Incorrect chapters generated
mrr19121970
Post by mrr19121970 »
Only 7 out of 13 chapters got generated.
Code: Select all
2010-12-24 13:11:35	Important   	****************************************Conversion process : session end****************************************
2010-12-24 13:11:35	Info        	Conversion process completed successfully
2010-12-24 13:11:35	Info        	Rendering rate: 1.16 x Realtime
2010-12-24 13:11:35	Info        	DVD duration (incl. menus) 01:38:59 (~ 5939 sec.) - rendering time 01:25:01
2010-12-24 13:11:35	Info        	Generated duration 5939.08 sec., expected 5934.04 sec.
2010-12-24 13:11:14	Info        	1257 subtitles frames encoded in subtitle stream #1
2010-12-24 13:11:14	Info        	P-SDT buffer Underflow 1 times, 285 bytes peak
2010-12-24 13:01:04	Info        	Chapter #7 start at 84:6.500
2010-12-24 12:45:23	Info        	Chapter #6 start at 66:45.500
2010-12-24 12:31:00	Info        	Chapter #5 start at 50:24.500
2010-12-24 12:21:12	Info        	Chapter #4 start at 39:24.500
2010-12-24 12:11:47	Info        	Chapter #3 start at 28:43.000
2010-12-24 11:57:45	Info        	Chapter #2 start at 13:9.000
2010-12-24 11:46:34	Info        	Stream #2 - Audio sync at 53.33 ms: 52.34 ms added
2010-12-24 11:46:34	Info        	Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-24 11:46:34	Info        	Audio settings: AC-3, 5.1 Channels
2010-12-24 11:46:34	Info        	Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, 448 kb/s
2010-12-24 11:46:34	Info        	Encoding English, AC3, 6 ch. with 8 threads
2010-12-24 11:46:34	Info        	Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=1-31, 5429 kb/s, pulldown: 24.000 -> 25.00 Fps
2010-12-24 11:46:34	Info        	Encoding MPEG-2 with 8 threads
2010-12-24 11:46:34	Info        	Decoding Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s with 8 threads
2010-12-24 11:46:34	Info        	Decoding Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 1399 kb/s with 8 threads
2010-12-24 11:46:34	Info        	Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 8 threads
2010-12-24 11:46:34	Info        	3 Stream(s) found - est. duration 01:37:50.042, reference 01:37:50.042
2010-12-24 11:46:34	Info        	Opening file "S:\BDMV\PLAYLIST\00000.mpls"
2010-12-24 11:46:33	Important   	****************************************Conversion process : session start****************************************
2010-12-24 11:46:33	Info        	Selected DVD menu template : Black Mirror (with chapter text)
2010-12-24 11:45:42	Important   	****************************************Conversion process : session end****************************************
2010-12-24 11:45:40	Info        	Conversion process has been aborted by user
2010-12-24 11:42:57	Info        	Stream #2 - Audio sync at 53.33 ms: 52.34 ms added
2010-12-24 11:42:57	Info        	Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2010-12-24 11:42:57	Info        	Audio settings: AC-3, 5.1 Channels
2010-12-24 11:42:57	Info        	Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, 448 kb/s
2010-12-24 11:42:57	Info        	Encoding English, AC3, 6 ch. with 8 threads
2010-12-24 11:42:57	Info        	Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=1-31, 5429 kb/s, pulldown: 24.000 -> 25.00 Fps
2010-12-24 11:42:57	Info        	Encoding MPEG-2 with 8 threads
2010-12-24 11:42:57	Info        	Decoding Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s with 8 threads
2010-12-24 11:42:57	Info        	Decoding Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 1399 kb/s with 8 threads
2010-12-24 11:42:57	Info        	Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 8 threads
2010-12-24 11:42:57	Info        	3 Stream(s) found - est. duration 01:37:50.042, reference 01:37:50.042
2010-12-24 11:42:57	Info        	Opening file "S:\BDMV\PLAYLIST\00000.mpls"
2010-12-24 11:42:56	Important   	****************************************Conversion process : session start****************************************
Here are the real chapters:
Code: Select all
00:00:00:000
00:06:08:875
00:13:08:541
00:19:55:375
00:28:43:000
00:39:24:458
00:50:24:458
00:59:09:416
01:06:45:208
01:13:59:250
01:24:06:416
01:32:52:000
01:37:49:833
AnyDVD_6.7.6.0_Info_S_WILD TARGET.zip
AnyDVD log so you can examine the MPLS
(117.07 KiB) Downloaded 467 times
mrr19121970
text deleted as not correct
Please, can you try the last beta version I’ve just published :
I’m waiting for your feedback…
Thank you!
mrr19121970
This seems to work now. Chapters are not exactly as BD on the generated DVD, but I assume as near to as possible.
Code: Select all
vso2010-12-30 10:32:53	Important   	****************************************Conversion process : session end****************************************
2010-12-30 10:32:22	Info        	Conversion process completed successfully
2010-12-30 10:32:22	Info        	Rendering rate: 1.36 x Realtime
2010-12-30 10:32:22	Info        	DVD duration (incl. menus) 01:48:09 (~ 6489 sec.) - rendering time 01:19:36
2010-12-30 10:32:17	Info        	Generated duration 6459.06 sec., expected 6454.36 sec.
