I have just started experimenting with this program (version 13 - trial version).
When opening up the blu-ray identified above, it only sees the 8.5 minute series of trailers as a title.
It does not recognize the actual 2.5 hour movie.
The ripped files seem fine as they play just fine and other programs recognize the actual movie title.
Any ideas?
Well - nothing on this question. I'll add more.
I thought this program would see and list all the titles on a blu-ray disc for selection.
It doesn't. It only lists 1 title. And the one it lists is not necessarily the movie.
When I run a blu-ray to dvd output, the resulting files are very small. How can that be?
I'm setting quality to the best available, thus expecting the best bit rate the program can manage resulting in using the great bulk of a DVD-5.
One of the titles I ran resulted in less than 2.5 gb of the 4.3gb available being used for a full length blu-ray movie after conversion to dvd.
That doesn't make sense to me?
Maybe this program is still a work in progress and not really ready for prime time?
If I am doing something incorrectly, I'd welcome guidance.
Girl Who Kicked The Hornet's Nest/blu-ray + File length
Re: Girl Who Kicked The Hornet's Nest/blu-ray + File length
Please, can you try with last beta version (1.2.0.0) I've just published :
Thank you.
Thank you.
