Select DVD5 on Harry Potter 2 Ultimate wants larger disk
Version 1.2.1.7 seems to have fixed the problem. The selection of movie and bonus seems reversed to me with the extended version as the default movie and the original/theatrical as the bonus instead of movie version 1 and movie version 2 - but it does work
__________________________________________________________________________
I Select DVD 5 as my output but burning process requests larger media.
Is there a way to automatically reduce target output to fit on a DVD
I am re-running to confirm
Details !!!!!!! Harry Potter 2, Extended Edition has option for 2 different playbacks - 2 streams I guess you would call it. The Converted doesn't recognize the 2 streams and can't complete the conversion. I don't want to waste one of my precious few DVD-9 disks to burn broken output.
Re: Select DVD5 but requests to insert larger disk
please post your log file
Logfile as requested. It spit my disk out and asked for a larger disk. It made a 7.91 gig directory
2011-08-24 14:10:33 Important ****************************************Conversion process : session end****************************************
2011-08-24 13:26:40 Info No disc in drive.
2011-08-24 13:26:35 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-08-24 13:26:35 Info Drive has IDE-ATAPI physical interface
2011-08-24 13:26:35 Info New Drive selected : 0:1:0 - HL-DT-ST DVD-RAM GSA-H22L 1.02 [D] (Ide)
2011-08-24 13:26:35 Info Starting to burn converted files...
2011-08-24 13:26:35 Info Conversion process completed successfully
2011-08-24 13:26:35 Info Rendering rate: 0.99 x Realtime
2011-08-24 13:26:35 Info DVD duration (incl. menus) 02:56:38 (~ 10598 sec.) - rendering time 02:58:24
2011-08-24 13:26:35 Info Generated duration 10598.36 sec., expected 10464.04 sec.
2011-08-24 13:25:46 Info P-SDT buffer Underflow 26 times, 13463 bytes peak
2011-08-24 13:25:46 Info 1463 frames duplicated
2011-08-24 13:16:41 Info Chapter #37 start at 165:12.400
2011-08-24 13:11:03 Info Chapter #36 start at 160:4.600
2011-08-24 13:05:21 Info Chapter #35 start at 154:49.280
2011-08-24 13:01:44 Info Chapter #34 start at 151:35.080
2011-08-24 12:57:39 Info Chapter #33 start at 148:1.380
2011-08-24 12:51:56 Info Chapter #32 start at 143:1.580
2011-08-24 12:46:05 Info Chapter #31 start at 137:38.760
2011-08-24 12:42:34 Info Chapter #30 start at 134:22.560
2011-08-24 12:36:48 Info Chapter #29 start at 128:55.220
2011-08-24 12:31:54 Info Chapter #28 start at 124:36.960
2011-08-24 12:27:22 Info Chapter #27 start at 120:30.720
2011-08-24 12:22:53 Info Stream #2 - Audio sync at 6973471.04 ms: 10.67 ms removed
2011-08-24 12:22:17 Info Chapter #26 start at 115:39.940
2011-08-24 12:16:52 Info Chapter #25 start at 110:33.620
2011-08-24 12:12:02 Info Chapter #24 start at 106:2.860
2011-08-24 12:12:01 Info Stream #2 - Audio sync at 6362911.04 ms: 10.67 ms removed
2011-08-24 12:07:35 Info Chapter #23 start at 101:55.100
2011-08-24 12:05:16 Info Stream #2 - Audio sync at 5989951.04 ms: 10.67 ms removed
2011-08-24 12:01:30 Info Chapter #22 start at 96:22.780
2011-08-24 11:56:33 Info Chapter #21 start at 91:57.020
2011-08-24 11:54:20 Info Stream #2 - Audio sync at 5401524.38 ms: 10.67 ms removed
2011-08-24 11:53:51 Info Stream #2 - Audio sync at 5370996.38 ms: 10.67 ms removed
2011-08-24 11:50:18 Info Chapter #20 start at 85:59.660
2011-08-24 11:45:09 Info Chapter #19 start at 80:33.320
2011-08-24 11:39:18 Info Chapter #18 start at 74:12.940
2011-08-24 11:36:56 Info Stream #2 - Audio sync at 4274281.71 ms: 10.67 ms removed
2011-08-24 11:35:12 Info Chapter #17 start at 69:25.660
2011-08-24 11:30:19 Info Chapter #16 start at 64:8.840
2011-08-24 11:26:40 Info Stream #2 - Audio sync at 3642644.38 ms: 10.67 ms removed
2011-08-24 11:24:00 Info Chapter #15 start at 58:8.480
2011-08-24 11:20:10 Info Chapter #14 start at 54:8.740
2011-08-24 11:15:00 Info Chapter #13 start at 48:40.420
2011-08-24 11:10:25 Info Chapter #12 start at 43:52.640
2011-08-24 11:07:11 Info Stream #2 - Audio sync at 2432265.71 ms: 10.67 ms removed
2011-08-24 11:06:32 Info Chapter #11 start at 39:50.880
2011-08-24 11:02:46 Info Stream #2 - Audio sync at 2162207.04 ms: 10.67 ms removed
2011-08-24 11:02:10 Info Chapter #10 start at 35:26.120
2011-08-24 10:59:30 Info Chapter #9 start at 32:32.460
2011-08-24 10:56:35 Info Chapter #8 start at 29:31.780
2011-08-24 10:53:10 Info Stream #2 - Audio sync at 1571199.04 ms: 10.67 ms removed
2011-08-24 10:52:38 Info Chapter #7 start at 25:38.540
2011-08-24 10:48:33 Info Chapter #6 start at 21:20.280
2011-08-24 10:44:13 Info Stream #2 - Audio sync at 1010804.38 ms: 10.67 ms removed
2011-08-24 10:42:14 Info Chapter #5 start at 14:48.880
2011-08-24 10:39:07 Info Chapter #4 start at 11:31.200
2011-08-24 10:36:19 Info Chapter #3 start at 8:37.020
2011-08-24 10:31:02 Info Chapter #2 start at 3:1.180
2011-08-24 10:28:10 Info Stream #2 - Audio sync at 53.33 ms: 52.38 ms added
2011-08-24 10:28:10 Info Audio settings: Automatic With DTS -> AC-3 conversion
2011-08-24 10:28:10 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, flt, 448 kb/s
2011-08-24 10:28:10 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=3-31, 2799 kb/s, pulldown: 23.976 -> 25.00 Fps
2011-08-24 10:28:10 Info Encoding MPEG-2 with 2 threads
2011-08-24 10:28:10 Info Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 2 threads
2011-08-24 10:28:10 Info 2 Stream(s) found - est. duration 02:54:24.037, reference 02:54:24.037
2011-08-24 10:28:10 Info Opening file "E:\BDMV\index.bdmv"
2011-08-24 10:28:10 Info Output folder : G:\Users\Robert\Documents\VSOBlurayConverter
2011-08-24 10:28:10 Info Maximum target size : 4.30 Gb.
2011-08-24 10:28:10 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2011-08-24 10:28:10 Important ****************************************Conversion process : session start****************************************
latest crash log - saved as: blur_ray_Converter_crash_PID3224.log
the process is still trying
2011-08-24 15:47:01 Info Stream #2 - Audio sync at 5401524.38 ms: 10.67 ms removed
2011-08-24 15:46:34 Info Stream #2 - Audio sync at 5370996.38 ms: 10.67 ms removed
2011-08-24 15:43:13 Info Chapter #20 start at 85:59.654
2011-08-24 15:38:22 Info Chapter #19 start at 80:33.328
2011-08-24 15:32:36 Info Chapter #18 start at 74:12.948
2011-08-24 15:29:39 Info Stream #2 - Audio sync at 4274281.71 ms: 10.67 ms removed
2011-08-24 15:27:52 Info Chapter #17 start at 69:25.661
2011-08-24 15:22:51 Info Chapter #16 start at 64:8.845
2011-08-24 15:19:15 Info Stream #2 - Audio sync at 3642644.38 ms: 10.67 ms removed
2011-08-24 15:16:42 Info Chapter #15 start at 58:8.485
2011-08-24 15:13:06 Info Chapter #14 start at 54:8.745
2011-08-24 15:08:06 Info Chapter #13 start at 48:40.417
2011-08-24 15:03:21 Info Chapter #12 start at 43:52.630
2011-08-24 15:00:10 Info Stream #2 - Audio sync at 2432265.71 ms: 10.67 ms removed
2011-08-24 14:59:33 Info Chapter #11 start at 39:50.888
2011-08-24 14:56:06 Info Stream #2 - Audio sync at 2162207.04 ms: 10.67 ms removed
2011-08-24 14:55:30 Info Chapter #10 start at 35:26.124
2011-08-24 14:52:50 Info Chapter #9 start at 32:32.450
2011-08-24 14:50:00 Info Chapter #8 start at 29:31.770
2011-08-24 14:46:43 Info Stream #2 - Audio sync at 1571199.04 ms: 10.67 ms removed
2011-08-24 14:46:12 Info Chapter #7 start at 25:38.537
2011-08-24 14:42:34 Info Chapter #6 start at 21:20.279
2011-08-24 14:38:26 Info Stream #2 - Audio sync at 1010804.38 ms: 10.67 ms removed
2011-08-24 14:36:32 Info Chapter #5 start at 14:48.888
2011-08-24 14:33:31 Info Chapter #4 start at 11:31.190
2011-08-24 14:30:49 Info Chapter #3 start at 8:37.016
2011-08-24 14:25:49 Info Chapter #2 start at 3:1.181
2011-08-24 14:23:26 Info Stream #2 - Audio sync at 53.33 ms: 52.38 ms added
2011-08-24 14:23:26 Info Audio settings: Automatic With DTS -> AC-3 conversion
2011-08-24 14:23:26 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, flt, 448 kb/s
2011-08-24 14:23:26 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=3-31, 2799 kb/s, pulldown: 23.976 -> 29.97 Fps
2011-08-24 14:23:26 Info Encoding MPEG-2 with 2 threads
2011-08-24 14:23:26 Info Video processing: Lanczos (VSO) resampler (1920*1080)->(720*480) 2 threads
2011-08-24 14:23:26 Info 2 Stream(s) found - est. duration 02:54:24.037, reference 02:54:24.037
2011-08-24 14:23:26 Info Opening file "E:\BDMV\index.bdmv"
2011-08-24 14:23:26 Info Output folder : G:\Users\Robert\Documents\VSOBlurayConverter
2011-08-24 14:23:26 Info Maximum target size : 4.30 Gb.
