DVD Converter: new beta version available! (2.1.1.35)
Hi all,
Here is the latest beta version of DVD Converter:
Current beta is available here (2.1.1.35):
http://oasis.vso-software.fr/Beta/Blura ... 1.1.35.exe
And the new version is out it is official v2.1.1.34
http://www.vso-software.fr/download_pro ... erultimate
Blu-ray & DVD Converters - 2.1.1.35 (Released 2013-03-11) [ View Issues ]
- 0006533: [Bug] cxd conversions do not load (felicia) - resolved.
- 0006525: [Bug] output size not respected (cedric) - resolved.
- 0006524: [Bug] forced subtitles not correctly displaying text (cedric) - resolved.
[3 issues]
Goldmembers get your key automatically
We are waiting for your feedback...
Thanks for your help!
[3 issues]
Re: DVD Converter : first ALPHA version available!
Any chance of a key?
I am a "Goldmember".
N.B. The link above describes Blu-ray converter, when it is DVD converter..
Yes this converter is really very good. i like this converter help to convert dvd's to so many formats. the quality of the converted file is also very good. there are so many converters available over the net but this is quite good.
thanks zebadee, I have hidden the links o that it causes less confusion.
1st post has been updated so goldmembers can get key
HiClaire wrote:1st post has been updated so goldmembers can get key
Many thanks....
Re: DVD Converter : new ALPHA version available! (1.2.1.5)
I love this program, this is not really n Alpha, it worked perfectly on my Win7 64bit system.
Cool. Will give this 1 a test in a few.
thanks for your comments
Re: DVD Converter : new BETA version available! (1.2.1.6)
Thanks for this latest update + history too!
Re: DVD Converter : new BETA version available! (1.2.1.10)
yes the email i opened said it was for blueray converter but it sent rego number for dvd converter????????????????????????? why
Re: DVD Converter : new BETA version available! (1.2.1.11)
Hi, Clair
Downloaded and installed but the program launches 1 time in 5
. You see the process start then nothing. If you double click the icon a few times then it may launch. Running Xp Pro.
Have UN-installed and reinstalled same problem have turned of anti virus in case was blocking (no warning giving such action)
Any Suggestions why
Regards Budda [sic]
PS when finally have managed to start the program have attached the log
2011-09-07 03:05:26 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-09-07 03:05:26 Info Drive has IDE-ATAPI physical interface
2011-09-07 03:05:26 Info New Drive selected : 2:0:0 - HL-DT-ST DVDRAM GMA-4082N HN03 [D] (Ide)
2011-09-07 03:05:26 Info Available Memory : 4241 Mb.
2011-09-07 03:05:26 Info Total Memory : 5985 Mb.
2011-09-07 03:05:26 Info Available extended Virtual Memory : 0 Mb.
2011-09-07 03:05:26 Info Available Virtual Memory : 1926 Mb.
2011-09-07 03:05:26 Info Total Virtual Memory : 2047 Mb.
2011-09-07 03:05:26 Info Memory Load : 51%
2011-09-07 03:05:26 Info Available Physical Memory : 1503 Mb.
2011-09-07 03:05:26 Info Total Physical Memory : 3070 Mb.
2011-09-07 03:05:26 Info System default language : English (United States)
2011-09-07 03:05:26 Info User default language : English (United States)
2011-09-07 03:05:26 Info Version : 1.2.1.11
2011-09-07 03:05:26 Info ExeName : C:\Program Files\VSO\DVD Converter Ultimate\DVDConverterUltimate.exe
2011-09-07 03:05:26 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
2011-09-07 03:04:38 Info 9 Menu templates loaded.
2011-09-07 03:04:38 Info No disc in drive.
2011-09-07 03:04:35 Info Using Advanced SPTI interface
2011-09-07 03:04:35 ---- ******************** Log session start 07-Sep 03:04:35.093 PID 4300********************
2011-09-07 02:43:53 ---- ******************** Log session stop 07-Sep 02:43:53.421 PID 4812********************
2011-09-07 02:43:47 Info 9 Menu templates loaded.
2011-09-07 02:43:46 Info No disc in drive.
