Better Quality CUDA or HQ ?
BenieUK
Post by BenieUK »
What will get me the very best quality from my bluray movie, set no size limit and select either Playstation H264 1080p HQ or H264 1080p CUDA?
I know CUDA is much faster but is that at a quality loss.. and how much ..
Thank You
Re: Better Quality CUDA or HQ ?
Cuda is Nvidias software to allow use of gfx-card hardware.
There should be no effect on output between Cuda and on-Cuda conversion if same settings are applied.
BenieUK
Post by BenieUK »
Ok i have done some testing on a trailer of around 4mins on my bluray with setting no size limit...
PS3 1080p CUDA > quality great (id give it 9/10), file size 134mb
PS3 1080p HQ > quality great (id give it 9/10), file size 42mb
so it seems with CUDA you get GREAT SPEED and the SAME QUALITY but at a BIG INCREASE in file size :!:
Looks like its the slower HQ setting for me :shock:
