Audio and video not in sync
I have attached log file. The audio is not in sync with the video. Using version 1.4.0.8.
- BR_and_DVD_Converters.log
- (26.94 KiB) Downloaded 630 times
Re: Audio and video not in sync
We are working on a new encoder engine and I think your issue will be fixed in next release.
Please check when a new beta version of converters (version 2) is out to test it...
Thank you!
Thank you!
Hi Cedric -
When will version2 be available with DVD video output?
DVD output works here, but we are working on DVD menu at this time...
Hi Cedric
I installed and activated version 2. First attempt at DVD video resulted in an error.
Here is the log file
2012-03-24 10:06:29 Info An error occured while converting
2012-03-24 10:06:29 Info Converted project will be burnt using D: drive
2012-03-24 10:06:29 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-24 10:06:29 Info Drive has IDE-ATAPI physical interface
2012-03-24 10:06:29 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2012-03-24 10:06:18 Info Writable disc DVD+R inserted. Ready to write
2012-03-24 10:06:17 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-24 10:06:17 Info Drive has IDE-ATAPI physical interface
2012-03-24 10:06:17 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2012-03-24 10:06:17 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu
Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2012-03-24 10:06:17 Info Drive has Serial ATA physical interface
2012-03-24 10:06:17 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH30N A102 [E] (Ide)
2012-03-24 10:06:10 Info Writable disc DVD+R inserted. Ready to write
2012-03-24 10:06:00 Info Parsing disc ...
2012-03-24 10:05:42 Info Video structure loaded successfully from:F:\DVDs\TOWER_HEIST\BDMV\index.bdmv
2012-03-24 10:05:16 Info No disc in drive.
2012-03-24 10:05:16 Info 9 Menu templates loaded.
2012-03-24 10:05:15 Info Available Memory : 21706 Mb.
2012-03-24 10:05:15 Info Total Memory : 24556 Mb.
2012-03-24 10:05:15 Info Available extended Virtual Memory : 0 Mb.
2012-03-24 10:05:15 Info Available Virtual Memory : 1857 Mb.
2012-03-24 10:05:15 Info Total Virtual Memory : 2047 Mb.
2012-03-24 10:05:15 Info Memory Load : 20%
2012-03-24 10:05:15 Info Available Physical Memory : 9746 Mb.
2012-03-24 10:05:15 Info Total Physical Memory : 12278 Mb.
2012-03-24 10:05:15 Info System default language : English (United States)
2012-03-24 10:05:15 Info User default language : English (United States)
2012-03-24 10:05:15 Info Version : 2.0.0.3
2012-03-24 10:05:15 Info ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\2\BlurayConverterUltimate.exe
2012-03-24 10:05:15 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2012-03-24 10:05:15 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-24 10:05:15 Info Drive has IDE-ATAPI physical interface
2012-03-24 10:05:15 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2012-03-24 10:05:15 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu
2012-03-24 10:05:15 Info Drive has Serial ATA physical interface
2012-03-24 10:05:15 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH30N A102 [E] (Ide)
2012-03-24 10:05:14 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-24 10:05:14 Info Drive has IDE-ATAPI physical interface
2012-03-24 10:05:14 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2012-03-24 10:05:14 Info Using Advanced SPTI interface
2012-03-24 10:05:13 ---- ******************** Log session start 24-Mar 10:05:13.694 PID 1328**************
Hi -
I installed version 2.0.0.4 and tried to convert to DVD again. Got a scrambled picture instead.
here is the log file:
2012-03-29 11:16:44 Info No disc in drive.
2012-03-29 11:16:44 Info 9 Menu templates loaded.
2012-03-29 11:16:43 Info Available Memory : 22153 Mb.
2012-03-29 11:16:43 Info Total Memory : 24556 Mb.
2012-03-29 11:16:43 Info Available extended Virtual Memory : 0 Mb.
2012-03-29 11:16:43 Info Available Virtual Memory : 1854 Mb.
2012-03-29 11:16:43 Info Total Virtual Memory : 2047 Mb.
