Query about high compatibility
Frederik
Post by Frederik »
Beta 1.1.1.6
The "encode AVI with high compatibility video/audio settings" does not seem to work? Should they?
Selection of either option ALWAYS fails to work?
See log attached with error "Error while preparing input/output contexts. Conversion can't start".
BR_and_DVD_Converters_crash_PID1064.log
(5.14 KiB) Downloaded 353 times
Re: Query about high compatibility
I reproduced then fixed your problem...
It only appear when high compatibility Audio setting is enabled AND output format request multichannel (like HD Ready & Full HD format, no problem with low resolution formats...).
In high compatibility audio mode, an old codec is used and doesn't support multichannel.
If you want to keep multichannel, I think you should try to disable this option BUT setting high compatibility video setting ON to see if your DivX player is able to play it.
This fix will be available in next beta version (1.2.2.7), coming in less than one hour.
Please check http://forums.vso-software.fr/dvd-converter-t14598.html post soon...
Thank you for your help!
Frederik
Post by Frederik »
Hi Cedric,
Thanks for your prompt reply.
I did not read your reply properly and set both high compatibility for audio and video in v 1.2.2.7 and got very confusing results? I have converted several DVDs thinking that everything was fine?
I had not seen the popup information under hight compatibility mode being relevant to divx and didn't really know what it was.
An avi was produced that plays properly in Nero Kwik media player but plays with absolutely non-synchronised sound in divx player. I can't even figure out where the sound comes from it is so much out of whack? i have never had problems with divx and do not know how valid the file is?
The log is a bit strange as well - the highlighted coloured sections contradict each other?
[2011-10-14 09:30:50 Info Conversion process completed successfully
2011-10-14 08:23:37 Info Converting track #2 : [AUDIO: ac3 48000Hz - 6 channels - 32bits] to [AUDIO: AC3 - 6 channels - 48000Hz - 448.000Kb/s]
2011-10-14 08:23:37 Info Converting track #1 : [VIDEO: mpeg-2_cuda - 720x576] to [VIDEO: MSMPEG4V3 - 1280x720 - 3.837Mb/s]
2011-10-14 08:23:37 Info Output file details : 1 video stream(s), 1 audio stream(s), 0 subtitle stream(s)
2011-10-14 08:23:37 Info Starting to encode Main title (Default) output file with [Generic video (AVI) HD Ready (720p) Xvid] profile
2011-10-14 08:23:37 Info Only one file to encode
2011-10-14 08:23:37 Info Output folder : C:\Documents\VSODVDConverter\
2011-10-14 08:23:37 Info Maximum target size : 4.30 Gb.
2011-10-14 08:23:37 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2011-10-14 08:23:37 Important ****************************************Conversion process : session start****************************************
2011-10-14 08:23:36 Error Error while preparing input/output contexts. Conversion can't start[/color]
Any clues - is the fault with the divx player?
BR_and_DVD_Converters.log
(79.02 KiB) Downloaded 383 times
Line "2011-10-14 08:23:36 Error Error while preparing input/output contexts. Conversion can't start"
was a false information, corrected in next 1.2.2.8 version...
Thank you for your feedback.
