I have an original "Sopranos" series season 1 nordic Blu-Ray, which I've copied to hard via SlySoft AnyDVD HD. When entering Converter (1.4.0.8) and drag-dropping the folder, it shows me only possibilities as in attached picture:
[img]http://aijaa.com/002699271633.jpg[/img]
[url]http://aijaa.com/002699271633.jpg[/url]
When attached to DVDFab (same folder), it shows all the subtitles and audio sources it should:
[img]http://aijaa.com/007549271634.jpg[/img]
[url]http://aijaa.com/007549271634.jpg[/url]
Current Converter version doesn't show the audio nor subtitles it should.
"Sopranos" series Blu-Ray not showing all possibilities
Re: "Sopranos" series Blu-Ray not showing all possibilities
This should be fixed in the next version.
Thanks for reporting.
