PROBLEM ERROR
MARCMENGER
PROBLEM ERROR
Post by MARCMENGER »
I have a problem,just paid for blue-ray to dvd,install the programma,enter key,ok wanna start bleu ray in drive,any dvd says ok
open and select bron bleu ray reader for the disk and error
help please,it dont works!!!
marc
this is the message its new and not work!!!!!!
NOT GOOD.jpg (13.02 KiB) Viewed 5397 times
Hi MARCMENGER,
Please, can you give me more details about your computer like OS version ( Windows version & Service pack), Blu-ray reader reference, AnyDVD HD version...
Thank you.
MARCMENGER
information
windows vista home premium
service pack 2
64-bits
ram 4gb
processor intel(r)core(tm)quad cpu q9450@ 2.66ghz 2.67 ghz
blue ray lg hl-dt-st bd-re gbw-h20l
any dvd hd version 6.7.3.0
greets marc :)
Can you try to install last beta version :
http://forums.vso-software.fr/blu-ray-t ... 13040.html
You will found the download link in bottom of first post.
MARCMENGER
if i install this version,its gonna work,,?? my key works???,
i paid for this but if i,install this new version has no new key needed??
marc :)
simple
Post by simple »
anydvd hd also wants updating the latest version is 6.7.6.0 :wink:
MARCMENGER
ok it works now!!!!thanks is good software!!!! :D marc
