Any one ??
In the mean while i have try`ed older versions, the last 2 versions gives me access violation.
All versions i still could find starts up fine but are not working.
One version i can only select to convert dvd.
Mkv,avi, etc.. are simply not in the program.
Another problem is that none of the other version will convert, it just says "list index out of bound (-1)" or will go to the next screen and then "checking files please wait" then nothing.
Or an error has occured with a log file about acces violation at addres 773c8da9 in module ntdll.dll.
Will there be a new version soon ?
When i bought the program it worked, allthought there was a little bit of a sync issue, with everthing that was coverted.
Then all new version after that ,i was getting the feeling that i got more problems with the program then before.
Problems were solved but new ones were born.