2011-09-07 02:43:43 Info Using Advanced SPTI interface
2011-09-07 02:43:43 ---- ******************** Log session start 07-Sep 02:43:43.500 PID 4812********************
2011-09-07 02:42:41 ---- ******************** Log session stop 07-Sep 02:42:41.437 PID 5052********************
2011-09-07 02:42:07 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-09-07 02:42:07 Info Drive has IDE-ATAPI physical interface
2011-09-07 02:42:07 Info New Drive selected : 2:0:0 - HL-DT-ST DVDRAM GMA-4082N HN03 [D] (Ide)
2011-09-07 02:42:06 Info Available Memory : 4616 Mb.
2011-09-07 02:42:06 Info Total Memory : 5985 Mb.
2011-09-07 02:42:06 Info Available extended Virtual Memory : 0 Mb.
2011-09-07 02:42:06 Info Available Virtual Memory : 1927 Mb.
2011-09-07 02:42:06 Info Total Virtual Memory : 2047 Mb.
2011-09-07 02:42:06 Info Memory Load : 44%
2011-09-07 02:42:06 Info Available Physical Memory : 1717 Mb.
2011-09-07 02:42:06 Info Total Physical Memory : 3070 Mb.
2011-09-07 02:42:06 Info System default language : English (United States)
2011-09-07 02:42:06 Info User default language : English (United States)
2011-09-07 02:42:06 Info Version : 1.2.1.11
2011-09-07 02:42:06 Info ExeName : C:\Program Files\VSO\DVD Converter Ultimate\DVDConverterUltimate.exe
2011-09-07 02:42:06 Info OS : Microsoft Windows XP Professional (Build 2600: Service Pack 3)
2011-09-07 02:41:49 Info 9 Menu templates loaded.
2011-09-07 02:41:49 Info No disc in drive.
2011-09-07 02:41:46 Info Using Advanced SPTI interface
2011-09-07 02:41:45 ---- ******************** Log session start 07-Sep 02:41:45.343 PID 5052********************
Any Suggestions why
Regards Budda [sic]
Budda [sic]
From Down Under
My All-rounder Rig
CPU: I7-2600K @ 4.6 GHZ
RAM: Corsair 16 Gig DDR3 1866
HDD: 11TB
Network & BU Thecus N5550
From Down Under
My All-rounder Rig
HDD: 11TB
Re: DVD Converter : new BETA version available! (1.2.1.13)
Thanks for your feedback. When you say
Have you used the CLeanVSO tool to uninstall?
A new vesrion is out 1.2.1.13 (we are working on getting the news keys in place today). Maybe let me know how it goes with that.
Thank you.
where do you "see" something? Do you see interface, or are you talking about in the task manager?You see the process start then nothing.
Thank you.
- Contact:
Re: DVD Converter : new BETA version available! (1.2.1.14)
Since 1.2.1.13, the DVD converter expects a new key (a longer key block) and the serial that can be automatically retrieved doesn't work any more..
Asking for a new key, I am a Goldmember and the key they send me doesnt work on the new beta.
0xdeadbeef wrote:Since 1.2.1.13, the DVD converter expects a new key (a longer key block) and the serial that can be automatically retrieved doesn't work any more..
Hialan1476 wrote:Asking for a new key, I am a Goldmember and the key they send me doesnt work on the new beta.
The info has already been posted.
* Now 1.2.1.14.Claire wrote:Hello,
Thanks for your feedback. When you saywhere do you "see" something? Do you see interface, or are you talking about in the task manager?You see the process start then nothing.
A new version is out 1.2.1.13* (we are working on getting the new keys in place today). Maybe let me know how it goes with that.
Thank you.
Obviously still sorting “new” keys.
Try again tomorrow is my option…
Tomorrow it is, at my age I dont even buy " Green bananas" so tomorrow is a questionable.
PM me with your email that is used in our database and I will send you a new key.
FYI for conversions DVD to DVD with 1.2.1.14 subtitles do not display in preview (as they are simply copied from the source - no reencode needed). We will propose a solution so user is informed.
Re: DVD Converter: new version available! (1.2.1.15)
new version posted
