dvd to divx
zarkomod
dvd to divx
Post by zarkomod »
Please help me to convert my DVD to divx. I have just bought the latest DVD Concerter and it simly do not show the option of converting to divx. I bought is specifically to this operation.
jtk174
Re: dvd to divx
Post by jtk174 »
Divx isn't specifically listed but Xvid is and hopefully that will do your job. Once you have loaded your file to convert, pick generic avi, then on the next screen use the drop down box/icon to select your codec, in this case Xvid and whatever resolution option you want.
Hope that helps.
BTW I recommend u using the .21 beta rather than .19 as it fixes several annoying bugs that I had been experiencing.
