Hello :-)
First of all, HAPPY NEW YEAR! :-)
I got a problem running Blu-Ray Converter in Windows 7 64bit. When I try encoding a Bluray into a MKV using MPEG / H264 / H264 CUDA encoder, i got the error shown in the log file below. I tried reinstalling, compatibility mode XP or Vista, nothing works, always the same error. Funny thing is, i still got Vista 64bit parallely installed on the same PC and there the program works like a charm.
So I think it got to be a Windows 7 64bit related problem?!
Thanx in advance for any help :-)
Greetz, n0f34r
2012-01-05 11:36:54 Info 9 Menüvorlagen geladen.
2012-01-05 11:36:48 Important ****************************************Conversion process : session end****************************************
2012-01-05 11:36:48 Info An error occured while converting
2012-01-05 11:36:48 Info 2 files to encode
2012-01-05 11:36:48 Info Output folder : D:\MKV
2012-01-05 11:36:48 Info Maximum target size : 8,30 Gb.
2012-01-05 11:36:48 Info Video quality selected : Best quality. Resize filter used for video : Windowed sinc Lanczos (VSO)
2012-01-05 11:36:48 Important ****************************************Conversion process : session start****************************************
2012-01-05 11:36:48 Error Error while preparing input/output contexts. Conversion can't start
2012-01-05 11:36:48 Error Encoder engine can't be initialized. Please check installation files or try to reinstall
2012-01-05 11:36:48 Info AV LOADER: File "index.bdmv" probed format is Any file in a Blu-Ray/AVCHD structure
2012-01-05 11:36:45 Info 9 Menu templates loaded.
2012-01-05 11:36:33 Info Video structure loaded successfully from:D:\MKV\Der Pianist\PIANIST_BD\BDMV\index.bdmv
2012-01-05 11:36:29 Info No disc in drive.
2012-01-05 11:36:28 Info 9 Menüvorlagen geladen.
2012-01-05 11:36:27 Info Available Memory : 18758 Mb.
2012-01-05 11:36:27 Info Total Memory : 20475 Mb.
2012-01-05 11:36:27 Info Available extended Virtual Memory : 0 Mb.
2012-01-05 11:36:27 Info Available Virtual Memory : 1815 Mb.
2012-01-05 11:36:27 Info Total Virtual Memory : 2047 Mb.
2012-01-05 11:36:27 Info Memory Load : 19%
2012-01-05 11:36:27 Info Available Physical Memory : 6563 Mb.
2012-01-05 11:36:27 Info Total Physical Memory : 8191 Mb.
2012-01-05 11:36:27 Info System default language : Deutsch (Deutschland)
2012-01-05 11:36:27 Info User default language : Deutsch (Deutschland)
2012-01-05 11:36:27 Info Version : 1.4.0.8
2012-01-05 11:36:27 Info ExeName : C:\Program Files (x86)\vso\Blu-ray Converter Ultimate\BlurayConverterUltimate.exe
2012-01-05 11:36:27 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
2012-01-05 11:36:27 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-01-05 11:36:27 Info Drive has Serial ATA physical interface
2012-01-05 11:36:27 Info New Drive selected : 8:0:0 - SAMSUNG DVDWBD SH-B083L SB00 [F] (Ide)
2012-01-05 11:36:27 Info Drive has IDE-ATAPI physical interface
2012-01-05 11:36:27 Info New Drive selected : 0:0:0 - HL-DT-ST DVDRAM GSA-4160B A306 [G] (Ide)
2012-01-05 11:36:27 Info Using Advanced SPTI interface
2012-01-05 11:36:27 ---- ******************** Log session start 05-Jan 11:36:27.118 PID 1596********************
Encoder engine can't be initialized. (Windows 7)
Re: Encoder engine can't be initialized. (Windows 7)
Problem solved!
In my Windows 7 the DEP (Data Execution Prevention) is enabled for every program.
The Blu-Ray Converter EXE has to be in the exception list.
If it isnt, this error occurs.
Thank you n0f34r! That answered the problem I was having with Server 2008 R2 as well! Cheers!
