Still cannot open 'V' Disc 2, list index out of bounds (1) ?
BenieUK
Post by BenieUK »
I have the series 'V' Season 1 UK, Disc 1 opens fine but Disc 2 i just get error : list index out of bounds (1)
Can this be fixed ?
PS. Good work on fixing most of the other bugs, this software is getting very stable now. Thank You :)
Re: Still cannot open 'V' Disc 2, list index out of bounds (
is this a problem with version 1.3.0.0?
BenieUK
Post by BenieUK »
Yes still a problem with newest update
this is with a physical disk in your optical drive?
Just to test, can you try by ripping the DVD on your HDD first, then convert?
Thank you!
BenieUK
Post by BenieUK »
I have tried from disc and ripped to hdd, still same problem.. disc 1 is ok but disc 2 not.
ok thanks I will try and reproduce
Can you post a screenshot of not only the error but with the main interface of the converter behind the error message? Thanks
umbrella72
Post by umbrella72 »
Im currently running Blu-ray converter ultimatum 1.3.0.0 and getting error “list index out of bounds (1)”.
I used CleanVSO.exe to completely remove all existing files of the program.
And after that i did a new install and everything worked perfectly.
The program to do this can be found here: http://download2.vso-software.fr/CleanVSO.exe
thanks for your report umbrella72
BenieUK
Post by BenieUK »
This is not solved, i tried the VSO clean software.. restarted pc and re-installed from start, the problem remains.
Please, can you provide more details about this disk?
I think we must buy it to reproduce...
Thanks you!
This is fixed in version 1.3.0.2 that is now available.
BenieUK
Post by BenieUK »
Thank you Claire this is fixed now :)
ok great thank you!