2011-08-24 14:23:26 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2011-08-24 14:23:26 Important ****************************************Conversion process : session start****************************************
2011-08-24 14:23:25 Info Chapters collection will be imported from original structure
2011-08-24 14:23:25 Info Selected DVD menu template : Black Mirror (with chapter text)
2011-08-24 14:23:18 Info Converted project will be burnt using D: drive
2011-08-24 14:23:18 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-08-24 14:23:18 Info Drive has IDE-ATAPI physical interface
2011-08-24 14:23:18 Info New Drive selected : 0:1:0 - HL-DT-ST DVD-RAM GSA-H22L 1.02 [D] (Ide)
2011-08-24 14:21:39 Info Writable disc DVD-R inserted. Ready to write
2011-08-24 14:19:04 Info Parsing disc ...
2011-08-24 10:28:09 Info Chapters collection will be imported from original structure
2011-08-24 10:28:09 Info Selected DVD menu template : Black Mirror (with chapter text)
2011-08-24 10:28:03 Info Converted project will be burnt using D: drive
2011-08-24 10:28:03 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-08-24 10:28:03 Info Drive has IDE-ATAPI physical interface
2011-08-24 10:28:03 Info New Drive selected : 0:1:0 - HL-DT-ST DVD-RAM GSA-H22L 1.02 [D] (Ide)
2011-08-24 10:27:54 Info Writable disc DVD-R inserted. Ready to write
2011-08-24 10:27:36 Info 9 Menu templates loaded.
2011-08-24 10:27:35 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVD+R, DVD+RW, CD-R, DL DVD+R, DL DVD-R
2011-08-24 10:27:35 Info Drive has IDE-ATAPI physical interface
2011-08-24 10:27:35 Info New Drive selected : 0:1:0 - HL-DT-ST DVD-RAM GSA-H22L 1.02 [D] (Ide)
2011-08-24 10:27:35 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-24 10:27:35 Info Drive has Serial ATA physical interface
2011-08-24 10:27:35 Info New Drive selected : 3:0:0 - HL-DT-ST BD-RE GGW-H20L YL05 [E] (Ide)
2011-08-24 10:27:34 Info Available Memory : 6621 Mb.
2011-08-24 10:27:34 Info Total Memory : 8187 Mb.
2011-08-24 10:27:34 Info Available extended Virtual Memory : 0 Mb.
2011-08-24 10:27:34 Info Available Virtual Memory : 1824 Mb.
2011-08-24 10:27:34 Info Total Virtual Memory : 2047 Mb.
2011-08-24 10:27:34 Info Memory Load : 31%
2011-08-24 10:27:34 Info Available Physical Memory : 2792 Mb.
2011-08-24 10:27:34 Info Total Physical Memory : 4094 Mb.
2011-08-24 10:27:34 Info System default language : English (United States)
2011-08-24 10:27:34 Info User default language : English (United States)
2011-08-24 10:27:34 Info Version : 1.2.0.14
2011-08-24 10:27:34 Info ExeName : G:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2011-08-24 10:27:34 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2011-08-24 10:27:33 Info Using Advanced SPTI interface
2011-08-24 10:27:33 ---- ******************** Log session start 2011-08-24 10:27:33.500 PID 3224********************
Just tried DVD5, as I normalyy use DVD9.
Started with BD original.
Finished with.
Try a clean install.
Might be worth selcting language 1st too!
I also disable "auto burning".
Only burn after checking everything appears OK.
Finished with.
hmmm - selected language - will try clean install
Hmmm - Still problems. Did a clean install, selected English as language - selected to NOT burn right away - Selected DVD5 4.7gig
STILL Created 5.46 directory - this won't fit on a disk.
This is my log.
2011-08-24 22:54:48 Info Stream #2 - Audio sync at 6362911.04 ms: 10.67 ms removed
2011-08-24 22:51:04 Info Chapter #23 start at 101:55.109
2011-08-24 22:49:21 Info Stream #2 - Audio sync at 5989951.04 ms: 10.67 ms removed
2011-08-24 22:46:29 Info Chapter #22 start at 96:22.777
2011-08-24 22:42:44 Info Chapter #21 start at 91:57.011
2011-08-24 22:41:03 Info Stream #2 - Audio sync at 5401524.38 ms: 10.67 ms removed
2011-08-24 22:40:37 Info Stream #2 - Audio sync at 5370996.38 ms: 10.67 ms removed
2011-08-24 22:37:35 Info Chapter #20 start at 85:59.654
2011-08-24 22:32:55 Info Chapter #19 start at 80:33.328
2011-08-24 22:27:40 Info Chapter #18 start at 74:12.948
2011-08-24 22:24:49 Info Stream #2 - Audio sync at 4274281.71 ms: 10.67 ms removed
2011-08-24 22:24:48 Info Stream #2 - Audio sync at 4274281.71 ms: 10.67 ms removed
2011-08-24 22:23:18 Info Chapter #17 start at 69:25.661
2011-08-24 22:19:19 Info Chapter #16 start at 64:8.845
2011-08-24 22:16:17 Info Stream #2 - Audio sync at 3642644.38 ms: 10.67 ms removed
2011-08-24 22:14:03 Info Chapter #15 start at 58:8.485
2011-08-24 22:10:45 Info Chapter #14 start at 54:8.745
2011-08-24 22:06:19 Info Chapter #13 start at 48:40.417
2011-08-24 22:02:21 Info Chapter #12 start at 43:52.630
2011-08-24 21:59:38 Info Stream #2 - Audio sync at 2432265.71 ms: 10.67 ms removed
2011-08-24 21:59:03 Info Chapter #11 start at 39:50.888
2011-08-24 21:55:47 Info Stream #2 - Audio sync at 2162207.04 ms: 10.67 ms removed
2011-08-24 21:55:18 Info Chapter #10 start at 35:26.124
2011-08-24 21:52:57 Info Chapter #9 start at 32:32.450
2011-08-24 21:50:28 Info Chapter #8 start at 29:31.770
2011-08-24 21:47:30 Info Stream #2 - Audio sync at 1571199.04 ms: 10.67 ms removed
2011-08-24 21:47:01 Info Chapter #7 start at 25:38.537
2011-08-24 21:43:27 Info Chapter #6 start at 21:20.279
2011-08-24 21:39:36 Info Stream #2 - Audio sync at 1010804.38 ms: 10.67 ms removed
2011-08-24 21:37:51 Info Chapter #5 start at 14:48.888
2011-08-24 21:35:04 Info Chapter #4 start at 11:31.190
2011-08-24 21:32:35 Info Chapter #3 start at 8:37.016
2011-08-24 21:27:51 Info Chapter #2 start at 3:1.181
2011-08-24 21:24:21 Info Stream #2 - Audio sync at 53.33 ms: 52.38 ms added
2011-08-24 21:24:21 Info Audio settings: Automatic With DTS -> AC-3 conversion
2011-08-24 21:24:21 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, flt, 448 kb/s
2011-08-24 21:24:21 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=3-31, 2799 kb/s, pulldown: 23.976 -> 29.97 Fps
2011-08-24 21:24:21 Info Encoding MPEG-2 with 2 threads
2011-08-24 21:24:21 Info Video processing: Linear (VSO) resampler (1920*1080)->(720*480) 2 threads
2011-08-24 21:24:21 Info 2 Stream(s) found - est. duration 02:54:24.037, reference 02:54:24.037
2011-08-24 21:24:21 Info Opening file "E:\BDMV\index.bdmv"
2011-08-24 21:24:21 Info Output folder : G:\Users\Robert\Documents\VSOBlurayConverter
2011-08-24 21:24:21 Info Maximum target size : 4.30 Gb.
2011-08-24 21:24:21 Info Video quality selected : Good quality. Resize filter used for video : Linear (VSO)
2011-08-24 21:24:21 Important ****************************************Conversion process : session start****************************************
2011-08-24 21:24:20 Info Chapters collection will be imported from original structure
2011-08-24 21:24:20 Info Selected DVD menu template : Black Mirror (with chapter text)
2011-08-24 21:24:07 Info Writable disc DVD-R inserted. Ready to write
2011-08-24 21:23:49 Info 9 Menu templates loaded.
2011-08-24 21:23:48 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-08-24 21:23:48 Info Drive has IDE-ATAPI physical interface
2011-08-24 21:23:48 Info New Drive selected : 0:1:0 - HL-DT-ST DVD-RAM GSA-H22L 1.02 [D] (Ide)
2011-08-24 21:23:48 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-24 21:23:48 Info Drive has Serial ATA physical interface
2011-08-24 21:23:48 Info New Drive selected : 3:0:0 - HL-DT-ST BD-RE GGW-H20L YL05 [E] (Ide)
2011-08-24 21:23:48 Info Available Memory : 6468 Mb.
2011-08-24 21:23:48 Info Total Memory : 8187 Mb.
2011-08-24 21:23:48 Info Available extended Virtual Memory : 0 Mb.
2011-08-24 21:23:48 Info Available Virtual Memory : 1824 Mb.
2011-08-24 21:23:48 Info Total Virtual Memory : 2047 Mb.
2011-08-24 21:23:48 Info Memory Load : 38%
2011-08-24 21:23:48 Info Available Physical Memory : 2535 Mb.
2011-08-24 21:23:48 Info Total Physical Memory : 4094 Mb.
2011-08-24 21:23:48 Info System default language : English (United States)
2011-08-24 21:23:48 Info User default language : English (United States)
2011-08-24 21:23:48 Info Version : 1.2.0.14
2011-08-24 21:23:48 Info ExeName : G:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2011-08-24 21:23:48 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2011-08-24 21:23:47 Info Using Advanced SPTI interface
2011-08-24 21:23:47 ---- ******************** Log session start 24-Aug 21:23:47.061 PID 3668********************
This is my log.
