Audio controls
Tsattler
Audio controls
Post by Tsattler »
I like the program except for one major issue, audio controls, no graphic equalizer, nothing to adjust tone period :evil: . This is a major issue, no one would by an amp or reciever that they couldn't control the bass and treble at least, most have tons of presets like KMplayer or even Windows Media player.
Also not being able to change the screen sizes is a drawback, not critical but a drawback.
felicia
Re: Audio controls
Post by felicia »
Yes, a graphic equalizer would be a plus, we've just implemented a boost for sound in our latest version that you can find here.
What do you mean by ?
Felicià
Tsattler
Re: Audio controls
Post by Tsattler »
I mean that there is a very large black space top and bottom, very large, in other programs you can expand the image to better fit the screen size.
Tsattler
Re: Audio controls
Post by Tsattler »
boost for sound? I just checked the update and didn't see anything at all anywhere.
felicia
Re: Audio controls
Post by felicia »
Tsattler wrote:I mean that there is a very large black space top and bottom, very large, in other programs you can expand the image to better fit the screen size.
Could you upload a screen shot?
Are you talking in full screen or in mormal mode.
felicia
Re: Audio controls
Post by felicia »
Tsattler wrote:boost for sound? I just checked the update and didn't see anything at all anywhere.
It's transparent it's activate once you push sound over 100%, there's a small delay and then the sound is boosted gradually.
To test it, just move the sound from 100% to 200% and wait a little while a movie is playing.
Tsattler
Re: Audio controls
Post by Tsattler »
Well I am going to hold off using it until there is some real control of the audio, as I mentioned a graphic equalizer or something similar.
