Feature Request @Cedric : DVD Menu Background
Hi Cedric, here's a feature request that is easy to implement and adds high value. In directory \BDMV\META\DL there is an XML file and JPGs these are usually read (by the PS3 for example) to replace the icon of the disk. It would be great if you could add this as an option to the created DVD menu to use these jacket covers as the background.
Re: Feature Request @Cedric : DVD Menu Background
Hi mrr19121970,
I added your feature request in my task list, but I must close some other tasks before.
http://bugs.vso-software.fr/view.php?id=4327
Thank your for your suggestion...
I've just compiled a new beta version (1.2.0.10) with your feature request added :
You will found the beta version download link on bottom of first post...
How this new feature works :
- If only one structure is added in project, both ROOT and TITLE DVD menu pages will use the Blu-ray "cover" as background
- If more than one structure is added in project, each TITLE DVD menu pages will use the Blu-ray "cover" of corresponding structure, ROOT menu will use default background of selectede template
You will found this new option in DVD menu option windows (where you select DVD menu template...)
Thank you for your usefull feature request!
Hi Cedric!
Yes, this is working as I expected thanks. I'm wondering if you are using the *Jacket_LRG.jp or *Jacket_SML.jpg as the quality of the picture is blocky, or is this an MPEG2 issue? I'm not sure I've come across a disk yet that has "jacket" sound yet, but this could be an option too.
Mike.
Mike.
I always use the bigger image file for background...
Do you use the best video quality setting (to use Lanczos as resize filter)?
Yes, I'm using best quality.
Hi Cedric!
I'm using 1.2.0.12, selecting classic menu (best for BD backgrounds). There is no audio/subtitle or chapter menu. Is this normal?
Update
I tried default, simple menu and this creates subtitle/audio + chapter menus but without background image. How do I get classic to display the extra menu parts?
Update
Classic menu doesn't provide settings/chapters DVD page.
You must choose another DVD menu template if you want to have a setting/chapter page on final DVD.
In last version (1.2.0.13), I added background image on chapter pages.
I tried to add background image on settings page too, but after a lot of try, I decided to remove it because this page became unclear with some pictures.
I also increased image background transparency to highlight buttons and others controls.
@Cedric
I just tried this with Beverley Hills Chihuaha 2 (using 1.2.0.15). It didn't work, also the menu now says 'title of the current film' with no background picture. Also a small bug report, when you click on 'convert' you get the error message 'The output folder need to be cleaned before starting the process... Do you wish to continue?' When you click 'no', you still go onto the next dialogue. Also need should be needs in error message.
Please, can you try with last beta version (1.2.0.16) I've just published :
http://forums.vso-software.fr/post64874.html#p64874
Thank you!
Thank you!
Hi Cedric!
Yes, that's working again now. Thanks. I'd really prefer an option though so I can decide whether I want the background on the settings page. My example would have been OK with the background picture too.
Mike.
Mike.
Ok you won, I will check tomorrow if I can add background picture for setting page too...
Hi Cedric
Version 1.4.0.5 still doesn't have the background picture on all menus
I worked on your problem and it will be fixed for next version (1.4.0.7).
All menu pages background will use Blu-ray cover if available and if setting is enabled.
EDIT :
The new version (1.4.0.7) has been set as default version on our web site :
http://www.vso-software.fr/products/blu ... verter.php
Thank you!
EDIT :
Thank you!
Hi Cedric!
Just tried 1408. Perfect. Thanks.
- Contact:
Maybe I'm doing something wrong, but the background picture seems to be still broken in 1.4.0.8.
If I select "Black mirror (with chapter text)", the manually selected background image is ignored no matter which transparency I chose.
Only if I select "Black mirror with static thumbnails", the background image is sometimes displayed (though most of the times it's ignored as well), yet then the video loop is showed in the upper part of the screen. Anyway, I just can't detect any kind of system when the background image is ignored and when it's displayed.
Sometimes it works for e.g. background transparency of 255 but then the next time it doesn't with the very same picture and setup. Seems completely random to me.
Besides, it would be necessary to select a font color when using a background image - else the light font gets unreadable on most background which are not completely dark.
Furthermore, a working menu preview would be really, really helpful ... or at least a test menu render without converting the whole movie each time. Currently it's just trying out options and hoping they'll work - but usually they don't, which is rather frustrating...
It would even help if the menus were just rendered first. Then you could stop the process if the result was unexpected again without having to convert the main movie first...
And while we're at it: why isn't it possible to use/select a background image in the DVD Converter but only in the BD Converter?