I just noticed.
Using a different version.
Was ver. 1.2.1.6.
Now using ver. 1.2.1.7.
Running again having cleared log etc.
Will post log later.
Try this latest version.
http://oasis.vso-software.fr/Beta/Blura ... .2.1.7.exe
I just noticed.
Was ver. 1.2.1.6.
I'm working on your problem (trying to reproduce first, then fix)
PS : You don't need to select language to have the program working in last version.
Hicedric wrote:Hi,
Interesting.
I did.
ver. 1.2.1.7.
As promised log:
2011-08-25 10:42:29 Important ****************************************Conversion process : session end****************************************
2011-08-25 10:42:29 Info Conversion process completed successfully
2011-08-25 10:42:28 Info Rendering rate: 1.46 x Realtime
2011-08-25 10:42:28 Info DVD duration (incl. menus) 02:04:57 (~ 7497 sec.) - rendering time 01:25:23
2011-08-25 10:42:28 Info Generated duration 7497.96 sec., expected 7498.00 sec.
2011-08-25 10:42:28 Info 0 subtitles frames encoded in subtitle stream #1
2011-08-25 10:42:28 Info P-SDT buffer Underflow 1 times, 285 bytes peak
2011-08-25 10:42:28 Warning No data in subtitle stream #3. Check source file.
2011-08-25 09:17:05 Info Stream #2 - Audio sync at 160.00 ms: 73.67 ms added
2011-08-25 09:17:04 Info Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2011-08-25 09:17:04 Info Audio settings: Automatic
2011-08-25 09:17:04 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, stereo, flt, 192 kb/s
2011-08-25 09:17:04 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=2-31, 4358 kb/s, pulldown: 24.000 -> 25.00 Fps
2011-08-25 09:17:04 Info Encoding MPEG-2 with 4 threads
2011-08-25 09:17:04 Info Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 4 threads
2011-08-25 09:17:04 Info 3 Stream(s) found - est. duration 02:04:58.000, reference 02:04:58.000
2011-08-25 09:17:04 Info Opening file "I:\BDMV\index.bdmv"
2011-08-25 09:17:04 Info Output folder : C:\Users\zebadee\Documents\VSOBlurayConverter\
2011-08-25 09:17:04 Info Maximum target size : 4.30 Gb.
2011-08-25 09:17:04 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2011-08-25 09:17:04 Important ****************************************Conversion process : session start****************************************
2011-08-25 09:17:03 Info Chapters collection will be imported from original structure
2011-08-25 09:17:03 Info Selected DVD menu template : No menu
2011-08-25 09:16:54 Info No disc in drive.
2011-08-25 09:16:38 Info 9 Menu templates loaded.
2011-08-25 09:16:37 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-08-25 09:16:37 Info Drive has Serial ATA physical interface
2011-08-25 09:16:37 Info New Drive selected : 0:3:0 - Optiarc DVD RW AD-7203S 1.09 [F] (Ide)
2011-08-25 09:16:37 Info New Drive selected : 4:0:0 - TSSTcorp CDDVDW SH-S203N SB02 [J] (Scsi)
2011-08-25 09:16:37 Info New Drive selected : 4:0:0 - HL-DT-ST BDDVDRW GGC-H20L 1.03 [H] (Scsi)
2011-08-25 09:16:37 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-25 09:16:37 Info New Drive selected : 4:0:0 - PIONEER BD-RW BDR-203 1.13 [G] (Scsi)
2011-08-25 09:16:37 Info New Drive selected : 0:2:0 - TSSTcorp CDDVDW SH-S223F SB03 [E] (Ide)
2011-08-25 09:16:37 Info Available Memory : 13876 Mb.
2011-08-25 09:16:37 Info Total Memory : 16378 Mb.
2011-08-25 09:16:37 Info Available extended Virtual Memory : 0 Mb.
2011-08-25 09:16:37 Info Available Virtual Memory : 1815 Mb.
2011-08-25 09:16:37 Info Total Virtual Memory : 2047 Mb.
2011-08-25 09:16:37 Info Memory Load : 27%
2011-08-25 09:16:37 Info Available Physical Memory : 5974 Mb.
2011-08-25 09:16:37 Info Total Physical Memory : 8190 Mb.
2011-08-25 09:16:37 Info System default language : English (United Kingdom)
2011-08-25 09:16:37 Info User default language : English (United Kingdom)
2011-08-25 09:16:37 Info Version : 1.2.1.7
2011-08-25 09:16:37 Info ExeName : C:\Program Files (x86)\vso\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2011-08-25 09:16:37 Info OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2011-08-25 09:16:36 Info Using Advanced SPTI interface
2011-08-25 09:16:35 ---- ******************** Log session start 25-Aug 09:16:35.797 PID 2372********************
2011-08-25 09:16:31 ---- ******************** Log session stop 25-Aug 09:16:31.279 PID 2716********************
2011-08-25 09:14:56 Info No disc in drive.
2011-08-25 09:10:51 Info 9 Menu templates loaded.
2011-08-25 09:10:50 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-08-25 09:10:50 Info Drive has Serial ATA physical interface
2011-08-25 09:10:50 Info New Drive selected : 0:3:0 - Optiarc DVD RW AD-7203S 1.09 [F] (Ide)
2011-08-25 09:10:50 Info New Drive selected : 4:0:0 - TSSTcorp CDDVDW SH-S203N SB02 [J] (Scsi)
2011-08-25 09:10:50 Info New Drive selected : 4:0:0 - HL-DT-ST BDDVDRW GGC-H20L 1.03 [H] (Scsi)
2011-08-25 09:10:50 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-25 09:10:50 Info New Drive selected : 4:0:0 - PIONEER BD-RW BDR-203 1.13 [G] (Scsi)
2011-08-25 09:10:50 Info New Drive selected : 0:2:0 - TSSTcorp CDDVDW SH-S223F SB03 [E] (Ide)
2011-08-25 09:10:50 Info Available Memory : 13882 Mb.
2011-08-25 09:10:50 Info Total Memory : 16378 Mb.
2011-08-25 09:10:50 Info Available extended Virtual Memory : 0 Mb.
2011-08-25 09:10:50 Info Available Virtual Memory : 1815 Mb.
2011-08-25 09:10:50 Info Total Virtual Memory : 2047 Mb.
2011-08-25 09:10:50 Info Memory Load : 26%
2011-08-25 09:10:50 Info Available Physical Memory : 5984 Mb.
2011-08-25 09:10:50 Info Total Physical Memory : 8190 Mb.
2011-08-25 09:10:50 Info System default language : English (United Kingdom)
2011-08-25 09:10:50 Info User default language : English (United Kingdom)
2011-08-25 09:10:50 Info Version : 1.2.1.7
2011-08-25 09:10:50 Info ExeName : C:\Program Files (x86)\vso\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2011-08-25 09:10:50 Info OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2011-08-25 09:10:49 Info Using Advanced SPTI interface
2011-08-25 09:10:49 ---- ******************** Log session start 25-Aug 09:10:49.149 PID 2716********************
I think there might be something confusing the converter with this specific disk. I just ran HP-1 overnight and it looked and worked fine.
I just started HP-3 and it said 2 hours and 20 min left.
HP-2 always said over 3 hours - like 3 hours and 50 minutes. It seems to me that it is finding MORE to convert then is really there. I don't see an option for different version to copy. HP-1 had 2 versions. I recorded the longer one - longer by about 12-14 minutes - it had the deleted scenes restored - AKA ABC Family version.
Ahah - HP-2 is the ultimate edition - box claims both theatrical and Extended version. I am sure the disk works that way too (I will still check it) I am NOT presented with 2 different options/movies to convert - HP-1 - also ultimate edition DID present with 2 options.
Hirsperson wrote:I think there might be something confusing the converter with this specific disk. I just ran HP-1 overnight and it looked and worked fine.
Are you using AnyDVD?
If so get the latest version.
http://sandbox.slysoft.com/beta/SetupAnyDVD6858.exe
It could be something is giving false info, affecting the end volume size.
Re: Select DVD5 on Harry Potter 2 Ultimate wants larger disk
Hi zebadee,
Are you trying to reproduce with a movie with same duration (about 3 hours) ?
I think we need to try with a movie with same duration as rperson...
Hicedric wrote:Hi zebadee,
Do not think any of my movies are that long.
The discs I've used on the last 3 versions, have all been around the 2 > 2.5 hour mark.
Will have a root around later.
I don't think the actual movie is anywhere near that long. It definitely has 2 different streams but the converter is not seeing them both - I have switched from the current AnyDVD HD to the beta to see if thats the problem. After that, I will try the beta Blu-ray converter. I don't want to change more then one thing at a time for testing.
(and why don't my quotes work?)
Lets back up a bit...
I need to make sure that my AnyDVD HD settings and BluRayConverter settings are correct. I might just have something set wrong.
Not sure if this helps - this is my AnyDVD HD log
0.00s: AnyDVD HD 6.8.5.8
0.08s: Drive: E:, disabled: 0, don't touch: 0, capture: 0
0.08s: medium state: 2
0.08s: ready
0.09s: busy
0.11s: Drive E: locked, result 1, took 1 seconds!
0.16s: mode 0
0.16s: has_something = 1, info->retry_count 0
0.16s: toc response count 2
0.16s: track 1 from 0 to 20530080, Control 4
0.16s: Drive 0 (not set!)
0.16s: read physical failed, sense 5:30:2
0.16s: dvd-rom version 0 120mm 2.52mbps parallel
0.16s: Layer 0 End: 0
0.16s: extract_content data reset 0, io->stop 20530080
0.16s: layer 1 reserved free
0.95s: standard udf
0.95s: label HARRY_POTTER_CHAMBER
2.08s: AACS!
2.08s: Allocated 512 replacement sectors at 10866108:10865820 in /AACS/DUPLICATE/MKB_RO.inf
3.42s: discRequiresBusEncryption 0
3.42s: driveSupportsBusEncryption 0
3.60s: HD type: 1
3.68s: GetExHashNode checking directory /BDMV/STREAM/...
