A little more information please
vbritt
Post by vbritt »
I am trying to convert a blu-ray disc to a DVD SL and DL with chapters and a title. Everything works except that the chapters only have time stamps and the title is missing. Where I would expect the title to be I have a default string that says, "Title of the current film". I have not found any way to change that to the title of the movie. I reviewed the job aid on your web page for Blu-Ray Converter Ultimate, but it seemed to be lacking when it came to how to create titles and or chapter names.
Any help will be appreciated.
Re: A little more information please
what type of title do you expect for the chapter points?
You can change the title name, by entering the project name
vbritt
Post by vbritt »
Claire wrote:what type of title do you expect for the chapter points?
Changing the project name has no effect on the finished product. I have tried and the finished output still says, "Title of the current film. I have AnyDVD-HD running and I am using version 1.2.0.14 of Blu-Ray Converter Ultimate. If the project name is supposed to be the title on the DVD then it doesn't work for me. I am running the Blu-Ray Converter Ultimate on a Windows 7, 64 bit machine if that makes any difference.
vbritt
Post by vbritt »
It seems like the problem of the missing title is caused when you generate chapters. If I turn off the chapter generation then I get the title. If I have the application generate a chapter every 20 minutes then I get the chapters but no title. I am attaching a screen shot that shows what I am seeing.
Blu-Ray Ultimate.zip
(417.97 KiB) Downloaded 330 times
I learned somthing new. If many titles appear, but only 1 is selected to be converted then name is taken from what is displayed in the first window. In the case of my screenshot "Main title (default)". (If many titles are converted, then the project name is used)
You can press F2 and have this changed.
I have requested that a new change be made to the up coming version, so that if the project name is taken if modified by user.
