Auto Booktype?
maonstad
Auto Booktype?
Post by maonstad »
Does the final output on a DVD +r auto change to DVD-ROM with this beta software. If so thats great. Or maybe a selection within the software to auto set the DVD +R to DVD-ROM...
Thx
Re: Auto Booktype?
maonstad wrote:Does the final output on a DVD +r auto change to DVD-ROM with this beta software. If so thats great. Or maybe a selection within the software to auto set the DVD +R to DVD-ROM...
Thx
Booktyping is usually done by the burner firmware.
Most drive will NOT Booktype DVD+R until you use hacked firmware.
I know some other software have this software ability but again, if your hardware doesn't support it, it will do nothing !
crowfax
Re: Auto Booktype?
Post by crowfax »
Cougar_II wrote:Most drive will NOT Booktype DVD+R until you use hacked firmware.
Every LG burner drive I've ever used has supported booktyping without any firmware mods.
Ripping Drives: Plextor PX-B310U, HL-DT-ST DVDRAM GP08LU11, BD E DS4E1S, PLDS DS-8A5SH
Playback Devices: WD TV LS (3rd Generation), Samsung Galaxy S2, Philips BDP3306, Cowon J3, Onda VX590Touch
zebadee
Post by zebadee »
Hi :)
Most current drives will booktype to DVD-Rom, when using DVD+R DL.
Lite-On has its own program.
ImgBurn will allow you set bitset manually with most models. ;)
