Copy dvd encrypted?
calcu007
Copy dvd encrypted?
Post by calcu007 »
DVD converted detected as encrypted and invalid dvd structure a copy DVD of the movie Thor. I made the copy using AnyDVd and CloneDVD. If I use the backup dvd with anydvd in background then there is not problem, but if I insert the backup dvd without anydvd running then the error message appears. The backup dvd IS NOT protected. Also if I copy the files of the backup to my computer, dvd converter open then without problem.
Re: Copy dvd encrypted?
thanks for reporting.
It has been confirmed
http://bugs.vso-software.fr/view.php?id=4837
Problem fixed in last beta version (1.2.1.21) :
http://forums.vso-software.fr/blu-ray-c ... s-f36.html
Thank you for your help!
