17:55:07	Info        	Stream #2 - Audio sync at 118484.38 ms: 42.67 ms added
2010-12-22 17:55:07	Error       	Exception [Out of memory] while reading packet #15640 - Skipped
2010-12-22 17:55:07	Error       	Exception [Out of memory] while reading packet #15611 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15522 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15418 - Skipped
2010-12-22 17:55:06	Info        	Stream #2 - Audio sync at 116489.71 ms: 42.67 ms added
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15403 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15393 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15383 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15373 - Skipped
2010-12-22 17:55:06	Info        	Stream #2 - Audio sync at 116148.38 ms: 42.67 ms added
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15363 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15357 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15350 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15341 - Skipped
2010-12-22 17:55:06	Info        	Stream #2 - Audio sync at 114612.38 ms: 42.67 ms added
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15177 - Skipped
2010-12-22 17:55:06	Error       	Exception [Out of memory] while reading packet #15142 - Skipped
2010-12-22 17:55:05	Error       	Exception [Out of memory] while reading packet #15024 - Skipped
2010-12-22 17:55:05	Error       	Exception [Out of memory] while reading packet #14906 - Skipped
2010-12-22 17:55:05	Info        	Stream #2 - Audio sync at 111316.38 ms: 42.67 ms added
2010-12-22 17:55:05	Error       	Exception [Out of memory] while reading packet #14789 - Skipped
2010-12-22 17:55:04	Error       	Exception [Out of memory] while reading packet #14718 - Skipped
2010-12-22 17:55:04	Error       	Exception [Out of memory] while reading packet #14610 - Skipped
2010-12-22 17:55:04	Error       	Exception [Out of memory] while reading packet #14600 - Skipped
2010-12-22 17:55:04	Info        	Stream #2 - Audio sync at 109524.38 ms: 42.67 ms added
2010-12-22 17:55:04	Error       	Exception [Out of memory] while reading packet #14571 - Skipped
2010-12-22 17:55:04	Error       	Exception [Out of memory] while reading packet #14433 - Skipped
2010-12-22 17:55:03	Error       	Exception [Out of memory] while reading packet #14289 - Skipped
2010-12-22 17:55:03	Error       	Exception [Out of memory] while reading packet #14269 - Skipped
2010-12-22 17:55:03	Info        	Stream #2 - Audio sync at 106015.04 ms: 42.67 ms added
2010-12-22 17:55:03	Error       	Exception [Out of memory] while reading packet #14151 - Skipped
2010-12-22 17:55:03	Error       	Exception [Out of memory] while reading packet #14141 - Skipped
2010-12-22 17:55:03	Error       	Exception [Out of memory] while reading packet #14032 - Skipped
2010-12-22 17:55:03	Error       	Exception [Out of memory] while reading packet #13976 - Skipped
2010-12-22 17:55:02	Info        	Stream #2 - Audio sync at 104020.38 ms: 42.67 ms added
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13908 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13867 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13859 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13851 - Skipped
2010-12-22 17:55:02	Info        	Stream #2 - Audio sync at 103423.04 ms: 42.67 ms added
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13839 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13828 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13809 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13793 - Skipped
2010-12-22 17:55:02	Info        	Stream #2 - Audio sync at 102868.38 ms: 42.67 ms added
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13779 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13767 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13747 - Skipped
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13729 - Skipped
2010-12-22 17:55:02	Info        	Stream #2 - Audio sync at 102111.04 ms: 42.67 ms added
2010-12-22 17:55:02	Error       	Exception [Out of memory] while reading packet #13691 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13566 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13555 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13537 - Skipped
2010-12-22 17:55:01	Info        	Stream #2 - Audio sync at 100788.38 ms: 42.67 ms added
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13525 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13506 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13486 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13460 - Skipped
2010-12-22 17:55:01	Info        	Stream #2 - Audio sync at 100084.38 ms: 42.67 ms added
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13438 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13425 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13406 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13396 - Skipped