2012-03-29 11:16:43 Info Memory Load : 16%
2012-03-29 11:16:43 Info Available Physical Memory : 10227 Mb.
2012-03-29 11:16:43 Info Total Physical Memory : 12278 Mb.
2012-03-29 11:16:43 Info System default language : English (United States)
2012-03-29 11:16:43 Info User default language : English (United States)
2012-03-29 11:16:43 Info Version : 2.0.0.4
2012-03-29 11:16:43 Info ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\2\BlurayConverterUltimate.exe
2012-03-29 11:16:43 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2012-03-29 11:16:43 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-29 11:16:43 Info Drive has IDE-ATAPI physical interface
2012-03-29 11:16:43 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2012-03-29 11:16:43 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu
2012-03-29 11:16:43 Info Drive has Serial ATA physical interface
2012-03-29 11:16:43 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH30N A102 [E] (Ide)
2012-03-29 11:16:42 Info Using Advanced SPTI interface
2012-03-29 11:16:42 ---- ******************** Log session start 29-Mar 11:16:42.322 PID 6300********************
2012-03-29 11:14:19 ---- ******************** Log session stop 29-Mar 11:14:19.283 PID 3692********************
2012-03-29 11:08:02 Info Conversion process completed successfully
2012-03-29 10:25:51 Info Video structure loaded successfully from:F:\DVDs\TOWER_HEIST\BDMV\index.bdmv
2012-03-29 10:25:17 Info No disc in drive.
2012-03-29 10:25:16 Info 9 Menu templates loaded.
2012-03-29 10:25:15 Info Available Memory : 22176 Mb.
2012-03-29 10:25:15 Info Total Memory : 24556 Mb.
2012-03-29 10:25:15 Info Available extended Virtual Memory : 0 Mb.
2012-03-29 10:25:15 Info Available Virtual Memory : 1854 Mb.
2012-03-29 10:25:15 Info Total Virtual Memory : 2047 Mb.
2012-03-29 10:25:15 Info Memory Load : 17%
2012-03-29 10:25:15 Info Available Physical Memory : 10110 Mb.
2012-03-29 10:25:15 Info Total Physical Memory : 12278 Mb.
2012-03-29 10:25:15 Info System default language : English (United States)
2012-03-29 10:25:15 Info User default language : English (United States)
2012-03-29 10:25:15 Info Version : 2.0.0.4
2012-03-29 10:25:15 Info ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\2\BlurayConverterUltimate.exe
2012-03-29 10:25:15 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2012-03-29 10:25:15 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-03-29 10:25:15 Info Drive has IDE-ATAPI physical interface
2012-03-29 10:25:15 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2012-03-29 10:25:15 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu
2012-03-29 10:25:15 Info Drive has Serial ATA physical interface
2012-03-29 10:25:15 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH30N A102 [E] (Ide)
2012-03-29 10:25:15 Info Using Advanced SPTI interface
2012-03-29 10:25:14 ---- ******************** Log session start 29-Mar 10:25:14.795 PID 3692********************
I tried to attach completed DVD file but could not.
Is there any update on this problem?
Hi-
I tried again today using 2.0.0.6. I have attached the log file and a screen print of the Video_TS file which shows what the result was.
