1.2.1.8 Blu to DVD fails saying i canceled every time
BenieUK
Post by BenieUK »
version 1.2.1.8 Blu to DVD fails at very end (ifo building) saying user canceled but i did not, tried a lot of bluray movies and all do the same.
LOG:
2011-08-30 10:10:37 ---- ******************** Log session stop 30-Aug 10:10:37.644 PID 2488********************
2011-08-30 10:10:07 Important ****************************************Conversion process : session end****************************************
2011-08-30 10:08:40 Info Conversion process has been aborted by user
2011-08-30 10:08:39 Error Exception EInvalidPointer [Invalid pointer operation] raised when building IFO's
2011-08-30 10:08:39 Info Generated duration 6760.13 sec., expected 6760.75 sec.
2011-08-30 10:08:39 Info P-SDT buffer Underflow 1 times, 1260 bytes peak
2011-08-30 10:08:39 Info 6 frames duplicated
2011-08-30 10:06:24 Info Chapter #28 start at 105:7.301
2011-08-30 10:05:21 Info Chapter #27 start at 100:55.549
2011-08-30 10:04:38 Info Chapter #26 start at 98:7.882
2011-08-30 10:04:06 Info Chapter #25 start at 95:58.753
2011-08-30 10:03:11 Info Chapter #24 start at 92:30.545
2011-08-30 10:02:08 Info Chapter #23 start at 88:23.798
2011-08-30 10:00:59 Info Chapter #22 start at 83:48.523
2011-08-30 10:00:08 Info Chapter #21 start at 80:23.819
2011-08-30 09:59:14 Info Chapter #20 start at 76:55.110
2011-08-30 09:57:37 Info Chapter #19 start at 70:50.246
2011-08-30 09:56:58 Info Chapter #18 start at 68:21.097
2011-08-30 09:56:18 Info Chapter #17 start at 65:43.940
2011-08-30 09:55:17 Info Chapter #16 start at 61:51.708
2011-08-30 09:54:16 Info Chapter #15 start at 58:4.981
2011-08-30 09:52:55 Info Chapter #14 start at 52:52.669
2011-08-30 09:51:36 Info Chapter #13 start at 47:51.869
2011-08-30 09:50:57 Info Chapter #12 start at 45:22.219
2011-08-30 09:50:03 Info Chapter #11 start at 41:56.514
2011-08-30 09:49:29 Info Chapter #10 start at 39:51.889
2011-08-30 09:48:38 Info Chapter #9 start at 36:46.704
2011-08-30 09:47:27 Info Chapter #8 start at 32:20.939
2011-08-30 09:46:06 Info Chapter #7 start at 27:14.633
2011-08-30 09:44:14 Info Chapter #6 start at 20:6.705
2011-08-30 09:43:00 Info Chapter #5 start at 15:22.922
2011-08-30 09:42:07 Info Chapter #4 start at 11:58.718
2011-08-30 09:40:57 Info Chapter #3 start at 7:37.457
2011-08-30 09:40:09 Info Chapter #2 start at 4:28.768
2011-08-30 09:38:59 Info Stream #2 - Audio sync at 53.33 ms: 52.38 ms added
2011-08-30 09:38:59 Info Audio settings: AC-3, 5.1 Channels
2011-08-30 09:38:59 Info Output Stream #2 (AUDIO) - ac3, 48000 Hz, 5.1, flt, 448 kb/s
2011-08-30 09:38:59 Info Output Stream #1 (VIDEO) - mpeg2video, yuv420p, 720x480 [SAR 32:27 DAR 16:9], q=3-31, 4603 kb/s, pulldown: 23.976 -> 29.97 Fps
2011-08-30 09:38:59 Info Encoding MPEG-2 with 8 threads
2011-08-30 09:38:59 Info Decoding Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9] with 8 threads
2011-08-30 09:38:59 Info Video processing: Lanczos (VSO) resampler (1920*1080)->(720*480) 8 threads
2011-08-30 09:38:59 Info 2 Stream(s) found - est. duration 01:52:40.754, reference 01:52:40.754
2011-08-30 09:38:59 Info Opening file "V:\BDMV\index.bdmv"
2011-08-30 09:38:59 Info Output folder : C:\Users\Admin\Temp
2011-08-30 09:38:59 Info Maximum target size : 4.30 Gb.
2011-08-30 09:38:59 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2011-08-30 09:38:59 Important ****************************************Conversion process : session start****************************************
2011-08-30 09:38:58 Info Chapters collection will be imported from original structure
2011-08-30 09:38:58 Info Selected DVD menu template : No menu
2011-08-30 09:38:53 Info No disc in drive.
2011-08-30 09:38:10 Info 9 Menu templates loaded.
2011-08-30 09:38:09 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2011-08-30 09:38:09 Info Drive has Serial ATA physical interface
2011-08-30 09:38:09 Info New Drive selected : 0:0:0 - PIONEER BD-RW BDR-205 1.12 [D] (Ide)
2011-08-30 09:38:09 Info Available Memory : 10902 Mb.
2011-08-30 09:38:09 Info Total Memory : 12268 Mb.
2011-08-30 09:38:09 Info Available extended Virtual Memory : 0 Mb.
2011-08-30 09:38:09 Info Available Virtual Memory : 1826 Mb.
2011-08-30 09:38:09 Info Total Virtual Memory : 2047 Mb.
2011-08-30 09:38:09 Info Memory Load : 13%
2011-08-30 09:38:09 Info Available Physical Memory : 5285 Mb.
2011-08-30 09:38:09 Info Total Physical Memory : 6135 Mb.
2011-08-30 09:38:09 Info System default language : English (United Kingdom)
2011-08-30 09:38:09 Info User default language : English (United Kingdom)
2011-08-30 09:38:09 Info Version : 1.2.1.8
2011-08-30 09:38:09 Info ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2011-08-30 09:38:09 Info OS : Microsoft Windows 7 Ultimate (Build 7601: Service Pack 1)
2011-08-30 09:38:08 Info Using Advanced SPTI interface
Re: 1.2.1.8 Blu to DVD fails saying i canceled every time
problem confirmed, will be fixed soon
