Blu-ray to DVD or "Ultimate"
mikesev
Post by mikesev »
What is the difference between "Convert Blu-ray to DVD" and the "Ultimate" version. The home page does not show an "Ultimate" version. When I downloaded it to see what it was, my Blu-ray to DVD unlock code would not work, so I uninstalled it.
When I installed the latest upgrade for Blu-ray to DVD it shows a version of 1.1.0.6
I also had a problem when using 1.1.0.6 to convert a blu-ray - the audio and video are out of sync. Not by much, but definitely noticeable. I have attached the logfile for this conversion.
blur_ray_Converter.log
(8.36 KiB) Downloaded 409 times
Hi mikesev,
The Ultimate version is in beta stage at this time, you can't buy an unlock.
For your audio/video sync issue, can you say me if this problem appear only with the first audio track (converted from TRUE HD track), or both audio tracks?
Thank you.
mikesev
Post by mikesev »
The problem appears to be only on the first audio track.
Re: Blu-ray to DVD or "Ultimate"
Please, can you try with last beta version (1.2.0.0) I've just published :
Thank you.
