Create videos in stardard or high definition format: 720 or 1080 pixels in the output size of your choice. Your video files will now be compatible with your devices.
how can I choose this Output Size ?
I found only this Options:
Fast Linear, Linear und Lanczos Filter
Thank you Zebadee,
but I have not the Blu-ray Converter Ultimate for multiple formats.
I have the verry normal program, only for single format "BR to DVD".
Regards Monacus
Sorry Claire,
that's what I want. Changing the targed Size f.e. 720, 1080, etc.
In the description I read this:
But this is not possible.
The only option ist to choose the Filter-Typ: Fast Linear, Linear and Lanczos Filter.
As I wrote: I have the Program for converting only BR to DVD, not the ULTIMATE
because I don't need converting to other formats.
