I've been getting this error within a few seconds of pressing "Convert" Don't know if the problem is with the disc, Blu-ray Converter Ultimate or AnyDVD.
I have attached the AnyDVD log and the Blu-ray converter log. My process is - open AnyDVD and scan disc, then rip video DVD to hard drive. Then I close AnyDVD and open Blu-ray converter to convert to DVD. Thanks for any help you can give me.
The Conversion process has been aborted by user
- Menace II Society log.txt
- (22.42 KiB) Downloaded 490 times
- AnyDVD_6.8.0.0_Info_E_MENACE_II_SOCIETY.zip
- (109.9 KiB) Downloaded 440 times
Re: The Conversion process has been aborted by user
Please, can you try with current beta version (1.2.0.16) available here :
You will found the download link on bottom of first post...
I'm waiting for your feedback.
Thank you!
Thank you!
This is with version 1.2.0.16.
Cedric - is there any other information I can give you to help resolve this problem?
Some users reported problems with last NVidia drivers update (and we use CUDA optim in converter when available).
Do you have a Nvidia graphic card? If yes, can you try to revert to previous driver version?
Hi Cedric,
No, I don't have an Nvidia graphic card. I have an ATI Radeon HD 5870 1GB.
I sent you an email to work around your problem...
Thanks Cedric,
The problem appeared to be in the Audio Format Settings when converting to DVD. It was not working correctly when set to Automatic option of "Convert Audio to format." When I use "AC-3, 5.1 channels," the conversion works fine.