3.68s: GetExHashNode returned 00027.m2ts!
4.13s: MKB version 16
1953dd33cbdd 4.13s:
39d90b989600 4.13s:
4.29s: HD: GetVolumeKey 1
4.29s: GetExHashNode checking directory /BDMV/STREAM/...
4.29s: 00180.m2ts: m2ts_id 0, pid_id 0x100
4.29s: 00179.m2ts: m2ts_id 1, pid_id 0x100
4.29s: 00178.m2ts: m2ts_id 2, pid_id 0x100
4.29s: 00177.m2ts: m2ts_id 3, pid_id 0x100
4.29s: 00176.m2ts: m2ts_id 4, pid_id 0x100
4.29s: 00175.m2ts: m2ts_id 5, pid_id 0x100
4.29s: 00129.m2ts: m2ts_id 6, pid_id 0x100
4.29s: 00128.m2ts: m2ts_id 7, pid_id 0x100
4.29s: 00127.m2ts: m2ts_id 8, pid_id 0x100
4.29s: 00113.m2ts: m2ts_id 9, pid_id 0x100
4.29s: 00123.m2ts: m2ts_id 10, pid_id 0x100
4.29s: 00169.m2ts: m2ts_id 11, pid_id 0x100
4.29s: 00125.m2ts: m2ts_id 12, pid_id 0x100
4.29s: 00037.m2ts: m2ts_id 13, pid_id 0x100
4.29s: 00167.m2ts: m2ts_id 14, pid_id 0x100
4.29s: 00035.m2ts: m2ts_id 15, pid_id 0x100
4.29s: 00034.m2ts: m2ts_id 16, pid_id 0x100
4.29s: 00033.m2ts: m2ts_id 17, pid_id 0x100
4.29s: 00032.m2ts: m2ts_id 18, pid_id 0x100
4.29s: 00162.m2ts: m2ts_id 19, pid_id 0x100
4.29s: 00030.m2ts: m2ts_id 20, pid_id 0x100
4.29s: 00029.m2ts: m2ts_id 21, pid_id 0x100
4.29s: 00028.m2ts: m2ts_id 22, pid_id 0x100
4.29s: 00027.m2ts: m2ts_id 23, pid_id 0x100
4.29s: 00026.m2ts: m2ts_id 24, pid_id 0x100
4.29s: 00025.m2ts: m2ts_id 25, pid_id 0x100
4.29s: 00024.m2ts: m2ts_id 26, pid_id 0x100
4.29s: 00158.m2ts: m2ts_id 27, pid_id 0x100
4.29s: 00021.m2ts: m2ts_id 28, pid_id 0x100
4.29s: 00020.m2ts: m2ts_id 29, pid_id 0x100
4.29s: 00019.m2ts: m2ts_id 30, pid_id 0x100
4.29s: 00018.m2ts: m2ts_id 31, pid_id 0x100
4.29s: 00017.m2ts: m2ts_id 32, pid_id 0x100
4.29s: 00009.m2ts: m2ts_id 33, pid_id 0x100
4.29s: 00151.m2ts: m2ts_id 34, pid_id 0x100
4.31s: 00016.m2ts: m2ts_id 35, pid_id 0x100
4.31s: 00015.m2ts: m2ts_id 36, pid_id 0x100
4.31s: 00148.m2ts: m2ts_id 37, pid_id 0x100
4.31s: 00147.m2ts: m2ts_id 38, pid_id 0x100
4.31s: 00007.m2ts: m2ts_id 39, pid_id 0x100
4.31s: 00145.m2ts: m2ts_id 40, pid_id 0x100
4.31s: 00006.m2ts: m2ts_id 41, pid_id 0x100
4.31s: 00005.m2ts: m2ts_id 42, pid_id 0x100
4.31s: 00004.m2ts: m2ts_id 43, pid_id 0x100
4.31s: 00003.m2ts: m2ts_id 44, pid_id 0x100
4.31s: 00001.m2ts: m2ts_id 45, pid_id 0x100
4.31s: 00140.m2ts: m2ts_id 46, pid_id 0x100
4.31s: 00031.m2ts: m2ts_id 47, pid_id 0x100
4.31s: 00014.m2ts: m2ts_id 48, pid_id 0x100
4.31s: 00115.m2ts: m2ts_id 49, pid_id 0x100
4.31s: 00137.m2ts: m2ts_id 50, pid_id 0x100
4.31s: 00136.m2ts: m2ts_id 51, pid_id 0x100
4.31s: 00135.m2ts: m2ts_id 52, pid_id 0x100
4.31s: 00134.m2ts: m2ts_id 53, pid_id 0x100
4.31s: 00133.m2ts: m2ts_id 54, pid_id 0x100
4.31s: 00132.m2ts: m2ts_id 55, pid_id 0x100
4.31s: 00114.m2ts: m2ts_id 56, pid_id 0x100
4.31s: 00131.m2ts: m2ts_id 57, pid_id 0x100
4.31s: 00130.m2ts: m2ts_id 58, pid_id 0x100
4.31s: 00112.m2ts: m2ts_id 59, pid_id 0x100
4.31s: 00111.m2ts: m2ts_id 60, pid_id 0x100
4.31s: 00110.m2ts: m2ts_id 61, pid_id 0x100
4.31s: 00109.m2ts: m2ts_id 62, pid_id 0x100
4.31s: 00108.m2ts: m2ts_id 63, pid_id 0x100
4.31s: 00107.m2ts: m2ts_id 64, pid_id 0x100
4.31s: 00106.m2ts: m2ts_id 65, pid_id 0x100
4.31s: 00105.m2ts: m2ts_id 66, pid_id 0x100
4.31s: 00104.m2ts: m2ts_id 67, pid_id 0x100
4.31s: 00103.m2ts: m2ts_id 68, pid_id 0x100
4.31s: 00102.m2ts: m2ts_id 69, pid_id 0x100
4.31s: 00101.m2ts: m2ts_id 70, pid_id 0x100
4.31s: 00100.m2ts: m2ts_id 71, pid_id 0x100
4.31s: 00099.m2ts: m2ts_id 72, pid_id 0x100
4.31s: 00098.m2ts: m2ts_id 73, pid_id 0x100
4.31s: 00097.m2ts: m2ts_id 74, pid_id 0x100
4.31s: 00096.m2ts: m2ts_id 75, pid_id 0x100
4.31s: 00095.m2ts: m2ts_id 76, pid_id 0x100
4.31s: 00094.m2ts: m2ts_id 77, pid_id 0x100
4.31s: 00093.m2ts: m2ts_id 78, pid_id 0x100
4.31s: 00092.m2ts: m2ts_id 79, pid_id 0x100
4.31s: 00091.m2ts: m2ts_id 80, pid_id 0x100
4.31s: 00090.m2ts: m2ts_id 81, pid_id 0x100
4.31s: 00089.m2ts: m2ts_id 82, pid_id 0x100
4.31s: 00088.m2ts: m2ts_id 83, pid_id 0x100
4.31s: 00087.m2ts: m2ts_id 84, pid_id 0x100
4.31s: 00121.m2ts: m2ts_id 85, pid_id 0x100
4.31s: 00086.m2ts: m2ts_id 86, pid_id 0x100
4.31s: 00085.m2ts: m2ts_id 87, pid_id 0x100
4.31s: 00084.m2ts: m2ts_id 88, pid_id 0x100
4.31s: 00083.m2ts: m2ts_id 89, pid_id 0x100
4.31s: 00082.m2ts: m2ts_id 90, pid_id 0x100
4.31s: 00081.m2ts: m2ts_id 91, pid_id 0x100
4.31s: 00080.m2ts: m2ts_id 92, pid_id 0x100
4.31s: 00079.m2ts: m2ts_id 93, pid_id 0x100
4.31s: 00078.m2ts: m2ts_id 94, pid_id 0x100
4.31s: 00077.m2ts: m2ts_id 95, pid_id 0x100
4.31s: 00076.m2ts: m2ts_id 96, pid_id 0x100
4.31s: 00075.m2ts: m2ts_id 97, pid_id 0x100
4.31s: 00074.m2ts: m2ts_id 98, pid_id 0x100
4.31s: 00073.m2ts: m2ts_id 99, pid_id 0x100
4.31s: 00072.m2ts: m2ts_id 100, pid_id 0x100
4.31s: 00071.m2ts: m2ts_id 101, pid_id 0x100
4.31s: 00070.m2ts: m2ts_id 102, pid_id 0x100
4.31s: 00069.m2ts: m2ts_id 103, pid_id 0x100
4.31s: 00068.m2ts: m2ts_id 104, pid_id 0x100
4.31s: 00067.m2ts: m2ts_id 105, pid_id 0x100
4.31s: 00066.m2ts: m2ts_id 106, pid_id 0x100
4.31s: 00065.m2ts: m2ts_id 107, pid_id 0x100
4.31s: 00064.m2ts: m2ts_id 108, pid_id 0x100
4.31s: 00120.m2ts: m2ts_id 109, pid_id 0x100
