VSO Blu-Ray To DVD Convertor (UK Blu-Ray Karate Kid 2010)
mrr19121970
Post by mrr19121970 »
Way on, wax off. Don't work.
Code: Select all
2010-12-24 21:34:21	----        	******************** Log session stop  24-Dec 21:34:21.589 PID 5684********************
2010-12-24 21:34:02	Important   	****************************************Conversion process : session end****************************************
2010-12-24 21:04:36	Info        	An error occured while converting
2010-12-24 19:51:23	Info        	Starting to encode THE_KARATE_KID.mp4 output file (1 video stream(s), 1 audio stream(s)
2010-12-24 19:51:23	Info        	Only one file to encode
2010-12-24 19:51:22	Important   	****************************************Conversion process : session start****************************************
2010-12-24 19:51:02	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-24 19:51:02	Info        	 Drive has IDE-ATAPI physical interface
2010-12-24 19:51:02	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-24 19:51:02	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-24 19:51:02	Info        	 Drive has Serial ATA physical interface
2010-12-24 19:51:02	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-24 19:51:02	Info        	7 Menu templates loaded.
2010-12-24 19:51:01	Info        	Available Memory : 22148 Mb.
2010-12-24 19:51:01	Info        	Total Memory : 24556 Mb.
2010-12-24 19:51:01	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-24 19:51:01	Info        	Available Virtual Memory : 1819 Mb.
2010-12-24 19:51:01	Info        	Total Virtual Memory : 2047 Mb.
2010-12-24 19:51:01	Info        	Memory Load  : 18%
2010-12-24 19:51:01	Info        	Available Physical Memory : 10012 Mb.
2010-12-24 19:51:01	Info        	Total Physical Memory : 12279 Mb.
2010-12-24 19:51:01	Info        	System default language : English (United Kingdom)
2010-12-24 19:51:01	Info        	User default language   : English (United Kingdom)
2010-12-24 19:51:01	Info        	Version : 1.0.0.6
2010-12-24 19:51:01	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-24 19:51:01	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-24 19:51:00	Info        	 Using Advanced SPTI interface
2010-12-24 19:51:00	----        	******************** Log session start 24-Dec 19:51:00.810 PID 5684********************
AnyDVD_6.7.6.0_Info_S_THE_KARATE_KID.zip
For you to see the BDMV structure
(286.66 KiB) Downloaded 675 times
mrr19121970
Resolved with 1008. I've noticed that the file blur_ray_Converter_crash_PIDxxxx.log does not get deleted when the program automatically powers down at end of encoding.
Code: Select all
2010-12-30 18:39:53	Important   	****************************************Conversion process : session end****************************************
2010-12-30 18:39:22	Info        	Conversion process completed successfully
2010-12-30 16:33:41	Info        	Starting to encode THE_KARATE_KID.mp4 output file : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2010-12-30 16:33:41	Info        	Only one file to encode
2010-12-30 16:33:40	Important   	****************************************Conversion process : session start****************************************
2010-12-30 16:32:28	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2010-12-30 16:32:28	Info        	 Drive has IDE-ATAPI physical interface
2010-12-30 16:32:28	Info        	 New Drive selected : 3:1:0 - HL-DT-ST DVDRAM GH22NS40 NL02 [L] (Ide)
2010-12-30 16:32:28	Info        	 Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2010-12-30 16:32:28	Info        	 Drive has Serial ATA physical interface
2010-12-30 16:32:28	Info        	 New Drive selected : 2:1:0 - HL-DT-ST BD-RE  BH10LS30 1.00 [M] (Ide)
2010-12-30 16:32:27	Info        	7 Menu templates loaded.
2010-12-30 16:32:26	Info        	Available Memory : 22307 Mb.
2010-12-30 16:32:26	Info        	Total Memory : 24556 Mb.
2010-12-30 16:32:26	Info        	Available extended Virtual Memory : 0 Mb.
2010-12-30 16:32:26	Info        	Available Virtual Memory : 1817 Mb.
2010-12-30 16:32:26	Info        	Total Virtual Memory : 2047 Mb.
2010-12-30 16:32:26	Info        	Memory Load  : 17%
2010-12-30 16:32:26	Info        	Available Physical Memory : 10123 Mb.
2010-12-30 16:32:26	Info        	Total Physical Memory : 12279 Mb.
2010-12-30 16:32:26	Info        	System default language : English (United Kingdom)
2010-12-30 16:32:26	Info        	User default language   : English (United Kingdom)
2010-12-30 16:32:26	Info        	Version : 1.0.0.8
2010-12-30 16:32:26	Info        	ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2010-12-30 16:32:26	Info        	OS : Microsoft Windows 7 Ultimate (Build 7600)
2010-12-30 16:32:26	Info        	 Using Advanced SPTI interface
2010-12-30 16:32:26	----        	******************** Log session start 30-Dec 16:32:26.216 PID 2044********************
mrr19121970
I selected a 720p PS3 file as output to fit onto a DVD-9. The resulting file was 9.77gb in length (ie too long) with NO AUDIO
This is what mediainfo says (but there is only silence)
Code: Select all
General
Complete name                    : E:\VSO_BD_CONVERTER\THE_KARATE_KID\Playstation 3\720p\THE_KARATE_KID.mp4
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 9.77 GiB
Duration                         : 2h 20mn
Overall bit rate                 : 9 993 Kbps
Writing application              : Lavf52.87.1
Video
Format                           : MPEG-4 Visual
Format profile                   : Simple@L1
Format settings, BVOP            : No
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : 20
Duration                         : 2h 20mn
Bit rate mode                    : Variable
Bit rate                         : 9 765 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Display aspect ratio             : 16:9
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Compression mode                 : Lossy
Bits/(Pixel*Frame)               : 0.442
Stream size                      : 9.55 GiB (98%)
Writing library                  : Lavc52.97.2
Audio
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : ac-3
Duration                         : 2h 20mn
Bit rate mode                    : Constant
Bit rate                         : 224 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Stream size                      : 224 MiB (2%)
Language                         : English
Update
I tried the 720P HQ profile. This creates an LC-AAC audio stream that does work.
Your output filesize issue should be fixed in last version (1.0.0.9) I've just (re)uploaded :
Thanks for all your usefull reports!