2010-12-22 17:55:01	Info        	Stream #2 - Audio sync at 99636.38 ms: 42.67 ms added
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13386 - Skipped
2010-12-22 17:55:01	Error       	Exception [Out of memory] while reading packet #13339 - Skipped
2010-12-22 17:55:00	Error       	Exception [Out of memory] while reading packet #13214 - Skipped
2010-12-22 17:55:00	Error       	Exception [Out of memory] while reading packet #13134 - Skipped
2010-12-22 17:54:59	Info        	Stream #2 - Audio sync at 96436.38 ms: 42.67 ms added
2010-12-22 17:54:59	Error       	Exception [Out of memory] while reading packet #12972 - Skipped
2010-12-22 17:54:59	Error       	Exception [Out of memory] while reading packet #12961 - Skipped
2010-12-22 17:54:59	Error       	Exception [Out of memory] while reading packet #12942 - Skipped
2010-12-22 17:54:59	Error       	Exception [Out of memory] while reading packet #12928 - Skipped
2010-12-22 17:54:59	Error       	Exception [Out of memory] while reading packet #12913 - Skipped
2010-12-22 17:54:59	Error       	Exception [Out of memory] while reading packet #12896 - Skipped
2010-12-22 17:54:20	Info        	Stream #2 - Audio sync at 53.33 ms: 52.38 ms added
2010-12-22 17:54:20	Info        	Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-22 17:54:20	Info        	Audio settings: AC-3, 5.1 Channels
2010-12-22 17:54:20	Info        	Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, 448 kb/s
2010-12-22 17:54:20	Info        	Encoding English, AC3, 6 ch. with 8 threads
2010-12-22 17:54:20	Info        	Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=1-31, 4395 kb/s, pulldown: 23.976 -> 25.00 Fps
2010-12-22 17:54:20	Info        	Encoding MPEG-2 with 8 threads
2010-12-22 17:54:20	Info        	Decoding Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s with 8 threads
2010-12-22 17:54:20	Info        	Decoding Video: VC1 DMO, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 9311 kb/s with 8 threads
2010-12-22 17:54:20	Info        	Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 8 threads
2010-12-22 17:54:20	Info        	12 Stream(s) found - est. duration 01:56:42.996, reference 01:56:42.996
2010-12-22 17:54:20	Info        	Opening file "S:\BDMV\PLAYLIST\00026.mpls"
2010-12-22 17:54:19	Important   	****************************************Conversion process : session start****************************************
2010-12-22 17:54:18	Info        	Selected DVD menu template : Default, simple menu
2010-12-22 17:44:04	Important   	****************************************Conversion process : session end****************************************
2010-12-22 17:26:41	Info        	An error occured while converting
2010-12-22 16:16:10	Info        	Starting to encode 4321_G51_SE.avi output file (1 video stream(s), 1 audio stream(s)
2010-12-22 16:16:10	Info        	Only one file to encode
2010-12-22 16:16:09	Important   	****************************************Conversion process : session start****************************************
2010-12-22 16:07:10	Info        	 No disc in drive.
2010-12-22 16:06:37	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-22 16:06:37	Info        	 Drive has IDE-ATAPI physical interface
2010-12-22 16:06:37	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-22 16:06:37	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-22 16:06:37	Info        	 Drive has Serial ATA physical interface
2010-12-22 16:06:37	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-22 16:06:36	Info        	Trial version
2010-12-22 16:05:48	Info        	7 Menu templates loaded.
2010-12-22 16:05:47	Info        	Available Memory : 21909 Mb.
2010-12-22 16:05:47	Info        	Total Memory : 24556 Mb.
2010-12-22 16:05:47	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-22 16:05:47	Info        	Available Virtual Memory : 1818 Mb.
2010-12-22 16:05:47	Info        	Total Virtual Memory : 2047 Mb.
2010-12-22 16:05:47	Info        	Memory Load  : 20%
2010-12-22 16:05:47	Info        	Available Physical Memory : 9703 Mb.
2010-12-22 16:05:47	Info        	Total Physical Memory : 12279 Mb.
2010-12-22 16:05:47	Info        	System default language : English (United Kingdom)
2010-12-22 16:05:47	Info        	User default language   : English (United Kingdom)
2010-12-22 16:05:47	Info        	Version : 1.0.0.6
2010-12-22 16:05:47	Info        	ExeName : C:\Program Files (x86)\vso\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-22 16:05:47	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-22 16:05:46	Info        	 Using Advanced SPTI interface
2010-12-22 16:05:46	----        	******************** Log session start 22-Dec 16:05:46.661 PID 5172********************
Stopped working
Stopped working
Your problem seems to be while encoding DVD menu...
Can you check your VOBs files please?
mrr19121970
Running this MENCODER now for you...