2012-04-07 09:58:07 ---- ******************** Log session stop 07-Apr 09:58:07.884 PID 6560********************
2012-04-07 09:47:15 Info *** File encoded successfully:: VTS_01_1.VOB - DVD NTSC 16/9 ***
2012-04-07 09:01:25 Info *** File encoded successfully:: VTS_02_1.VOB - DVD NTSC 16/9 ***
2012-04-07 08:58:24 Info *** File encoded successfully:: VTS_03_1.VOB - DVD NTSC 16/9 ***
2012-04-07 08:57:40 Info ************* VTS_03_1.VOB: DVD - NTSC 16/9 *************
2012-04-07 08:57:40 Info [audio: #1 - ac3 main audio, 48000 kHz, 2 Ch., 192 kbps [English]] -> [audio ]
2012-04-07 08:57:40 Info [video: #0 - h264 video, 1920x1080, YUV420P, 1.00] -> [video ]
2012-04-07 08:57:40 Info ***********************************************************
2012-04-07 08:57:38 Info ************* VTS_02_1.VOB: DVD - NTSC 16/9 *************
2012-04-07 08:57:38 Info [audio: #1 - ac3 main audio, 48000 kHz, 2 Ch., 192 kbps [English]] -> [audio ]
2012-04-07 08:57:38 Info [video: #0 - h264 video, 1920x1080, YUV420P, 1.00] -> [video ]
2012-04-07 08:57:38 Info ***********************************************************
2012-04-07 08:57:38 Info ************* VTS_01_1.VOB: DVD - NTSC 16/9 *************
2012-04-07 08:57:38 Info [audio: #1 - ac3 main audio, 0 kHz, 0 Ch. [English]] -> [audio ]
2012-04-07 08:57:02 Info Video structure loaded successfully from:F:\DVDs\TGW_KICKED_THE_HORNETS_NEST\BDMV\index.bdmv
2012-04-07 08:55:57 Info No disc in drive.
2012-04-07 08:55:57 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-04-07 08:55:57 Info Drive has IDE-ATAPI physical interface
2012-04-07 08:55:57 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2012-04-07 08:55:57 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2012-04-07 08:55:57 Info Drive has Serial ATA physical interface
2012-04-07 08:55:57 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH30N A102 [E] (Ide)
2012-04-07 08:55:38 Info 9 Menu templates loaded.
2012-04-07 08:55:37 Info No disc in drive.
2012-04-07 08:55:36 Info Available Memory : 22293 Mb.
2012-04-07 08:55:36 Info Total Memory : 24556 Mb.
2012-04-07 08:55:36 Info Available extended Virtual Memory : 0 Mb.
2012-04-07 08:55:36 Info Available Virtual Memory : 1862 Mb.
2012-04-07 08:55:36 Info Total Virtual Memory : 2047 Mb.
2012-04-07 08:55:36 Info Memory Load : 16%
2012-04-07 08:55:36 Info Available Physical Memory : 10278 Mb.
2012-04-07 08:55:36 Info Total Physical Memory : 12278 Mb.
2012-04-07 08:55:36 Info System default language : English (United States)
2012-04-07 08:55:36 Info User default language : English (United States)
2012-04-07 08:55:36 Info Version : 2.0.0.6
2012-04-07 08:55:36 Info ExeName : C:\Program Files (x86)\VSO\Blu-ray Converter Ultimate\2\BlurayConverterUltimate.exe
2012-04-07 08:55:36 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
2012-04-07 08:55:36 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R
2012-04-07 08:55:36 Info Drive has IDE-ATAPI physical interface
2012-04-07 08:55:36 Info New Drive selected : 0:0:0 - HL-DT-ST DVD+-RW GH50N B104 [D] (Ide)
2012-04-07 08:55:36 Info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R, DL DVD-R, Blu Ray-R Seq., Blu Ray-R Rnd., Blu Ray-RE
2012-04-07 08:55:36 Info Drive has Serial ATA physical interface
2012-04-07 08:55:36 Info New Drive selected : 0:1:0 - HL-DT-ST BD-RE BH30N A102 [E] (Ide)
2012-04-07 08:55:35 Info Using Advanced SPTI interface
2012-04-07 08:55:34 ---- ******************** Log session start 07-Apr 08:55:34.486 PID 6560********************
so that is what you mean by scrambled picture?
Yes - didn't know what else to call it. The thumbnail is what the picture looks like when I attempt to play the file back. I couldn't attach the complete converted file.
Version 2 does not convert to DVD yet. That profile does not work, is that the profile you are using?
Yes, that's the profile I'm using. However, Cedric noted above that it does work...
I am sorry about that, I guess you are right. For me however I don't think it works and I haven't tested it yet. Maybe towards the end of next week I think the DVD profile should be working again.
OK. I'll switch back to version 1 until version 2 works.
