Bug with 1.2.1.11 beta & loading ISO images
Drag-and-drop of ISOs is not working properly in v1.2.1.11 beta. Try dragging any DVD ISO image into the program and you'll receive a message stating, "Selected HD structure doesn't contain any valid video stream." Well, of course not. It's a DVD and not HD material. This is easily reproduced with any ISO image I tried to load into the program.
Loading from a physical optical drive, virtual drive, or loading from a folder works without issue.
Re: Bug with 1.2.1.11 beta & loading ISO images
Does it work on previous versions?
ISO is container, how about opening/mounting that ISO and the drag contents of it to program?
Yes, if the ISO is mounted it can then be dragged into the program. Of course, needing to mount the image before adding the contents into the program defeats the purpose of the program supporting drag-and-drop of ISO images which works properly in other VSO products such as VSO Blu-ray Converter.JJ wrote:Does it work on previous versions?
Yes, it did. It worked with v1.2.1.2 alpha, 1.2.1.7 beta and 1.2.1.8 beta. This is the first update since 1.2.1.8 beta that I have so the problem is new.JJ wrote:Does it work on previous versions?
Issue is also present in 1.2.1.14.
I have reported the problem about not being able to load DVD ISO files here
http://bugs.vso-software.fr/view.php?id=4829
Hopefully it will be corrected in the next version.
Thank you, Claire.Claire wrote:Hi,
Problem fixed in last beta version (1.2.1.17).
Will be available today...
Thanks!
Thanks!
Errrr... it isn't a complete fix. If you click on the DVD icon to load the structure and use the drop-down menu and then select to load an ISO image it does work. If you drag-and-drop an ISO from Windows Explorer onto the VSO DVD Converter window then absolutely nothing happens at all. It ignores it completely. This behavior is unexpected and different when compared to other VSO products. The problem is partially resolved but not completely.
Sorry, I'm not trying to be a pain. I'm a gold member, too. I just want to help out with making things work as they should.
you are no pain at all, we appreciate you reporting.