Code: Select all
@echo off
echo Convert To PAL DVD
REM These Are Constants
set PathToMencoder=J:\Downloaded\Video\MPlayer-Mencoder\mencoder_mt.exe
set PathToInput=S:\BDMV\STREAM\00036.m2ts
set PathToOutput=E:\4321.mpg
"%PathToMencoder%" -oac lavc -ovc lavc -of mpeg -mpegopts format=dvd:tsaf -vf scale=720:576,harddup -srate 48000 -af lavcresample=48000 -lavcopts vcodec=mpeg2video:vrc_buf_size=1835:vrc_maxrate=9416:vbitrate=4860:keyint=15:vstrict=0:acodec=ac3:abitrate=448:aspect=16/9:threads=8 -ofps 25 -o "%PathToOutput%" "%PathToInput%"
needs 2.5 hours
mrr19121970
VOBS 'look' OK
VOBS
VOBS
mrr19121970
I think the problem is the thumbnail generation in the chapter.
Code: Select all
00:00:00:000
00:04:51:624
00:10:48:564
00:16:31:991
00:21:59:067
00:28:04:349
00:33:04:232
00:39:13:893
00:45:30:978
00:51:00:515
00:56:31:513
01:03:07:408
01:08:39:031
01:14:55:073
01:20:01:922
01:25:42:804
01:31:13:843
01:36:24:111
01:43:53:936
01:49:15:048
01:49:15:048 is missing in the menu.
Also chapter 01:49:15:048 is not in the created VOB. The total film length is 01:56:42
Ok good work.
I will check the last DVD chapter generation
mrr19121970
Here is the AnyDVD log file incase you need the MPLS to look for the last chapter.
I'd also like to offer some suggestions on improving the software:
. Creating Menu: An option to edit menus before writing them to the destination folder. Possibly saving all meta data (audio options, chapter points and chapter thumbnails) extra so that a menu can be created after the VOBs have been created the menu can be completely replaced (even after the application has closed)
. Audio & subtitle selection: An 'advanced mode' showing all audio/subtitle streams including their PID that can be individually deselected
AnyDVD_6.7.6.0_Info_S_4321_G51_SE.zip
4321
(154.05 KiB) Downloaded 590 times
mrr19121970
1008 also fails
Code: Select all
2010-12-30 16:26:20	----        	******************** Log session stop  30-Dec 16:26:20.577 PID 2756********************
2010-12-30 16:26:10	Important   	****************************************Conversion process : session end****************************************
2010-12-30 16:26:10	Info        	An error occured while converting
2010-12-30 16:26:10	Info        	Output Stream #4 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-30 16:26:10	Info        	Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-30 16:26:10	Info        	Audio settings: AC-3, 5.1 Channels
2010-12-30 16:26:10	Info        	Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, 448 kb/s
2010-12-30 16:26:10	Info        	Encoding English, AC3, 6 ch. with 8 threads
2010-12-30 16:26:10	Info        	Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=1-31, 4335 kb/s, pulldown: 23.976 -> 25.00 Fps
2010-12-30 16:26:10	Info        	Encoding MPEG-2 with 8 threads
2010-12-30 16:26:10	Info        	Decoding Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s with 8 threads
2010-12-30 16:26:10	Info        	Decoding Video: VC1 DMO, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 9311 kb/s with 8 threads
2010-12-30 16:26:10	Info        	Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 8 threads
2010-12-30 16:26:09	Important   	****************************************Conversion process : session start****************************************
2010-12-30 16:26:09	Info        	Selected DVD menu template : Default, simple menu
2010-12-30 16:25:14	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-30 16:25:14	Info        	 Drive has IDE-ATAPI physical interface
2010-12-30 16:25:14	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-30 16:25:14	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-30 16:25:14	Info        	 Drive has Serial ATA physical interface
2010-12-30 16:25:14	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-30 16:25:13	Info        	7 Menu templates loaded.
2010-12-30 16:25:12	Info        	Available Memory : 22324 Mb.
2010-12-30 16:25:12	Info        	Total Memory : 24556 Mb.
2010-12-30 16:25:12	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-30 16:25:12	Info        	Available Virtual Memory : 1817 Mb.
2010-12-30 16:25:12	Info        	Total Virtual Memory : 2047 Mb.
2010-12-30 16:25:12	Info        	Memory Load  : 17%
2010-12-30 16:25:12	Info        	Available Physical Memory : 10153 Mb.
2010-12-30 16:25:12	Info        	Total Physical Memory : 12279 Mb.
2010-12-30 16:25:12	Info        	System default language : English (United Kingdom)
2010-12-30 16:25:12	Info        	User default language   : English (United Kingdom)
2010-12-30 16:25:12	Info        	Version : 1.0.0.8
2010-12-30 16:25:12	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-30 16:25:12	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-30 16:25:12	Info        	 Using Advanced SPTI interface
2010-12-30 16:25:12	----        	******************** Log session start 30-Dec 16:25:12.223 PID 2756********************
