Still having slight sync problems with 1.3.0.1. tried a few movies like avatar etc. and there still small sync problems.
Playstation 3 1080p cuda, no size limit, windows 7 64bit.
not tried other profiles.
Still sync problem with 1.3.0.1
Re: Still sync problem with 1.3.0.1
Thanks for your report.
I am sorry I did not reply faster, but with the 24hours you posted we tested and did see some problems, and despite what we see translates to something different than audio/sync the core issue is probably the same.
It has been reported here:
http://bugs.vso-software.fr/view.php?id=4892
I've tried myself and I do not get audio / video sync issues. Are you sure your computer has enough resources to read the file generated?