4.31s: 00063.m2ts: m2ts_id 110, pid_id 0x100
4.31s: 00119.m2ts: m2ts_id 111, pid_id 0x100
4.31s: 00062.m2ts: m2ts_id 112, pid_id 0x100
4.31s: 00061.m2ts: m2ts_id 113, pid_id 0x100
4.31s: 00060.m2ts: m2ts_id 114, pid_id 0x100
4.31s: 00118.m2ts: m2ts_id 115, pid_id 0x100
4.31s: 00059.m2ts: m2ts_id 116, pid_id 0x100
4.31s: 00117.m2ts: m2ts_id 117, pid_id 0x100
4.31s: 00058.m2ts: m2ts_id 118, pid_id 0x100
4.31s: 00116.m2ts: m2ts_id 119, pid_id 0x100
4.31s: 00057.m2ts: m2ts_id 120, pid_id 0x100
4.31s: 00056.m2ts: m2ts_id 121, pid_id 0x100
4.31s: 00055.m2ts: m2ts_id 122, pid_id 0x100
4.31s: 00054.m2ts: m2ts_id 123, pid_id 0x100
4.31s: 00053.m2ts: m2ts_id 124, pid_id 0x100
4.31s: 00052.m2ts: m2ts_id 125, pid_id 0x100
4.31s: 00051.m2ts: m2ts_id 126, pid_id 0x100
4.31s: 00050.m2ts: m2ts_id 127, pid_id 0x100
4.31s: 00049.m2ts: m2ts_id 128, pid_id 0x100
4.31s: 00048.m2ts: m2ts_id 129, pid_id 0x100
4.31s: 00047.m2ts: m2ts_id 130, pid_id 0x100
4.31s: 00046.m2ts: m2ts_id 131, pid_id 0x100
4.31s: 00045.m2ts: m2ts_id 132, pid_id 0x100
4.31s: 00044.m2ts: m2ts_id 133, pid_id 0x100
4.31s: 00043.m2ts: m2ts_id 134, pid_id 0x100
4.31s: 00042.m2ts: m2ts_id 135, pid_id 0x100
4.31s: 00041.m2ts: m2ts_id 136, pid_id 0x100
4.31s: 00040.m2ts: m2ts_id 137, pid_id 0x100
4.31s: 00039.m2ts: m2ts_id 138, pid_id 0x100
4.31s: 00038.m2ts: m2ts_id 139, pid_id 0x100
4.31s: 00000.m2ts: m2ts_id 140, pid_id 0x100
4.31s: 00220.m2ts: m2ts_id 141, pid_id 0x100
4.31s: 00124.m2ts: m2ts_id 142, pid_id 0x100
4.31s: 00122.m2ts: m2ts_id 143, pid_id 0x100
4.31s: 00219.m2ts: m2ts_id 144, pid_id 0x100
4.31s: 00218.m2ts: m2ts_id 145, pid_id 0x100
4.31s: 00217.m2ts: m2ts_id 146, pid_id 0x100
4.31s: 00216.m2ts: m2ts_id 147, pid_id 0x100
4.31s: 00215.m2ts: m2ts_id 148, pid_id 0x100
4.31s: 00214.m2ts: m2ts_id 149, pid_id 0x100
4.31s: 00213.m2ts: m2ts_id 150, pid_id 0x100
4.31s: 00212.m2ts: m2ts_id 151, pid_id 0x100
4.31s: 00211.m2ts: m2ts_id 152, pid_id 0x100
4.31s: 00210.m2ts: m2ts_id 153, pid_id 0x100
4.31s: 00209.m2ts: m2ts_id 154, pid_id 0x100
4.31s: 00208.m2ts: m2ts_id 155, pid_id 0x100
4.31s: 00207.m2ts: m2ts_id 156, pid_id 0x100
4.31s: 00206.m2ts: m2ts_id 157, pid_id 0x100
4.31s: 00205.m2ts: m2ts_id 158, pid_id 0x100
4.31s: 00142.m2ts: m2ts_id 159, pid_id 0x100
4.31s: 00141.m2ts: m2ts_id 160, pid_id 0x100
4.31s: 00181.m2ts: m2ts_id 161, pid_id 0x100
4.31s: 00002.m2ts: m2ts_id 162, pid_id 0x100
4.31s: 00013.m2ts: m2ts_id 163, pid_id 0x100
4.31s: 00011.m2ts: m2ts_id 164, pid_id 0x100
4.31s: 00010.m2ts: m2ts_id 165, pid_id 0x100
4.31s: 00174.m2ts: m2ts_id 166, pid_id 0x100
4.31s: 00022.m2ts: m2ts_id 167, pid_id 0x100
4.31s: 00012.m2ts: m2ts_id 168, pid_id 0x100
4.31s: 00199.m2ts: m2ts_id 169, pid_id 0x100
4.31s: 00198.m2ts: m2ts_id 170, pid_id 0x100
4.31s: 00197.m2ts: m2ts_id 171, pid_id 0x100
4.31s: 00196.m2ts: m2ts_id 172, pid_id 0x100
4.31s: 00155.m2ts: m2ts_id 173, pid_id 0x100
4.31s: 00195.m2ts: m2ts_id 174, pid_id 0x100
4.31s: 00194.m2ts: m2ts_id 175, pid_id 0x100
4.31s: 00192.m2ts: m2ts_id 176, pid_id 0x100
4.31s: 00150.m2ts: m2ts_id 177, pid_id 0x100
4.31s: 00189.m2ts: m2ts_id 178, pid_id 0x100
4.31s: 00187.m2ts: m2ts_id 179, pid_id 0x100
4.31s: 00184.m2ts: m2ts_id 180, pid_id 0x100
4.31s: 00126.m2ts: m2ts_id 181, pid_id 0x100
4.31s: 00183.m2ts: m2ts_id 182, pid_id 0x100
4.31s: 00182.m2ts: m2ts_id 183, pid_id 0x100
4.31s: 00139.m2ts: m2ts_id 184, pid_id 0x100
4.31s: 00173.m2ts: m2ts_id 185, pid_id 0x100
4.31s: 00172.m2ts: m2ts_id 186, pid_id 0x100
4.31s: 00171.m2ts: m2ts_id 187, pid_id 0x100
4.31s: 00170.m2ts: m2ts_id 188, pid_id 0x100
4.31s: 00168.m2ts: m2ts_id 189, pid_id 0x100
4.31s: 00166.m2ts: m2ts_id 190, pid_id 0x100
4.31s: 00165.m2ts: m2ts_id 191, pid_id 0x100
4.31s: 00164.m2ts: m2ts_id 192, pid_id 0x100
4.31s: 00163.m2ts: m2ts_id 193, pid_id 0x100
4.31s: 00161.m2ts: m2ts_id 194, pid_id 0x100
4.31s: 00160.m2ts: m2ts_id 195, pid_id 0x100
4.31s: 00159.m2ts: m2ts_id 196, pid_id 0x100
4.31s: 00204.m2ts: m2ts_id 197, pid_id 0x100
4.31s: 00203.m2ts: m2ts_id 198, pid_id 0x100
4.31s: 00202.m2ts: m2ts_id 199, pid_id 0x100
4.31s: 00201.m2ts: m2ts_id 200, pid_id 0x100
4.31s: 00200.m2ts: m2ts_id 201, pid_id 0x100
4.31s: 00157.m2ts: m2ts_id 202, pid_id 0x100
4.31s: 00156.m2ts: m2ts_id 203, pid_id 0x100
4.31s: 00154.m2ts: m2ts_id 204, pid_id 0x100
4.31s: 00153.m2ts: m2ts_id 205, pid_id 0x100
4.31s: 00152.m2ts: m2ts_id 206, pid_id 0x100
4.31s: 00193.m2ts: m2ts_id 207, pid_id 0x100
4.31s: 00149.m2ts: m2ts_id 208, pid_id 0x100
4.31s: 00191.m2ts: m2ts_id 209, pid_id 0x100
4.31s: 00190.m2ts: m2ts_id 210, pid_id 0x100
4.31s: 00146.m2ts: m2ts_id 211, pid_id 0x100
4.31s: 00188.m2ts: m2ts_id 212, pid_id 0x100
4.31s: 00144.m2ts: m2ts_id 213, pid_id 0x100
4.31s: 00186.m2ts: m2ts_id 214, pid_id 0x100
4.31s: 00143.m2ts: m2ts_id 215, pid_id 0x100
4.31s: 00185.m2ts: m2ts_id 216, pid_id 0x100
4.31s: 00138.m2ts: m2ts_id 217, pid_id 0x100
4.31s: m2ts_size 218
4.98s: Begin remaster
4.99s: GetExHashNode checking directory /BDMV/STREAM/...
4.99s: GetExHashNode returned 00027.m2ts!
