AVCHD to DVD
AVCHD to DVD
Blu-ray to DVD does not recognize any blu-ray that has been converted to a BD5 or BD9 by BD-Rebuilder or MultiAVCHD.
The error says 'Selected HD structure doesn't contain any valid video stream"
If I do a full BD25 from rebuilder then there is no error message.
Using TSmuxer just to do a Blu-ray from the original rip gives the same error message in Blu-ray to DVD.
Any ideas?
Any ideas?
Re: AVCHD to DVD
if it as already been converted then it is not a genuine source as it as already been compressed - re-encodedJJB wrote:Blu-ray to DVD does not recognize any blu-ray that has been converted to a BD5 or BD9 by BD-Rebuilder or MultiAVCHD.
Any ideas?
Hi JJB,
Don't be so upset because we don't respond to your post after one week, I was in holidays and I don't have seen your question.
I take this message to wish you an happy new year
If Blu-ray to Converter don't accept your structures, I think the cause is they should not be Blu-ray/AVCHD compliant.
Can you give me some details about your BD5/BD9 content like video stream codec/resolution/bitrate and audio stream codec/channels/bitrate.
I will try to build some structures with these softwares to see where is the problem, and how can I accept them.
Thank you!
Thank you!
If you try to open remux of original BD made with tsMuxeR, appears two error messages: "Selected HD structure doesn't contain any valid video stream" and then "Selected input doesn't contain any Blu-ray/AVCHD valid structure..."
PS: The same remux played on software and hardware players without any problems.
The same thing happens to BluRays that have been converted down to BD9 or BD5 by DVDFab
I converted a BluRay down to BD5 in DVDFab - the end result had a video stream of 1280x720 (16:9) AVC (Main@L3.1)(CABAC /2 Ref Frames) Audio Stream - 640 kbps, 48KHz, 6 Channels, AC-3 - This was taken from Media Info.
GSpot reported - File Type MPEG-2 Transport Stream, Mime Type Video/mp2t
Hope that helps a little
eon
eon
OK, no problem. I'll take it from the top.cedric wrote:Hi JJB,
Thank you!
1. I rip a blu-ray with AnyDVD HD.
2. I convert it to a BD5 or 9 in most cases using BD-Rebuilder from jdobbs at Doom9. A magnificent piece of software I must say.
http://forum.doom9.org/showthread.php?t=143716
3. The end result is a movie only BD5 or 9 that plays on "Any" Blu-Ray player that can play AVCHD. So it must be compliant. I own 2 Samsung's, a Panasonic and a Sony. Friends have LG and PS3. No problem with any playback.
4. When I try to convert the AVCHD (Strict Format) BD5 or 9 to a DVD using Blu-Ray to DVD is when I receive the "Selected HD structure doesn't contain any valid video stream
5. The workaround is to use AVCHD Editor and make it AVCHD Long Format or Blu-ray compliant then Blu-Ray to DVD can convert it to a DVD. The recommended Short format produces the same error in Blu-Ray to DVD.
6. It appears to be a recognizable structure problem in Blu-Ray to DVD as all the processed BD5 and 9 will play any where and is recognized by several other open source programs such as DeanK's MULTIAVCHD, TSmuxer and AVStoDVD and ConvertXtoDVD(yes, I am a duel owner but prefer Blu-Ray to DVD)
7. I like Blu-Ray to DVD for it's speed vs the others that use HCencoder or Quenc encoders.
8. I do batch converts with BD-Rebuilder then convert to DVD for Grand Kids as needed.(They're to broke to buy a Blu-Ray and I aint giving them one)
9. I wasn't so much upset as I was frustrated.
Can it be fixed?
Hi all,
I think your issue(s) should be fixed in last beta version (1.1.0.4)...
Please can you confirm?
http://forums.vso-software.fr/vso-blu-r ... e89da2ec9b
PS : For lucky users having a NVidia graphic card with CUDA support, they will be happy to see new CUDA stamped profiles (only in PS3 & MKV templates) in this new version.
Thanks!
Thanks!
Thanks but I own BLU-RAY to DVD not Blu-Ray Converter Ultimate and my key will not make it a full version.cedric wrote:Hi all,
Thanks!
Ok,
I built a Blu-ray to DVD beta version, like that you can test if your issue is really fixed.
You will found the link in first post (on bottom) of this topic :
http://forums.vso-software.fr/blu-ray-t ... 13040.html
Have a nice week end!
Thank You!! Works great, no problems.cedric wrote:Ok,
The only thing better than a Holiday is a Weekend.
