Blu-Ray to Avi
Blu-Ray to Avi
just purchased it and received an activation code. Subtitles a very messed up. Converted Avatar to xvid, and used the sub for only the non-english parts, each subtitle stays on the screen untill the next one, and then that one shows untill ther is a new one.
Sandy
Sandy
Asus P8P67 Intel I7core 2600K 3400GHz @3850GHz (Water Cooled) ,Nvivda 9800GTX 8GB DDR3-1333. SATA 600x2,
SATA 300x1 Windows 7(64bit)
Re: Blu-Ray to Avi
Hi SandyB,
I reproduced your problem, I'm working on...
Re: Blu-Ray to Avi
Please, can you confirm I fixed your problem in last beta version :
http://oasis.vso-software.fr/Beta/Blura ... 1.0.17.exe
Thank you!
Thank you!
Re: Blu-Ray to Avi
I have made a sample of Avatar from a forced subtitle part for testing various programs. I tried Blu-Ray To Avi(latest beta) and the subtitles are all messed up . Hard to describe but they have a flashing trail behind them. HDConvertToX does a great job of the same sample.
Re: Blu-Ray to Avi
Hi Kiwikid,
Please, can you send me your Avatar sample using our ftp upload tool:
http://download2.vso-software.fr/other/ ... Files2.exe
I will work on your problem when the file will be uploaded.
Thank you!
Thank you!
Re: Blu-Ray to Avi
Thanks, I'll try 17....just got back from a week in Key West
Re: Blu-Ray to Avi
Still has 30 min to go, but from the preview, it looks like the subtitles are fixed. getting about 52fps. I will check it when it's done, and report back.
Re: Blu-Ray to Avi
finished...subtitles are where and when they are supposed to be, and no longer stuck on the screen. Great work, thanks.
Re: Blu-Ray to Avi
Ok, thank you for your (positive) feedback...
Re: Blu-Ray to Avi
I'm still having problems with subtitles. Plus how do you select only forced subs?
Re: Blu-Ray to Avi
Latest beta still makes a mess of the subtitles in Avatar. Converting same file works properly with other software. Any ideas?
Re: Blu-Ray to Avi
Please, can you give me the timestamp where the subtitle is badly displayed?
Thank you.
Thank you.
Re: Blu-Ray to Avi
The strange appearance of the subtitles in Avatar appears to be fixed with v1.2.0.3. Thanks