dechash:: 48e15802b4e514b4443ca69f8984d2b876b8d442 7.55s:
7.55s: End remaster
7.55s: parse_image took 7 seconds
7.61s:
Number of entries: 234
7.61s: Type: 2
7.61s: From 3297 to 3297, length 1
7.61s: Type: 2
7.61s: From 3300 to 3300, length 1
7.61s: Type: 2
7.61s: From 3302 to 3302, length 1
7.61s: Type: 2
7.61s: From 3304 to 3306, length 3
7.61s: Type: 2
7.61s: From 3307 to 3310, length 4
7.61s: Type: 2
7.61s: From 3311 to 3314, length 4
7.61s: Type: 2
7.61s: From 3315 to 3315, length 1
7.61s: Type: 2
7.61s: From 3317 to 3317, length 1
7.61s: Type: 2
7.61s: From 6051 to 6252, length 202
7.61s: Type: 2
7.61s: From 6253 to 6862, length 610
7.61s: Type: 2
7.61s: From 6863 to 7015, length 153
7.61s: Type: 2
7.61s: From 36733 to 36733, length 1
7.61s: Type: 4
7.61s: From 36768 to 851684, length 814917
7.61s: Type: 4
7.61s: From 851712 to 958169, length 106458
7.61s: Type: 4
7.61s: From 958170 to 994970, length 36801
7.61s: Type: 4
7.61s: From 994976 to 1880029, length 885054
7.61s: Type: 4
7.61s: From 1880032 to 2233179, length 353148
7.61s: Type: 4
7.61s: From 2233180 to 2309850, length 76671
7.61s: Type: 4
7.61s: From 2309856 to 2928188, length 618333
7.61s: Type: 4
7.61s: From 2928192 to 3061553, length 133362
7.61s: Type: 4
7.61s: From 3061554 to 3166916, length 105363
7.61s: Type: 4
7.61s: From 3166944 to 4011467, length 844524
7.61s: Type: 4
7.61s: From 4011488 to 4142560, length 131073
7.61s: Type: 4
7.61s: From 4142561 to 4212808, length 70248
7.61s: Type: 4
7.61s: From 4212832 to 4461084, length 248253
7.61s: Type: 4
7.61s: From 4461085 to 4493703, length 32619
7.61s: Type: 4
7.61s: From 4493728 to 4735116, length 241389
7.61s: Type: 4
7.61s: From 4735117 to 5076555, length 341439
7.61s: Type: 4
7.61s: From 5076556 to 5313129, length 236574
7.61s: Type: 4
7.61s: From 5313152 to 7070170, length 1757019
7.61s: Type: 4
7.61s: From 7070171 to 7103038, length 32868
7.61s: Type: 4
7.61s: From 7103040 to 8185913, length 1082874
7.61s: Type: 4
7.61s: From 8185920 to 8656733, length 470814
7.61s: Type: 4
7.61s: From 8656734 to 9016859, length 360126
7.61s: Type: 4
7.61s: From 9016860 to 9439520, length 422661
7.61s: Type: 4
7.61s: From 9439521 to 9757079, length 317559
7.61s: Type: 4
7.61s: From 9757088 to 10329118, length 572031
7.61s: Type: 4
7.61s: From 10329120 to 10509341, length 180222
7.61s: Type: 4
7.61s: From 10509342 to 10567403, length 58062
7.61s: Type: 4
7.61s: From 10567424 to 10696288, length 128865
7.61s: Type: 4
7.61s: From 10696289 to 10723849, length 27561
7.61s: Type: 4
7.61s: From 10723850 to 10842238, length 118389
7.61s: Type: 4
7.61s: From 10842239 to 10865125, length 22887
7.61s: Type: 4
7.61s: From 10868128 to 11472831, length 604704
7.61s: Type: 4
7.61s: From 11473248 to 11505296, length 32049
7.61s: Type: 4
7.61s: From 11505297 to 11777699, length 272403
7.61s: Type: 4
7.61s: From 11777728 to 12193701, length 415974
7.61s: Type: 4
7.61s: From 12193702 to 12849327, length 655626
7.61s: Type: 4
7.61s: From 12849344 to 12882004, length 32661
7.61s: Type: 4
7.61s: From 12882005 to 13296544, length 414540
7.61s: Type: 4
7.61s: From 13296576 to 13755434, length 458859
7.61s: Type: 4
7.61s: From 13755435 to 14328281, length 572847
7.61s: Type: 4
7.61s: From 14328288 to 14445827, length 117540
7.61s: Type: 4
7.61s: From 14445828 to 14496605, length 50778
7.61s: Type: 4
7.61s: From 14496608 to 20325418, length 5828811
7.61s: Type: 4
7.61s: From 20325440 to 20325607, length 168
7.61s: Type: 4
7.61s: From 20325632 to 20325664, length 33
7.61s: Type: 4
7.61s: From 20325696 to 20325878, length 183
7.61s: Type: 4
7.61s: From 20325888 to 20326082, length 195
7.61s: Type: 4
7.61s: From 20326112 to 20326273, length 162
7.61s: Type: 4
7.61s: From 20326304 to 20326561, length 258
7.61s: Type: 4
7.61s: From 20326592 to 20326771, length 180
7.61s: Type: 4
7.61s: From 20326784 to 20326972, length 189
7.61s: Type: 4
7.61s: From 20326976 to 20327155, length 180
7.61s: Type: 4
7.61s: From 20327168 to 20327332, length 165
7.61s: Type: 4
7.61s: From 20327360 to 20327671, length 312
7.61s: Type: 4
7.61s: From 20327680 to 20327970, length 291
7.61s: Type: 4
7.61s: From 20328000 to 20328254, length 255
7.61s: Type: 4
7.61s: From 20328256 to 20328381, length 126
7.61s: Type: 4
7.61s: From 20328384 to 20329352, length 969
7.61s: Type: 4
7.61s: From 20329376 to 20329534, length 159
7.61s: Type: 4
7.61s: From 20329536 to 20329715, length 180
7.61s: Type: 4
7.61s: From 20329728 to 20329889, length 162
7.61s: Type: 4
7.61s: From 20329920 to 20330057, length 138
7.61s: Type: 4
7.61s: From 20330080 to 20330298, length 219
7.61s: Type: 4
7.61s: From 20330304 to 20330645, length 342
7.61s: Type: 4
7.61s: From 20330656 to 20331906, length 1251
7.61s: Type: 4
7.61s: From 20331936 to 20332106, length 171
7.61s: Type: 4
7.61s: From 20332128 to 20332304, length 177
7.61s: Type: 4
7.61s: From 20332320 to 20332442, length 123
7.61s: Type: 4
7.61s: From 20332448 to 20332726, length 279
7.61s: Type: 4
7.61s: From 20332736 to 20333020, length 285
7.61s: Type: 4
7.61s: From 20333024 to 20333239, length 216
7.61s: Type: 4
7.61s: From 20333248 to 20333520, length 273
7.61s: Type: 4
7.61s: From 20333536 to 20333853, length 318
7.61s: Type: 4
7.61s: From 20333856 to 20335031, length 1176
7.61s: Type: 4
7.61s: From 20335040 to 20335192, length 153
7.61s: Type: 4
7.61s: From 20335200 to 20335340, length 141
7.61s: Type: 4
7.61s: From 20335360 to 20335506, length 147
7.61s: Type: 4
7.61s: From 20335520 to 20335771, length 252
7.61s: Type: 4
7.61s: From 20335776 to 20336015, length 240
7.61s: Type: 4
7.61s: From 20336032 to 20336304, length 273
7.61s: Type: 4
7.61s: From 20336320 to 20336586, length 267
7.61s: Type: 4
7.61s: From 20336608 to 20336751, length 144
7.61s: Type: 4
7.61s: From 20336768 to 20336917, length 150
7.61s: Type: 4
7.61s: From 20336928 to 20337932, length 1005
7.61s: Type: 4
7.61s: From 20337952 to 20338308, length 357
7.61s: Type: 4
7.61s: From 20338336 to 20338533, length 198
7.61s: Type: 4
7.61s: From 20338560 to 20338784, length 225
7.61s: Type: 4
7.61s: From 20338816 to 20339073, length 258
7.61s: Type: 4
7.61s: From 20339104 to 20339469, length 366
7.61s: Type: 4
7.61s: From 20339488 to 20339688, length 201
7.61s: Type: 4
7.61s: From 20339712 to 20340011, length 300
7.61s: Type: 4
7.61s: From 20340032 to 20340229, length 198
7.61s: Type: 4
7.61s: From 20340256 to 20340522, length 267
7.61s: Type: 4
7.61s: From 20340544 to 20340786, length 243
7.61s: Type: 4
7.61s: From 20340800 to 20341015, length 216
7.61s: Type: 4
7.61s: From 20341024 to 20341296, length 273
7.61s: Type: 4
7.61s: From 20341312 to 20342415, length 1104
7.61s: Type: 4
7.61s: From 20342432 to 20342557, length 126
7.61s: Type: 4
7.61s: From 20342560 to 20342691, length 132
7.61s: Type: 4
7.61s: From 20342720 to 20342839, length 120
7.61s: Type: 4
7.61s: From 20342848 to 20343006, length 159
7.61s: Type: 4
7.61s: From 20343008 to 20343151, length 144
7.61s: Type: 4
7.61s: From 20343168 to 20343365, length 198
7.61s: Type: 4
7.61s: From 20343392 to 20344456, length 1065
7.61s: Type: 4
7.61s: From 20344480 to 20344809, length 330
7.61s: Type: 4
7.61s: From 20344832 to 20345077, length 246
7.61s: Type: 4
7.61s: From 20345088 to 20345363, length 276
7.61s: Type: 4
7.61s: From 20345376 to 20345585, length 210
7.61s: Type: 4
7.61s: From 20345600 to 20345746, length 147
7.61s: Type: 4
7.61s: From 20345760 to 20345957, length 198
7.61s: Type: 4
7.61s: From 20345984 to 20347021, length 1038
7.61s: Type: 4
7.61s: From 20347040 to 20347198, length 159
7.61s: Type: 4
7.61s: From 20347200 to 20347376, length 177
7.61s: Type: 4
7.61s: From 20347392 to 20347625, length 234
7.61s: Type: 4
7.61s: From 20347648 to 20347887, length 240
7.61s: Type: 4
7.61s: From 20347904 to 20348185, length 282
7.61s: Type: 4
7.61s: From 20348192 to 20348329, length 138
7.61s: Type: 4
7.61s: From 20348352 to 20348483, length 132
7.61s: Type: 4
7.61s: From 20348512 to 20349636, length 1125
7.61s: Type: 4
7.61s: From 20349664 to 20349894, length 231
7.61s: Type: 4
7.61s: From 20349920 to 20350102, length 183
7.61s: Type: 4
7.61s: From 20350112 to 20350303, length 192
7.61s: Type: 4
7.61s: From 20350304 to 20350510, length 207
7.61s: Type: 4
7.61s: From 20350528 to 20350719, length 192
7.61s: Type: 4
7.61s: From 20350720 to 20350911, length 192
7.61s: Type: 4
7.61s: From 20350912 to 20351121, length 210
7.61s: Type: 4
7.61s: From 20351136 to 20351354, length 219
7.61s: Type: 4
7.61s: From 20351360 to 20351593, length 234