2010-12-30 10:31:30	Info        	P-SDT buffer Underflow 1 times, 480 bytes peak
2010-12-30 10:31:30	Info        	1 frames duplicated
2010-12-30 10:25:02	Info        	Chapter #16 start at 95:53.240
2010-12-30 10:21:02	Info        	Chapter #15 start at 89:57.400
2010-12-30 10:15:51	Info        	Chapter #14 start at 83:16.000
2010-12-30 10:14:01	Info        	Stream #2 - Audio sync at 4852458.67 ms: 10.67 ms removed
2010-12-30 10:10:09	Info        	Chapter #13 start at 75:58.060
2010-12-30 10:07:09	Info        	Stream #2 - Audio sync at 4321066.67 ms: 10.67 ms removed
2010-12-30 10:05:23	Info        	Chapter #12 start at 69:44.180
2010-12-30 10:01:37	Info        	Chapter #11 start at 64:52.380
2010-12-30 09:57:39	Info        	Stream #2 - Audio sync at 3576266.67 ms: 10.67 ms removed
2010-12-30 09:56:22	Info        	Chapter #10 start at 57:54.480
2010-12-30 09:52:42	Info        	Stream #2 - Audio sync at 3189589.33 ms: 10.67 ms removed
2010-12-30 09:51:03	Info        	Chapter #9 start at 50:41.540
2010-12-30 09:47:10	Info        	Stream #2 - Audio sync at 2710570.67 ms: 10.67 ms removed
2010-12-30 09:46:49	Info        	Chapter #8 start at 44:44.180
2010-12-30 09:42:40	Info        	Stream #2 - Audio sync at 2363808.00 ms: 10.67 ms removed
2010-12-30 09:42:33	Info        	Chapter #7 start at 39:14.360
2010-12-30 09:37:44	Info        	Stream #2 - Audio sync at 1937845.33 ms: 10.67 ms removed
2010-12-30 09:37:43	Info        	Chapter #6 start at 32:15.940
2010-12-30 09:34:28	Info        	Stream #2 - Audio sync at 1683125.33 ms: 10.67 ms removed
2010-12-30 09:32:25	Info        	Chapter #5 start at 25:20.520
2010-12-30 09:27:20	Info        	Stream #2 - Audio sync at 1131616.00 ms: 10.67 ms removed
2010-12-30 09:26:07	Info        	Chapter #4 start at 17:13.040
2010-12-30 09:22:46	Info        	Stream #2 - Audio sync at 759786.67 ms: 10.67 ms removed
2010-12-30 09:20:59	Info        	Chapter #3 start at 10:24.620
2010-12-30 09:18:52	Info        	Chapter #2 start at 7:26.940
2010-12-30 09:12:45	Info        	Audio settings: AC-3, 5.1 Channels
2010-12-30 09:12:45	Info        	Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, 448 kb/s
2010-12-30 09:12:45	Info        	Encoding English, AC3, 6 ch. with 8 threads
2010-12-30 09:12:45	Info        	Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], q=1-31, 4943 kb/s, pulldown: 23.976 -> 25.00 Fps
2010-12-30 09:12:45	Info        	Encoding MPEG-2 with 8 threads
2010-12-30 09:12:45	Info        	Decoding Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s with 8 threads
2010-12-30 09:12:45	Info        	Decoding Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 46197 kb/s with 8 threads
2010-12-30 09:12:45	Info        	Video processing: Pad (Left:0 - Top:72 - Right:0 - Bottom:72)
2010-12-30 09:12:45	Info        	Video processing: Lanczos (VSO) resampler (1920*1080)->(720*432) 8 threads
2010-12-30 09:12:44	Important   	****************************************Conversion process : session start****************************************
2010-12-30 09:12:44	Info        	Selected DVD menu template : Default, simple menu
2010-12-30 09:11:07	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-30 09:11:07	Info        	 Drive has IDE-ATAPI physical interface
2010-12-30 09:11:07	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-30 09:11:06	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-30 09:11:06	Info        	 Drive has Serial ATA physical interface
2010-12-30 09:11:06	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-30 09:11:06	Info        	 Drive has IDE-ATAPI physical interface
2010-12-30 09:11:06	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-30 09:11:05	Info        	7 Menu templates loaded.
2010-12-30 09:11:04	Info        	Available Memory : 22276 Mb.
2010-12-30 09:11:04	Info        	Total Memory : 24556 Mb.
2010-12-30 09:11:04	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-30 09:11:04	Info        	Available Virtual Memory : 1817 Mb.
2010-12-30 09:11:04	Info        	Total Virtual Memory : 2047 Mb.
2010-12-30 09:11:04	Info        	Memory Load  : 17%
2010-12-30 09:11:04	Info        	Available Physical Memory : 10109 Mb.
2010-12-30 09:11:04	Info        	Total Physical Memory : 12279 Mb.
2010-12-30 09:11:04	Info        	System default language : English (United Kingdom)
2010-12-30 09:11:04	Info        	User default language   : English (United Kingdom)
2010-12-30 09:11:04	Info        	Version : 1.0.0.8
2010-12-30 09:11:04	Info        	ExeName : C:\Program Files (x86)\vso\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-30 09:11:04	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-30 09:11:03	Info        	 Using Advanced SPTI interface
2010-12-30 09:11:02	----        	******************** Log session start 30-Dec 09:11:02.795 PID 512********************
mrr19121970
One thing that needs 'attention' is the fact you can't edit the name of the title in the menu.
Similarly if there is only 1 title, then the titleset menu should be left out (or at least an option to leave out)
You can edit the title name in DVD menu by changing the "project name" in first step.
You can change each titleset name by editing them in video stream list (Step 1) by using F2 key.
If only one titleset is needed (one main movie), only the root menu is generated.
mrr19121970
OK, tried it an works. Context help would be nice ;)
