No Chapters on DVD
No Chapters on DVD
I'm using version 1.2.1.7, but I've had this problem on the last 2 versions also. When I convert from blu-ray to DVD, I choose the option to keep source chapters. However, the DVD does not have chapters - only 1 "chapter" that is the entire length of the movie.
I have attached a log file.
2011-08-26 11:29:07 ---- ******************** Log session stop 26-Aug 11:29:07.670 PID 6468********************
2011-08-26 11:24:15 Important ****************************************Conversion process : session end****************************************
2011-08-26 11:24:15 Info Conversion process completed successfully
2011-08-26 11:24:14 Info Rendering rate: 4.83 x Realtime
2011-08-26 11:24:14 Info DVD duration (incl. menus) 02:48:30 (~ 10110 sec.) - rendering time 00:34:53
2011-08-26 11:24:14 Info Generated duration 10110.21 sec., expected 10111.10 sec.
2011-08-26 11:24:14 Info 0 subtitles frames encoded in subtitle stream #1
2011-08-26 11:24:14 Info P-SDT buffer Underflow 1 times, 1260 bytes peak
2011-08-26 11:24:14 Info 6 frames duplicated
2011-08-26 11:24:14 Warning No data in subtitle stream #4. Check source file.
2011-08-26 10:49:20 Info Stream #2 - Audio sync at 25.00 ms: 46.71 ms added
2011-08-26 10:49:20 Info Output Stream #4 (SUBTITLE) - dvdsub, 64 kb/s
2011-08-26 10:49:20 Info Audio settings: AC-3, 5.1 Channels
2011-08-26 10:49:20 Info Output Stream #3 (AUDIO) - ac3, 48000 Hz, 5.1, flt, 448 kb/s
2011-08-26 10:49:20 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, flt, 448 kb/s
2011-08-26 10:49:20 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9], q=3-31, 2472 kb/s, pulldown: 23.976 -> 29.97 Fps
2011-08-26 10:49:20 Info Encoding MPEG-2 with 8 threads
2011-08-26 10:49:20 Info Decoding Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9] with 8 threads
2011-08-26 10:49:20 Info Video processing: Lanczos (VSO) resampler (1920*1080)->(720*480) 8 threads
2011-08-26 10:49:20 Info 4 Stream(s) found - est. duration 02:48:31.101, reference 02:48:31.101
2011-08-26 10:49:20 Info Opening file "F:\DVDs\PIRATES3 AT WORLDS END\BDMV\index.bdmv"
2011-08-26 10:49:20 Info Output folder : C:\Users\Mike\Documents\VSOBlurayConverter\
2011-08-26 10:49:20 Info Maximum target size : 4.30 Gb.
2011-08-26 10:49:20 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2011-08-26 10:49:20 Important ****************************************Conversion process : session start****************************************
2011-08-26 10:49:19 Info Chapters collection will be imported from original structure
2011-08-26 10:49:19 Info Selected DVD menu template : No menu
2011-08-26 10:48:38 Info No disc in drive.
2011-08-26 10:48:03 Info 10 Menu templates loaded.
2011-08-26 10:48:02 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2011-08-26 10:48:02 Info Drive has IDE-ATAPI physical interface
2011-08-26 10:48:02 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2011-08-26 10:48:02 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-26 10:48:02 Info Drive has Serial ATA physical interface
2011-08-26 10:48:02 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH30N A102 [E] (Ide)
2011-08-26 10:48:02 Info Available Memory : 22343 Mb.
2011-08-26 10:48:02 Info Total Memory : 24556 Mb.
2011-08-26 10:48:02 Info Available extended Virtual Memory : 0 Mb.
2011-08-26 10:48:02 Info Available Virtual Memory : 1840 Mb.
2011-08-26 10:48:02 Info Total Virtual Memory : 2047 Mb.
2011-08-26 10:48:02 Info Memory Load : 16%
2011-08-26 10:48:02 Info Available Physical Memory : 10299 Mb.
2011-08-26 10:48:02 Info Total Physical Memory : 12278 Mb.
2011-08-26 10:48:02 Info System default language : English (United States)
2011-08-26 10:48:02 Info User default language : English (United States)
2011-08-26 10:48:02 Info Version : 1.2.1.7
2011-08-26 10:48:02 Info ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2011-08-26 10:48:02 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2011-08-26 10:48:01 Info Using Advanced SPTI interface
2011-08-26 10:48:01 ---- ******************** Log session start 26-Aug 10:48:01.049 PID 6468********************
Re: No Chapters on DVD
So, checking 'keep source chapters' doesn't work?
Himikesev wrote:So, checking 'keep source chapters' doesn't work?
Yes & no.
It doesn't appear to work in latest versions, when burning (auto/via Blu-ray Converter).
As I use this to store movies on HDD for media library.
I haven't checked this aspect before.
However, I find that if you want this feature.
As Blu-ray Converter does in fact store the files.
Using an alternative in the burn process.
Whether manual or third party s/w.
This will work for now.
I have no doubt that in the forseeable such glitches will be consigned to history.
- Contact:
Chapters and files are two completely different things. If the converter doesn't create chapters, then there is no way of creating them by doing something in the burn process.
In fact my impression always was that indeed no chapters are created at all, but up to now I was not completely sure if this is an issue with the SW players I tried. I might also add that I'd really like an automatically chapter menu as already supported by ConvertXtoDVD...
The "Keep Source Chapters" option has worked with older versions of the program. It has only been in the last couple of versions where it hasn't worked.
Hi0xdeadbeef wrote:Chapters and files are two completely different things. If the converter doesn't create chapters, then there is no way of creating them by doing something in the burn process.
What you say may well be fact.
"Chapters & files are two completely different things".
I never said otherwise.
But I know if you use a third party DVD progam (Slysoft in my case).
The resulting burned DVD will have have said chapters.
When the Video files are singular they don't.
So if you save "Chapters".
But they are not present in the finalised burnt DVD.
(When using Blu-ray Converter).
Using ClonDVD they will be.
At least in my experience.
So I am saying that the data is there, if selected.
Just does not materialise when using same program to write to disc.
This to me is a glitch.
Which in the short can be worked around.
If the user feels it important enough.
I just burned a copy using the same converted file with Copy To DVD. There were no chapters on this disc either.
chapters have been removed, but will be added back soon.
fixed in 1.2.1.9