7.61s: Type: 4
7.61s: From 20351616 to 20351795, length 180
7.61s: Type: 4
7.61s: From 20351808 to 20352035, length 228
7.61s: Type: 4
7.61s: From 20352064 to 20352222, length 159
7.61s: Type: 4
7.61s: From 20352224 to 20352409, length 186
7.61s: Type: 4
7.61s: From 20352416 to 20352739, length 324
7.61s: Type: 4
7.61s: From 20352768 to 20352995, length 228
7.61s: Type: 4
7.61s: From 20353024 to 20353356, length 333
7.61s: Type: 4
7.61s: From 20353376 to 20353573, length 198
7.61s: Type: 4
7.61s: From 20353600 to 20353818, length 219
7.61s: Type: 4
7.61s: From 20353824 to 20354012, length 189
7.61s: Type: 4
7.61s: From 20354016 to 20355173, length 1158
7.61s: Type: 4
7.61s: From 20355200 to 20355373, length 174
7.61s: Type: 4
7.61s: From 20355392 to 20355553, length 162
7.61s: Type: 4
7.61s: From 20355584 to 20355754, length 171
7.61s: Type: 4
7.61s: From 20355776 to 20355931, length 156
7.61s: Type: 4
7.61s: From 20355936 to 20356100, length 165
7.61s: Type: 4
7.61s: From 20356128 to 20356286, length 159
7.61s: Type: 4
7.61s: From 20356288 to 20356434, length 147
7.61s: Type: 4
7.61s: From 20356448 to 20356663, length 216
7.61s: Type: 4
7.61s: From 20356672 to 20356875, length 204
7.61s: Type: 4
7.61s: From 20356896 to 20357105, length 210
7.61s: Type: 4
7.61s: From 20357120 to 20357353, length 234
7.61s: Type: 4
7.61s: From 20357376 to 20357534, length 159
7.61s: Type: 4
7.61s: From 20357536 to 20357712, length 177
7.61s: Type: 4
7.61s: From 20357728 to 20357988, length 261
7.61s: Type: 4
7.61s: From 20358016 to 20358183, length 168
7.61s: Type: 4
7.61s: From 20358208 to 20358423, length 216
7.61s: Type: 4
7.61s: From 20358432 to 20358677, length 246
7.61s: Type: 4
7.61s: From 20358688 to 20358882, length 195
7.61s: Type: 4
7.61s: From 20358912 to 20359226, length 315
7.61s: Type: 4
7.61s: From 20359232 to 20360323, length 1092
7.61s: Type: 4
7.61s: From 20360352 to 20360540, length 189
7.61s: Type: 4
7.61s: From 20360544 to 20360762, length 219
7.61s: Type: 4
7.61s: From 20360768 to 20360995, length 228
7.61s: Type: 4
7.61s: From 20361024 to 20361179, length 156
7.61s: Type: 4
7.61s: From 20361184 to 20361345, length 162
7.61s: Type: 4
7.61s: From 20361376 to 20362491, length 1116
7.61s: Type: 4
7.61s: From 20362496 to 20362699, length 204
7.61s: Type: 4
7.61s: From 20362720 to 20363016, length 297
7.61s: Type: 4
7.61s: From 20363040 to 20363213, length 174
7.61s: Type: 4
7.61s: From 20363232 to 20363444, length 213
7.61s: Type: 4
7.61s: From 20363456 to 20363758, length 303
7.61s: Type: 4
7.61s: From 20363776 to 20363970, length 195
7.61s: Type: 4
7.61s: From 20364000 to 20364197, length 198
7.61s: Type: 4
7.61s: From 20364224 to 20364508, length 285
7.61s: Type: 4
7.61s: From 20364512 to 20364721, length 210
7.61s: Type: 4
7.61s: From 20364736 to 20364963, length 228
7.61s: Type: 4
7.61s: From 20364992 to 20365207, length 216
7.61s: Type: 4
7.61s: From 20365216 to 20365371, length 156
7.61s: Type: 4
7.61s: From 20365376 to 20365549, length 174
7.61s: Type: 4
7.61s: From 20365568 to 20365774, length 207
7.61s: Type: 4
7.61s: From 20365792 to 20366028, length 237
7.61s: Type: 4
7.61s: From 20366048 to 20366365, length 318
7.61s: Type: 4
7.61s: From 20366368 to 20366664, length 297
7.61s: Type: 4
7.61s: From 20366688 to 20366810, length 123
7.61s: Type: 4
7.61s: From 20366816 to 20367052, length 237
7.61s: Type: 4
7.61s: From 20367072 to 20368142, length 1071
7.61s: Type: 4
7.61s: From 20368160 to 20368312, length 153
7.61s: Type: 4
7.61s: From 20368320 to 20368592, length 273
7.61s: Type: 4
7.61s: From 20368608 to 20368901, length 294
7.61s: Type: 4
7.61s: From 20368928 to 20369296, length 369
7.61s: Type: 4
7.61s: From 20369312 to 20369530, length 219
7.61s: Type: 4
7.61s: From 20369536 to 20369763, length 228
7.61s: Type: 4
7.61s: From 20369792 to 20370913, length 1122
7.61s: Type: 4
7.61s: From 20370944 to 20371222, length 279
7.61s: Type: 4
7.61s: From 20371232 to 20371564, length 333
7.61s: Type: 4
7.61s: From 20371584 to 20371832, length 249
7.61s: Type: 4
7.61s: From 20371840 to 20372112, length 273
7.61s: Type: 4
7.61s: From 20372128 to 20372355, length 228
7.61s: Type: 4
7.61s: From 20372384 to 20372617, length 234
7.61s: Type: 4
7.61s: From 20372640 to 20372903, length 264
7.61s: Type: 4
7.61s: From 20372928 to 20373173, length 246
7.61s: Type: 4
7.61s: From 20373184 to 20373435, length 252
7.61s: Type: 4
7.61s: From 20373440 to 20373706, length 267
7.61s: Type: 4
7.61s: From 20373728 to 20373973, length 246
7.61s: Type: 4
7.61s: From 20373984 to 20374247, length 264
7.61s: Type: 4
7.61s: From 20374272 to 20374544, length 273
7.61s: Type: 4
7.61s: From 20374560 to 20374817, length 258
7.61s: Type: 4
7.61s: From 20374848 to 20375015, length 168
7.61s: Type: 4
7.61s: From 20375040 to 20375252, length 213
7.61s: Type: 4
7.61s: From 20375264 to 20375458, length 195
7.61s: Type: 4
7.61s: From 20375488 to 20375793, length 306
7.61s: Type: 4
7.61s: From 20375808 to 20375990, length 183
7.61s: Type: 4
7.61s: From 20376000 to 20376197, length 198
7.61s: Type: 4
7.61s: From 20376224 to 20376484, length 261
7.61s: Type: 4
7.61s: From 20376512 to 20377633, length 1122
7.61s: Type: 4
7.61s: From 20377664 to 20378083, length 420
7.61s: Type: 4
7.61s: From 20378112 to 20378531, length 420
7.61s: Type: 4
7.61s: From 20378560 to 20381901, length 3342
7.61s: Type: 4
7.61s: From 20381920 to 20388273, length 6354
7.61s: Type: 4
7.61s: From 20388288 to 20390378, length 2091
7.61s: Type: 4
7.61s: From 20390400 to 20398538, length 8139
7.61s: Type: 4
7.61s: From 20398560 to 20408297, length 9738
7.61s: Type: 4
7.61s: From 20408320 to 20529051, length 120732
7.61s:
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.63s: From 20352768 to 20352995, length 228
7.63s: Type: 4
7.63s: From 20353024 to 20353356, length 333
7.63s: Type: 4
7.63s: From 20353376 to 20353573, length 198
7.63s: Type: 4
7.63s: From 20353600 to 20353818, length 219
7.63s: Type: 4
7.63s: From 20353824 to 20354012, length 189
7.63s: Type: 4
7.63s: From 20354016 to 20355173, length 1158
7.63s: Type: 4
7.63s: From 20355200 to 20355373, length 174
7.63s: Type: 4
7.63s: From 20355392 to 20355553, length 162
7.63s: Type: 4
7.63s: From 20355584 to 20355754, length 171
7.63s: Type: 4
7.63s: From 20355776 to 20355931, length 156
7.63s: Type: 4
7.63s: From 20355936 to 20356100, length 165
7.63s: Type: 4
7.63s: From 20356128 to 20356286, length 159
7.63s: Type: 4
7.63s: From 20356288 to 20356434, length 147
7.63s: Type: 4
7.63s: From 20356448 to 20356663, length 216
7.63s: Type: 4
7.63s: From 20356672 to 20356875, length 204
7.63s: Type: 4
7.63s: From 20356896 to 20357105, length 210
7.63s: Type: 4
7.63s: From 20357120 to 20357353, length 234
7.63s: Type: 4
7.63s: From 20357376 to 20357534, length 159
7.63s: Type: 4
7.63s: From 20357536 to 20357712, length 177
7.63s: Type: 4
7.63s: From 20357728 to 20357988, length 261
7.63s: Type: 4
7.63s: From 20358016 to 20358183, length 168
7.63s: Type: 4
7.63s: From 20358208 to 20358423, length 216
7.63s: Type: 4
7.63s: From 20358432 to 20358677, length 246
7.63s: Type: 4
7.63s: From 20358688 to 20358882, length 195
7.63s: Type: 4
7.63s: From 20358912 to 20359226, length 315
7.63s: Type: 4
7.63s: From 20359232 to 20360323, length 1092
7.63s: Type: 4
7.63s: From 20360352 to 20360540, length 189
7.63s: Type: 4
7.63s: From 20360544 to 20360762, length 219
7.63s: Type: 4
7.63s: From 20360768 to 20360995, length 228
7.63s: Type: 4
7.63s: From 20361024 to 20361179, length 156
7.63s: Type: 4
7.63s: From 20361184 to 20361345, length 162
7.63s: Type: 4
7.63s: From 20361376 to 20362491, length 1116
7.63s: Type: 4
7.63s: From 20362496 to 20362699, length 204
7.63s: Type: 4
7.63s: From 20362720 to 20363016, length 297
7.63s: Type: 4
7.63s: From 20363040 to 20363213, length 174
7.63s: Type: 4
7.63s: From 20363232 to 20363444, length 213
7.63s: Type: 4
7.63s: From 20363456 to 20363758, length 303
7.63s: Type: 4
7.63s: From 20363776 to 20363970, length 195
7.63s: Type: 4
7.63s: From 20364000 to 20364197, length 198
7.63s: Type: 4
7.63s: From 20364224 to 20364508, length 285
7.63s: Type: 4
7.63s: From 20364512 to 20364721, length 210
7.63s: Type: 4
7.63s: From 20364736 to 20364963, length 228
7.63s: Type: 4
7.63s: From 20364992 to 20365207, length 216
7.63s: Type: 4
7.63s: From 20365216 to 20365371, length 156
7.63s: Type: 4
7.63s: From 20365376 to 20365549, length 174
7.63s: Type: 4
7.63s: From 20365568 to 20365774, length 207
7.63s: Type: 4
7.63s: From 20365792 to 20366028, length 237
