VSO Blu-Ray To DVD Convertor (German Blu-Ray Salt)
mrr19121970
Post by mrr19121970 »
Failled
Code: Select all
2010-12-24 19:48:52	----        	******************** Log session stop  24-Dec 19:48:52.176 PID 6924********************
2010-12-24 19:47:09	Important   	****************************************Conversion process : session end****************************************
2010-12-24 18:12:44	Info        	An error occured while converting
2010-12-24 17:43:04	Info        	Starting to encode SALT (Version 2).mp4 output file (1 video stream(s), 1 audio stream(s)
2010-12-24 17:43:04	Info        	Only one file to encode
2010-12-24 17:42:57	Warning     	Stream #2 (audio) - Codec tag "" unsupported
2010-12-24 17:42:57	Important   	****************************************Conversion process : session start****************************************
2010-12-24 17:42:30	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-24 17:42:30	Info        	 Drive has IDE-ATAPI physical interface
2010-12-24 17:42:30	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-24 17:42:30	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-24 17:42:30	Info        	 Drive has Serial ATA physical interface
2010-12-24 17:42:30	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-24 17:42:30	Info        	7 Menu templates loaded.
2010-12-24 17:42:29	Info        	Available Memory : 22149 Mb.
2010-12-24 17:42:29	Info        	Total Memory : 24556 Mb.
2010-12-24 17:42:29	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-24 17:42:29	Info        	Available Virtual Memory : 1819 Mb.
2010-12-24 17:42:29	Info        	Total Virtual Memory : 2047 Mb.
2010-12-24 17:42:29	Info        	Memory Load  : 18%
2010-12-24 17:42:29	Info        	Available Physical Memory : 10017 Mb.
2010-12-24 17:42:29	Info        	Total Physical Memory : 12279 Mb.
2010-12-24 17:42:29	Info        	System default language : English (United Kingdom)
2010-12-24 17:42:29	Info        	User default language   : English (United Kingdom)
2010-12-24 17:42:29	Info        	Version : 1.0.0.6
2010-12-24 17:42:29	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-24 17:42:29	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-24 17:42:28	Info        	 Using Advanced SPTI interface
2010-12-24 17:42:28	----        	******************** Log session start 24-Dec 17:42:28.820 PID 6924********************
mrr19121970
Here's the LOG file from AnyDVD so you can see the structure. It also fails trying to make an 1080p MKV too. Same error.
AnyDVD_6.7.6.0_Info_S_SALT.zip
ANYDVD log
(249.11 KiB) Downloaded 481 times
Please, can you try the last beta version I’ve just published :
I’m waiting for your feedback…
Thank you!
mrr19121970
I'm assuming this is fixed. See here
http://forums.vso-software.fr/incorrect ... 13288.html
running 1 last test through in iPAD mode. Will post result in 1hour 35 mins.
mrr19121970
All OK, bug fixed. Thanks.
Code: Select all
2010-12-30 16:22:07	----        	******************** Log session stop  30-Dec 16:22:07.709 PID 4520********************
2010-12-30 16:04:36	Important   	****************************************Conversion process : session end****************************************
2010-12-30 16:04:36	Info        	Conversion process completed successfully
2010-12-30 14:31:15	Info        	Starting to encode SALT (Version 2).mp4 output file : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2010-12-30 14:31:15	Info        	Only one file to encode
2010-12-30 14:31:14	Important   	****************************************Conversion process : session start****************************************
2010-12-30 14:30:30	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-30 14:30:30	Info        	 Drive has IDE-ATAPI physical interface
2010-12-30 14:30:30	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-30 14:30:29	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-30 14:30:29	Info        	 Drive has Serial ATA physical interface
2010-12-30 14:30:29	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-30 14:30:29	Info        	 Drive has IDE-ATAPI physical interface
2010-12-30 14:30:29	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-30 14:30:29	Info        	7 Menu templates loaded.
2010-12-30 14:30:28	Info        	Available Memory : 21935 Mb.
2010-12-30 14:30:28	Info        	Total Memory : 24556 Mb.
2010-12-30 14:30:28	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-30 14:30:28	Info        	Available Virtual Memory : 1816 Mb.
2010-12-30 14:30:28	Info        	Total Virtual Memory : 2047 Mb.
2010-12-30 14:30:28	Info        	Memory Load  : 20%
2010-12-30 14:30:28	Info        	Available Physical Memory : 9724 Mb.
2010-12-30 14:30:28	Info        	Total Physical Memory : 12279 Mb.
2010-12-30 14:30:28	Info        	System default language : English (United Kingdom)
2010-12-30 14:30:28	Info        	User default language   : English (United Kingdom)
2010-12-30 14:30:28	Info        	Version : 1.0.0.8
2010-12-30 14:30:28	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-30 14:30:28	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-30 14:30:28	Info        	 Using Advanced SPTI interface
2010-12-30 14:30:27	----        	******************** Log session start 30-Dec 14:30:27.940 PID 4520********************