7.63s: Type: 4
7.63s: From 20366048 to 20366365, length 318
7.63s: Type: 4
7.63s: From 20366368 to 20366664, length 297
7.63s: Type: 4
7.63s: From 20366688 to 20366810, length 123
7.63s: Type: 4
7.63s: From 20366816 to 20367052, length 237
7.63s: Type: 4
7.63s: From 20367072 to 20368142, length 1071
7.63s: Type: 4
7.63s: From 20368160 to 20368312, length 153
7.63s: Type: 4
7.63s: From 20368320 to 20368592, length 273
7.63s: Type: 4
7.63s: From 20368608 to 20368901, length 294
7.63s: Type: 4
7.63s: From 20368928 to 20369296, length 369
7.63s: Type: 4
7.63s: From 20369312 to 20369530, length 219
7.63s: Type: 4
7.63s: From 20369536 to 20369763, length 228
7.63s: Type: 4
7.63s: From 20369792 to 20370913, length 1122
7.63s: Type: 4
7.63s: From 20370944 to 20371222, length 279
7.63s: Type: 4
7.63s: From 20371232 to 20371564, length 333
7.63s: Type: 4
7.63s: From 20371584 to 20371832, length 249
7.63s: Type: 4
7.63s: From 20371840 to 20372112, length 273
7.63s: Type: 4
7.63s: From 20372128 to 20372355, length 228
7.63s: Type: 4
7.63s: From 20372384 to 20372617, length 234
7.63s: Type: 4
7.63s: From 20372640 to 20372903, length 264
7.63s: Type: 4
7.63s: From 20372928 to 20373173, length 246
7.63s: Type: 4
7.63s: From 20373184 to 20373435, length 252
7.63s: Type: 4
7.63s: From 20373440 to 20373706, length 267
7.63s: Type: 4
7.63s: From 20373728 to 20373973, length 246
7.63s: Type: 4
7.63s: From 20373984 to 20374247, length 264
7.63s: Type: 4
7.63s: From 20374272 to 20374544, length 273
7.63s: Type: 4
7.63s: From 20374560 to 20374817, length 258
7.63s: Type: 4
7.63s: From 20374848 to 20375015, length 168
7.63s: Type: 4
7.63s: From 20375040 to 20375252, length 213
7.63s: Type: 4
7.63s: From 20375264 to 20375458, length 195
7.63s: Type: 4
7.63s: From 20375488 to 20375793, length 306
7.63s: Type: 4
7.63s: From 20375808 to 20375990, length 183
7.63s: Type: 4
7.63s: From 20376000 to 20376197, length 198
7.63s: Type: 4
7.63s: From 20376224 to 20376484, length 261
7.63s: Type: 4
7.63s: From 20376512 to 20377633, length 1122
7.63s: Type: 4
7.63s: From 20377664 to 20378083, length 420
7.63s: Type: 4
7.63s: From 20378112 to 20378531, length 420
7.63s: Type: 4
7.63s: From 20378560 to 20381901, length 3342
7.63s: Type: 4
7.63s: From 20381920 to 20388273, length 6354
7.63s: Type: 4
7.63s: From 20388288 to 20390378, length 2091
7.63s: Type: 4
7.63s: From 20390400 to 20398538, length 8139
7.63s: Type: 4
7.63s: From 20398560 to 20408297, length 9738
7.63s: Type: 4
7.63s: From 20408320 to 20529051, length 120732
7.63s: hdtitles
7.68s: Sending Patchlevel 0
7.68s: mode 9247 0x241f
0.08s: ready
0.09s: busy
0.16s: mode 0
0.95s: standard udf
2.08s: AACS!
3.60s: HD type: 1
1953dd33cbdd 4.13s:
39d90b989600 4.13s:
7.55s: End remaster
7.61s:
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s:
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 2
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.61s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: Type: 4
7.63s: hdtitles
AnyDVD HD and CyberlinkPowerDVD11 allow me to choose either video stream.
Blu-ray Converter 1.2.1.7 doesn't see 2 view streams.
1.2.1.7 WORKS The stream selection was a little different - it showed a larger/longer movie that I assumed was the extended version as the main movie. It showed a bonus film about 14 minutes shorter that I assumed was the theatrical version.
It provided a DVD5 output - all seems good. Time for more testing
Certainly wasn't movie lenght.
Inception "Extraction mode" 3hrs10mins22secs.
2011-08-25 17:32:18 Important ****************************************Conversion process : session end****************************************
2011-08-25 17:32:18 Info Conversion process completed successfully
2011-08-25 17:32:17 Info Rendering rate: 1.01 x Realtime
2011-08-25 17:32:17 Info DVD duration (incl. menus) 03:10:55 (~ 11455 sec.) - rendering time 03:09:44
2011-08-25 17:32:17 Info Generated duration 11455.64 sec., expected 11454.08 sec.
2011-08-25 17:31:59 Info 1 subtitles frames encoded in subtitle stream #1
2011-08-25 17:31:59 Info P-SDT buffer Underflow 1 times, 285 bytes peak
2011-08-25 17:26:20 Info Stream #2 - Audio sync at 11021396.38 ms: 10.67 ms removed
2011-08-25 17:22:20 Info Stream #2 - Audio sync at 10806431.04 ms: 10.67 ms removed
2011-08-25 17:14:09 Info Stream #2 - Audio sync at 10441599.04 ms: 10.67 ms removed
2011-08-25 16:44:34 Info Stream #2 - Audio sync at 8953919.04 ms: 10.67 ms removed
2011-08-25 16:30:25 Info Stream #2 - Audio sync at 8108319.04 ms: 10.67 ms removed
2011-08-25 16:05:34 Info Stream #2 - Audio sync at 6616319.04 ms: 10.67 ms removed
2011-08-25 15:37:41 Info Stream #2 - Audio sync at 4960500.38 ms: 10.67 ms removed
2011-08-25 15:36:59 Info Stream #2 - Audio sync at 4922548.38 ms: 10.67 ms removed
2011-08-25 15:09:09 Info Stream #2 - Audio sync at 3188649.71 ms: 10.67 ms removed
2011-08-25 14:55:09 Info Stream #2 - Audio sync at 2326911.04 ms: 10.67 ms removed
2011-08-25 14:52:02 Info Stream #2 - Audio sync at 2102399.04 ms: 10.67 ms removed
2011-08-25 14:33:26 Info Stream #2 - Audio sync at 816447.04 ms: 10.67 ms removed
2011-08-25 14:22:33 Info Stream #2 - Audio sync at 53.33 ms: 52.38 ms added
2011-08-25 14:22:33 Info Output Stream #3 (SUBTITLE) - dvdsub, 64 kb/s
2011-08-25 14:22:33 Info Audio settings: Automatic
2011-08-25 14:22:33 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, flt, 448 kb/s
2011-08-25 14:22:33 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=3-31, 2516 kb/s, pulldown: 23.976 -> 25.00 Fps
2011-08-25 14:22:33 Info Encoding MPEG-2 with 4 threads
2011-08-25 14:22:33 Info Video processing: Lanczos (VSO) resampler (1920*1080)->(720*576) 4 threads
2011-08-25 14:22:33 Info 3 Stream(s) found - est. duration 03:10:22.077, reference 03:10:22.077
2011-08-25 14:22:33 Info Opening file "K:\BDMV\index.bdmv"
2011-08-25 14:22:33 Info Output folder : C:\Users\zebadee\Documents\VSOBlurayConverter\
2011-08-25 14:22:33 Info Maximum target size : 4.30 Gb.
2011-08-25 14:22:33 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2011-08-25 14:22:33 Important ****************************************Conversion process : session start****************************************
2011-08-25 14:22:32 Info Chapters collection will be imported from original structure
2011-08-25 14:22:32 Info Selected DVD menu template : Black Mirror (with chapter text)
2011-08-25 14:22:15 Info No disc in drive.
2011-08-25 14:21:38 Info 9 Menu templates loaded.
2011-08-25 14:21:37 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-08-25 14:21:37 Info Drive has Serial ATA physical interface
2011-08-25 14:21:37 Info New Drive selected : 0:3:0 - Optiarc DVD RW AD-7203S 1.09 [F] (Ide)
2011-08-25 14:21:37 Info New Drive selected : 4:0:0 - TSSTcorp CDDVDW SH-S203N SB02 [J] (Scsi)
2011-08-25 14:21:37 Info New Drive selected : 4:0:0 - HL-DT-ST BDDVDRW GGC-H20L 1.03 [H] (Scsi)
2011-08-25 14:21:37 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-25 14:21:37 Info New Drive selected : 4:0:0 - PIONEER BD-RW BDR-203 1.13 [G] (Scsi)
2011-08-25 14:21:37 Info New Drive selected : 0:2:0 - TSSTcorp CDDVDW SH-S223F SB03 [E] (Ide)
2011-08-25 14:21:37 Info Available Memory : 13090 Mb.
2011-08-25 14:21:37 Info Total Memory : 16378 Mb.
2011-08-25 14:21:37 Info Available extended Virtual Memory : 0 Mb.
2011-08-25 14:21:37 Info Available Virtual Memory : 1815 Mb.
2011-08-25 14:21:37 Info Total Virtual Memory : 2047 Mb.
2011-08-25 14:21:37 Info Memory Load : 35%
2011-08-25 14:21:37 Info Available Physical Memory : 5251 Mb.
2011-08-25 14:21:37 Info Total Physical Memory : 8190 Mb.
2011-08-25 14:21:37 Info System default language : English (United Kingdom)
2011-08-25 14:21:37 Info User default language : English (United Kingdom)
2011-08-25 14:21:37 Info Version : 1.2.1.7
2011-08-25 14:21:37 Info ExeName : C:\Program Files (x86)\vso\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2011-08-25 14:21:37 Info OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2011-08-25 14:21:36 Info Using Advanced SPTI interface
2011-08-25 14:21:35 ---- ******************** Log session start 25-Aug 14:21:35.974 PID 49908********************
Original:-
Conversion:-
Original:-
Hirsperson wrote:...
...cedric wrote:Hi zebadee,
As for quotes.
Are you using the "Quote" button?
If so you must be editing too much from the quote.
You need to the (quote) (/quote) {where the() are in fact [] }
Although a pain.
To sort your problem for now.
Try ripping to HDD (iso.file).
Then use Blu-ray Converter Ultimate.
